[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
moroen
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Post by moroen » Tuesday 21 August 2018 13:22
Philos31 wrote:
Tuesday 21 August 2018 10:18
Hi, I am allready busy for 2 days to get this working.
Everything seems ok, but there is something strange going on.
In the domoticz log I see:
2018-08-21 10:04:21.915 Error: (Tradfri) ----> Line 280 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py, function onMessage
2018-08-21 10:04:21.915 Error: (Tradfri) ----> Line 190 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py, function onMessage
2018-08-21 10:04:22.567 Error: (Tradfri) ----> Line 280 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py, function onMessage
2018-08-21 10:04:22.567 Error: (Tradfri) ----> Line 190 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py, function onMessage
When I try:
python3 tradfri.tac
It is stuck when initializing
IKEA-tradfri COAP-adaptor version 0.6 started (command line)!
Connected from IPv4Address(type='TCP', host='127.0.0.1', port=52704)
Data received: b'{"identity": "domoticz", "gateway": "192.168.1.136", "action": "setConfig", "pollinterval": "30", "groups": "False", "psk": "*****************", "observe": "True"}'
Initializing gateway
And it stays initializing, doing nothing further...
Any idea?
Sorry for the late reply! It would appear that you're using the latest beta of domoticz?
I commited a small fix to the development-branch of the plugin a couple of days ago, that should address this issue. If it still fails, feel free to open a issue on github or let me know here in the forum.
Regards,
M
ivarka
Target OS: Raspberry Pi
Post by ivarka » Wednesday 22 August 2018 9:36
IKEA will launch a smart plug in october: https://teknikveckan.com/nyheter/ikea-g ... rt-i-host/
Philos31
Post by Philos31 » Wednesday 22 August 2018 9:41
Any idea?
Regards,
M
Thanks, that would explain a lot. I am running the latest Beta, started this week building my years old domoticz from scratch.
Now if I just knew how to pull the development-branch from Git.... but I found that out.
It seems to work now. Thanks.
RasPi2/KaKu/HUE/Xiaomi/Z-Wave/Nuki/Daikin 3,5kw Ururu Sarara/IR Heating Panels all working together with domoticz
dzjr
Domoticz version: 4.9942B
Post by dzjr » Friday 24 August 2018 23:47
Hello everyone,
I have made a new attempt, a completely new installation (read that there was an update).
now I'm a little further .. it just does not work ...
when I reboot the PI I get the following message in the log of domoticz:
2018-08-24 23:46:27.012 (IKEA Tradfri) Connected successfully to: 192.168.0.19
2018-08-24 23:46:27.013 Error: (IKEA Tradfri) 'onMessage' failed 'TypeError':'byte indices must be integers or slices, not str'.
2018-08-24 23:46:27.013 Error: (IKEA Tradfri) ----> Line 282 in /home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py, function onMessage
2018-08-24 23:46:27.013 Error: (IKEA Tradfri) ----> Line 195 in /home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py, function onMessage
2018-08-24 23:46:38.088 PluginSystem: Restarting I/O service thread.
2018-08-24 23:46:38.089 (IKEA Tradfri) Device has disconnected
What did I do wrong?
maybe done too much?
I hope someone could help!
Raspberry Pi-3 Domoticz Beta
Tradfri Pluging by Moroen, Home made MySensors, Luftdaten, Home & Garden automatisation
moroen
Post by moroen » Saturday 25 August 2018 18:51
Hello everyone,
Hi!
Which version of domoticz and which branch of the plugin are you using?
[edit]
I managed to recreate this error by using the domoticz stable with the development-branch of the plugin. If you try using the plugin's master branch with domoticz stable, it should work.
[/edit]
Regards,
M
dzjr
Post by dzjr » Saturday 25 August 2018 19:37
Good evening M,
Yesterday i used the latest stable final version of Domoticz, and in used the plugin from your github, i downloaded both yesterday.
Today i have tried to upgrade tot Domoticz Beta (now Version: 4.9942 Build Hash: 5524d792)
Now i have this message on the Domoticz Log:
 2018-08-25 19:24:17.133 (IKEA Tradfri) Connected successfully to: 192.168.0.19
2018-08-25 19:24:28.107 (IKEA Tradfri) Device has disconnected
When i start " python3 tradfri.tac " i get the following message;
Couldn't listen on any:1234: [Errno 98] Address already in use.
Whit twistd -n -y tradfri.tac i get the message:
Another twistd server is running, PID 267
This could either be a previously started instance of your application or a
different application entirely. To start a new one, either run it in some other
directory, or use the --pidfile and --logfile parameters to avoid clashes.
The content of ikea-tradfri.service is:
[Unit]
Description=IKEA Tradfri COAP-adapter
[Service]
Type=simple
Environment=IKEA_HOME=/home/pi/domoticz/plugins/IKEA-Tradfri
ExecStart=/usr/local/bin/twistd --nodaemon \
      --rundir=${IKEA_HOME} \
      --pidfile=${IKEA_HOME}/twistd.pid \
      --python=${IKEA_HOME}/tradfri.tac
User=root
Group=root
Restart=always
[Install]
WantedBy=multi-user.target
What do i wrong?
as far as I can see, the coap client just works.
I hope you can help me
dzjr
moroen
Post by moroen » Sunday 26 August 2018 2:37
Good evening M,
[Unit]
[Service]
Type=simple
User=root
Group=root
Restart=always
[Install]
What do i wrong?
dzjr
It looks like you already have the adapter running. If you're using latest beta of domoticz with the plugin version from the developmen-branch, a reboot of the Pi should do the trick...
Regards,
M
dzjr
Post by dzjr » Sunday 26 August 2018 17:15
Regards,
M
Hello M,
I have tried a reboot several times, and still the same "error"
I made a clean install with Domoticz Beta 4.9948 & IKEA-Tradfri development branche, and again the same problem.....
Coaps is working..., only the script of ggravelingen din't work right i think (try it yourself).
i don't know what i can try next....
dzjr
moroen
Post by moroen » Sunday 26 August 2018 19:52
Regards,
M
Hello M,
dzjr
Ok, please try: Go to the plugin-directory (/home/pi/domoticz/plugins/IKEA-Tradfri) look for and remove the twistd.pid file if it exists, then try to run the adapter from the command line.
Regards,
M
dzjr
Post by dzjr » Sunday 26 August 2018 20:55
Regards,
M
i have removed twistd.pid and run twistd -n -y tradfri.tac and the output is:
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ twistd -n -y tradfri.tac
2018-08-26T20:51:11+0200 [-] Loading tradfri.tac...
2018-08-26T20:51:13+0200 [-] Loaded.
2018-08-26T20:51:13+0200 [twisted.scripts._twistd_unix.UnixAppLogger#info] twistd 18.7.0 (/usr/bin/python3 3.5.3) starting up.
2018-08-26T20:51:13+0200 [twisted.scripts._twistd_unix.UnixAppLogger#info] reactor class: twisted.internet.epollreactor.EPollReactor.
2018-08-26T20:51:13+0200 [stderr#error] Traceback (most recent call last):
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/internet/tcp.py", line 1361, in startListening
2018-08-26T20:51:13+0200 [stderr#error]     skt.bind(addr)
2018-08-26T20:51:13+0200 [stderr#error] OSError: [Errno 98] Address already in use
2018-08-26T20:51:13+0200 [stderr#error] During handling of the above exception, another exception occurred:
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/bin/twistd", line 11, in <module>
2018-08-26T20:51:13+0200 [stderr#error]     sys.exit(run())
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/scripts/twistd.py", line 31, in run
2018-08-26T20:51:13+0200 [stderr#error]     app.run(runApp, ServerOptions)
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/application/app.py", line 674, in run
2018-08-26T20:51:13+0200 [stderr#error]     runApp(config)
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/scripts/twistd.py", line 25, in runApp
2018-08-26T20:51:13+0200 [stderr#error]     runner.run()
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/application/app.py", line 385, in run
2018-08-26T20:51:13+0200 [stderr#error]     self.postApplication()
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/scripts/_twistd_unix.py", line 254, in postApplication
2018-08-26T20:51:13+0200 [stderr#error]     self.startApplication(self.application)
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/scripts/_twistd_unix.py", line 442, in startApplication
2018-08-26T20:51:13+0200 [stderr#error]     service.IService(application).privilegedStartService()
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/application/service.py", line 283, in privilegedStartService
2018-08-26T20:51:13+0200 [stderr#error]     service.privilegedStartService()
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/application/internet.py", line 114, in privilegedStartService
2018-08-26T20:51:13+0200 [stderr#error]     self._port = self._getPort()
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/application/internet.py", line 142, in _getPort
2018-08-26T20:51:13+0200 [stderr#error]     'listen%s' % (self.method,))(*self.args, **self.kwargs)
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/internet/posixbase.py", line 495, in listenTCP
2018-08-26T20:51:13+0200 [stderr#error]     p.startListening()
2018-08-26T20:51:13+0200 [stderr#error]   File "/usr/local/lib/python3.5/dist-packages/twisted/internet/tcp.py", line 1363, in startListening
2018-08-26T20:51:13+0200 [stderr#error]     raise CannotListenError(self.interface, self.port, le)
2018-08-26T20:51:13+0200 [stderr#error] twisted.internet.error.CannotListenError: Couldn't listen on any:1234: [Errno 98] Address already in use.
output of python3 tradfri.tac is:
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
moroen
Post by moroen » Monday 27 August 2018 18:09
The network port is already taken. Either you have the adapter running in the background (started via systemd?) or another service is using the same port-number (1234). It could also be that the port is being blocked by a firewall or something. I would guess the adapter already running is the most probable reason.
If you try:
$ sudo systemctl stop ikea-tradfri.service
and let me know the output...
Regards,
M
dzjr
Post by dzjr » Monday 27 August 2018 19:02
If you try:
Regards,
M
the output of python3 tradfri.tac is:
Connected from IPv4Address(type='TCP', host='127.0.0.1', port=45418)
Data received: b'{"groups": "True", "gateway": "192.168.0.19", "identity": "*****", "pollinterval": "30", "observe": "True", "action": "setConfig", "psk": "{\\"9091\\":\\"123456789\\",\\"9029\\":\\"1.4.0015\\"}"}'
Unhandled Error
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/log.py", line 103, in callWithLogger
    return callWithContext({"system": lp}, func, *args, **kw)
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/log.py", line 86, in callWithContext
    return context.call({ILogContext: newCtx}, func, *args, **kw)
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/context.py", line 122, in callWithContext
    return self.currentContext().callWithContext(ctx, func, *args, **kw)
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/context.py", line 85, in callWithContext
    return func(*args,**kw)
--- <exception caught here> ---
  File "/usr/local/lib/python3.5/dist-packages/twisted/internet/posixbase.py", line 614, in _doReadOrWrite
    why = selectable.doRead()
  File "/usr/local/lib/python3.5/dist-packages/twisted/internet/tcp.py", line 243, in doRead
    return self._dataReceived(data)
  File "/usr/local/lib/python3.5/dist-packages/twisted/internet/tcp.py", line 249, in _dataReceived
    rval = self.protocol.dataReceived(data)
  File "tradfri.tac", line 76, in dataReceived
    self.factory.initGateway(self, command)
  File "tradfri.tac", line 275, in initGateway
    self.devices = self.api(self.api(self.gateway.get_devices()))
  File "/usr/local/lib/python3.5/dist-packages/pytradfri/api/libcoap_api.py", line 96, in request
    return self._execute(api_commands, timeout=timeout)
  File "/usr/local/lib/python3.5/dist-packages/pytradfri/api/libcoap_api.py", line 85, in _execute
    raise RequestTimeout() from None
pytradfri.error.RequestTimeout:
Disconnected
dzjr
moroen
Post by moroen » Wednesday 29 August 2018 19:26
Unhandled Error
Disconnected
Ok, so the adapter times out when trying to use coap-client to communicate with the gateway. Are you sure you're using the correct ident/pks? Correct IP-adress? Can you use the coap-client directly to communicate with the gateway?
Regards,
M
dzjr
Post by dzjr » Wednesday 29 August 2018 19:43
Regards,
M
i get this
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ coap-client -k "***************" coaps://192.168.0.19/.well-known/core
v:1 t:CON c:GET i:77ff {} [ ]
<//15006>;ct=0;obs,<//15001>;ct=0;obs,<//15004>;ct=0;obs,<//15004/add>;ct=0,<//15004/remove>;ct=0,<//15010>;ct=0;obs,<//15005>;ct=0;obs,<//15011/15012>;ct=0;obs,<//15011/9034>;ct=0,<//15011/9030>;ct=0,<//15011/9031>;ct=0,<//15011/9102>;ct=0,<//15011/9094>;ct=0;obs,<//15011/9095>;ct=0;obs,<//15011/9104>;ct=0;obs,<//15010/317446>;ct=0;obs,<//15010/289670>;ct=0;obs,<//15005/169498/200393>;ct=0;obs,<//15005/169498/220984>;ct=0;obs,<//15005/169498/205165>;ct=0;obs,<//15004/169498>;ct=0;obs,<//15005/169498>;ct=0;obs,<//15004/138625>;ct=0;obs,<//15005/138625>;ct=0;obs,<//15001/65537>;ct=0;obs,<//15001/65540>;ct=0;obs,<//15001/65536>;ct=0;obs,<//15001/65538>;ct=0;obs,<//15001/65542>;ct=0;obs,<//15001/65541>;ct=0;obs,<//15005/160748/212648>;ct=0;obs,<//15005/160748/217145>;ct=0;obs,<//15005/160748/197623>;ct=0;obs,<//15004/160748>;ct=0;obs,<//15005/160748>;ct=0;obs,<//15001/65543>;ct=0;obs,<//15005/138625/222168>;ct=0;obs,<//15005/138625/203559>;ct=0;obs,<//15005/138625/224462>;ct=0;obs,<//15011/9063>;ct=0,<//15001/65544>;ct=0;obs,<//15010/285904>;ct=0;obs
dzjr
Post by dzjr » Thursday 30 August 2018 18:15
Regards,
M
:oops: i did something stupit, i used the complete ouput of the coap call into Domoticz...
i placed only the PSK :idea: , and now it is working....
thank you for the helping, and offcourse for the plugin!
regeards
dzjr
moroen
Post by moroen » Friday 31 August 2018 14:17
regeards
dzjr
Glad it worked out for you!
I've been toying with an idea to handle the whole IDENT/PSK-thing differently, I'll use your experience as motivation to finally getting it implemented...
Regards,
M
moroen
Post by moroen » Tuesday 04 September 2018 22:38
The latest version of the plugin's development branch now has a rather major change, a change that will break a current installation of the plugin, though rather easy to fix.
Instead of generating a (or using a known) IDENT/PSK pair, and then entering this information on the plugin setup page, the IDENT/PSK is handled by the adaptor, and generated using a configure.py python scipt, which need to be executed once before the adapter starts.
Anyone updating to the newest version are encouraged to the check out the readme for instructions, and report errors, problems or suggestions in this thread. Hopefully this change will alleviate a rather common problem getting the adapter to run, as you only need to supply the gateway IP and master-key on setup, no more manually using the coap-client directly to generate the IDENT/PSK-pair.
Regards,
M
MichaelvK
Domoticz version: 4.9992
Post by MichaelvK » Sunday 09 September 2018 11:02
Hi M,
I am running the plugin on development, and Domoticz on 4.9700.
When running the tradfri.tac, it is quiet.
After starting the plugin from Domoticz, I get the following result.
It is in a reboot loop after that, so the plugin re-initializes, and all lines re-occur.
It must be a very small issue, as I came this far finally (getting the right python3, pip3, twisted and coap-client setups without ipkg or so within the Synology linux variant..)
I have received the psk and marked it as x.x.xxxx below, it is a numeric value ofcourse.
Me@Diskstation216:/usr/local/domoticz/var/plugins/IKEA-Tradfri$ python3 tradfri.tac
Connected from IPv4Address(type='TCP', host='127.0.0.1', port=55273)
Data received: b'{"pollinterval": "30", "gateway": "192.168.1.167", "identity": "Client_identity", "groups": "False", "observe": "True", "psk": "x.x.xxxx", "action": "setConfig"}'
Unhandled Error
File "/opt/lib/python3.6/site-packages/twisted/python/log.py", line 103, in callWithLogger
File "/opt/lib/python3.6/site-packages/twisted/python/log.py", line 86, in callWithContext
File "/opt/lib/python3.6/site-packages/twisted/python/context.py", line 122, in callWithContext
File "/opt/lib/python3.6/site-packages/twisted/python/context.py", line 85, in callWithContext
File "/opt/lib/python3.6/site-packages/twisted/internet/posixbase.py", line 614, in _doReadOrWrite
File "/opt/lib/python3.6/site-packages/twisted/internet/tcp.py", line 243, in doRead
File "/opt/lib/python3.6/site-packages/twisted/internet/tcp.py", line 249, in _dataReceived
File "/opt/lib/python3.6/site-packages/pytradfri-5.5.1-py3.6.egg/pytradfri/api/libcoap_api.py", line 96, in request
File "/opt/lib/python3.6/site-packages/pytradfri-5.5.1-py3.6.egg/pytradfri/api/libcoap_api.py", line 85, in _execute
Disconnected
My Domoticz config:
My Domoticz log:
Synology DS216+ & Domoticz as a Package (Jadahl)
connected:
Denon AVR2200W
Panasonic TX-L47ET60B
Doorbell Action
Several KAKU Action Flamingo's
Ali-Express WiFi cam
Ali-Express WiFi PTZ cam (soon)
Ali-Express PIR's
IKEA Trådfri
Dnpwwo
Post by Dnpwwo » Sunday 09 September 2018 15:05
I assume you have upgraded Domoticz recently because the plugin framework changed JSON handling a few months ago and I believe that is your problem.
This code at around line 188 in plugin.py:
def onMessage(self, Connection, Data):
        #Domoticz.Debug("Received: " + str(Data))
command = json.loads(Data.decode("utf-8"))
is out of date because the framework now returns structured JSON rather than a simple string as it did previously.
It needs to be changed to be something like:
command = Data
MichaelvK
Post by MichaelvK » Sunday 09 September 2018 19:54
Got it working indeed , missed an update of Domoticz, but as this is handled as a package, had to pick a beta from Jadahl.
Great!
All I now have to figure out is to have the "python3 tradfri.tac" as a daemon / service on Synology.
Not as easy as it sounds..
Great stuff this plugin!!
connected:
Denon AVR2200W
Doorbell Action
Ali-Express PIR's
IKEA Trådfri
Users browsing this forum: QSKONE and 3 guests
