API - When to use nvalue and when svalue? Topic is solved
maho2nd
Target OS: Raspberry Pi
Post by maho2nd » Monday 29 May 2017 19:57
What does nvalue and svalue represent?
In the JSON-API sometimes the nvalue is used (Air quality) and most times the svalue is used (Temperature, etc.).
maho2nd
Re: API - When to use nvalue and when svalue?
Post by maho2nd » Monday 29 May 2017 21:41
tvurce
Post by tvurce » Saturday 10 November 2018 14:06
I am interested too...
Post by waaren » Saturday 10 November 2018 14:51
nValue = numeric ( one value -- INTEGER DEFAULT 0)
sValue = string ( multiple values -- VARCHAR(200) DEFAULT null )
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
tvurce
Post by tvurce » Monday 12 November 2018 11:08
Yes. But in a lot of examples, there are numbers throwing to Domoticz with sValue. This is little bit confusing. But anyway, if one send number to Domoticz in sValue, it seems working (graphs, averages etc are calculated OK...)
febalci
Post by febalci » Monday 12 November 2018 11:17
You can find out when to use svalue or nvalue according to the device type in this page:
https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
emme
Domoticz version: latest
Post by emme » Monday 12 November 2018 11:43
nValue (Numeric Value) is only integer and is used command option for existing devices:
ON(1)
OFF(0)
STOP(17)
DIM LEVEL(2)
(I think there are more, but up to know I know these)
any other value should be set to sValue (String Value)
"We always done this way"
Users browsing this forum: No registered users and 3 guests
