P2000 to Domoticz for central ventilation
phoenixblue
Target OS: Raspberry Pi
Domoticz version: 3.7392
Post by phoenixblue » Monday 05 June 2017 15:27
I have for the Dutch users maybe an nice script for Domoticz to control your home ventilation when there is an current fire or other problem where it's handy to shutdown you home ventilation.
The script is build to import P2000 messages that will check if there is an active "GRIP" messages, after import it will compare the location with the GPS location that is set into the script.
When the result is positive it will send the info to Domoticz to control for example the home ventilation system.
Setup
First create an virtual Alert device into domoticz to push the info to and setup inside this script the following info:
domoticz_server = "http://localhost"
domoticz_port = 8080
domoticz_device = 1
alert_range = 25 # in km
llatHome = xx.xxxxx
lngHome = xx.xxxx
Note: The script is also able to check the GPS location from Domoticz.
Made an cronejob to run this script every x time to check the P2000 server. For test you can set the random_debug to 1 to send GRIP alerts to domotics when needed.
There are some issues to solve but maybe someone has an nice idea to solve it.
- Insert an option to send messages 1 time so there are no double messages in the system.
- Debug the default level to green when there is no actual message (already start it with it)
- Use an RTL_SDR stick to receive local the P2000 messages like the airplane script.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import xml.etree.ElementTree as ET
import requests
import json
import math
import random
from requests.exceptions import ConnectionError
domoticz_device = 1
random_debug = 0 # 1 for enable
llatHome = xx.xxxxx
lngHome = xx.xxxx
# Try to get the data from domoticz
try:
    data = json.loads(
        requests.get(
            "%s:%d/json.htm?type=settings" %
            (domoticz_server, domoticz_port)).content)
    latHome = float(data['Location']['Latitude'])
    lngHome = float(data['Location']['Longitude'])
except:
    pass
class GripAlert:
    def __init__(self):
        self.link = "http://feeds.livep2000.nl/"
        if random_debug:
            self.push(random.randint(0, 4), "debug push")
        self.fetch()
    def push(self, level, text):
        try:
            requests.get(
                "%s:%d/json.htm?type=command&param=udevice&idx=%d&nvalue=%d&svalue=%s" %
                (domoticz_server, domoticz_port, domoticz_device, level, text))
        except ConnectionError:
            print "I wasn't able to contact the domoticz server, is it up?"
    def fetch(self):
        # fetch the data and push it
        z = requests.get(self.link)
        elements = ET.fromstring(z.content).getchildren()[0].getchildren()
        pushed = 0
        for element in elements[7:]:
            data = element.getchildren()
            try:
                title = data[0].text.replace("<br/>", "\n")
                description = data[3].text.replace("<br/>", "\n")
                lat = float(data[6].text)
                lng = float(data[7].text)
                if not (self.calculateDistance(latHome, lngHome, lat,
                        lng) <= alert_range):
                    continue
                level = 0
                if ("grip: 1" in title.lower()
                        or "grip: 1" in description.lower()):
                    level = 1
                elif ("grip: 2" in title.lower() or "grip: 2" in description.lower()):
                    level = 2
                elif ("grip: 3" in title.lower() or "grip: 3" in description.lower()):
                    level = 3
                elif ("grip: 4" in title.lower() or "grip: 4" in description.lower()):
                    level = 4
                if not level:
                    continue
                message = "%s\n%s" % (title, description)
                self.push(level, message)
                print "Pushed alert, GRIP Level: %d\nMessage: %s" % (level, message)
                pushed += 1
            except:
                pass
        if not pushed:
            print "No alerts were pushed"
    def calculateDistance(self, lat1, lng1, lat2, lng2):
        radius = 6371
        dLat = (lat2 - lat1) * math.pi / 180
        dLng = (lng2 - lng1) * math.pi / 180
        lat1 = lat1 * math.pi / 180
        lat2 = lat2 * math.pi / 180
        val = math.sin(dLat / 2) * math.sin(dLat / 2) + math.sin(dLng / 2) * \
            math.sin(dLng / 2) * math.cos(lat1) * math.cos(lat2)
        ang = 2 * math.atan2(math.sqrt(val), math.sqrt(1 - val))
        return radius * ang
GripAlert()
scripts on github: Link
assenzuid
Re: P2000 to Domoticz for central ventilation
Post by assenzuid » Tuesday 06 June 2017 21:25
Nice and thanks for sharing.
EdwinK
Post by EdwinK » Wednesday 07 June 2017 10:16
I created the device, but can't seem to find it. It is in the device list, but not on any of the other tabs.
Device list
Screen Shot 2017-06-07 at 10.11.13.png (30.32 KiB) Viewed 2476 times
Duh... Should have enabled the device. Smart me.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
EdwinK
Post by EdwinK » Monday 21 August 2017 23:09
And now that we have a GRIP 2 situation in my region, it doesn't show on Domoticz :(
EdwinK
Post by EdwinK » Tuesday 22 August 2017 8:42
Mmm... Now the alerts show up.
EdwinK
Post by EdwinK » Tuesday 22 August 2017 9:09
Something looks wrong. I think I get the same data over and over.
2017-08-22 00:13:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:12:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:11:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:10:07 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:09:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:08:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:07:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:06:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:05:06 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:04:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:03:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:02:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:01:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-22 00:00:06 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:59:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:58:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:57:02 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:56:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:55:06 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:54:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:53:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:52:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:51:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:50:05 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:49:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:48:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:47:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:46:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:45:06 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:44:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:43:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:42:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:41:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:40:06 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
2017-08-21 23:39:03 A1 (GRIP: 2) AMBU 17114 Botlekweg 3197KA Botlek Rotterdam BOTLEK bon 80414 1420999 MKA Rotterdam-Rijnmond ( Monitorcode ) 1420014 MKA Rotterdam-Rijnmond ( Ambulance 17-114 )
EdwinK
Post by EdwinK » Tuesday 22 August 2017 9:59
Screen Shot 2017-08-22 at 09.58.52.png (91.04 KiB) Viewed 2111 times
Derik
Post by Derik » Tuesday 22 August 2017 19:17
should this not be possible without a stick?
There are different site where the alarms can be found,,
Sorry i cannot make the script respect for the builder!
Only a web location to get the data is perhaps better?
EdwinK
Post by EdwinK » Tuesday 22 August 2017 19:46
You don't need any stick for this. The data comes from a website.
Derik
Post by Derik » Tuesday 22 August 2017 19:51
You don't need any atick for this. The data comes from a website.
mmm Sorry..
I read this....
Derik
Post by Derik » Tuesday 22 August 2017 19:56
mmm what type virtual do i need?
And can i run this script with the intern python option?
What type is the best option [ i do not understand a thing of this optiosn...:_( ]
Or just external script, and use a crontab?
EdwinK
Post by EdwinK » Tuesday 22 August 2017 20:08
Siewert308SW
Post by Siewert308SW » Tuesday 30 January 2018 14:57
Just a thought.
What if i only want to follow our local fire dep.
Could it be possible to insert a option to show only alarms from a specfic CAP code
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
phoenixblue
Post by phoenixblue » Wednesday 31 January 2018 0:40
I think this will not be an problem, in that case there must be made an other version op de script without the gps part.
Siewert308SW
Post by Siewert308SW » Wednesday 31 January 2018 20:37
thx, looking forward to it...
Setup:
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
EdwinK
Post by EdwinK » Saturday 14 April 2018 15:57
Now trying to get this to work again, but
sudo python P2000.py
  File "P2000.py", line 45
    print "I was not able to contact the domoticz server, is it up?"
SyntaxError: Missing parentheses in call to 'print'
EdwinK
Post by EdwinK » Wednesday 25 July 2018 8:53
Still not getting this to work ;(
Users browsing this forum: No registered users and 7 guests
