[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
moroen
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Post by moroen » Thursday 31 May 2018 23:54
bmoons wrote:
Thursday 31 May 2018 14:27
everything worked for 30 min afterwards I restarted the PI and it doesn't connect anymore to my devices.
I get an error
Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
I really want this to work
The adapter is not running. Are you running the adapter as a service? On a guess, I would say that you ran the adapter from the command line, and after reboot, it didn't restart. See the description of the steps I gave to Mario a couple of posts back... :)
Regards,
M
moroen
Post by moroen » Friday 01 June 2018 0:01
Mario wrote:
Thursday 31 May 2018 21:00
Hi M,
Done as told and I think everything went okay, except the hardware isn't showing anymore. I think plugin doesn't start now, can you try to explain why?
Here is the log from PI and the log from Domoticz
sudo systemctl status ikea-tradfri
● ikea-tradfri.service - IKEA Tradfri COAP-adapter
Loaded: loaded (/lib/systemd/system/ikea-tradfri.service; enabled)
Active: active (running) since Thu 2018-05-31 20:46:48 CEST; 5min ago
Main PID: 433 (twistd)
CGroup: /system.slice/ikea-tradfri.service
└─433 /usr/local/bin/python3.5 /usr/local/bin/twistd --nodaemon --rundir=/home/pi/domoticz/plugins/IKEA-Tradfri ...
May 31 20:46:48 raspberrypi systemd[1]: Started IKEA Tradfri COAP-adapter.
May 31 20:46:51 raspberrypi twistd[433]: 2018-05-31T20:46:51+0200 [-] Loading /home/pi/domoticz/plugins/IKEA-Tradfri/...tac...
May 31 20:46:51 raspberrypi twistd[433]: 2018-05-31T20:46:51+0200 [-] Loaded.
May 31 20:46:51 raspberrypi twistd[433]: 2018-05-31T20:46:51+0200 [twisted.scripts._twistd_unix.UnixAppLogger#info] t...ng up.
May 31 20:46:51 raspberrypi twistd[433]: 2018-05-31T20:46:51+0200 [twisted.scripts._twistd_unix.UnixAppLogger#info] r...actor.
May 31 20:46:51 raspberrypi twistd[433]: 2018-05-31T20:46:51+0200 [-] AdaptorFactory starting on 1234
May 31 20:46:51 raspberrypi twistd[433]: 2018-05-31T20:46:51+0200 [builtins.AdaptorFactory#info] Starting factory <Ad...02b90>
Hint: Some lines were ellipsized, use -l to show in full.
2018-05-31 20:46:54.302 Domoticz V3.9527 (c)2012-2018 GizMoCuz
2018-05-31 20:46:54.302 Build Hash: 2fe4348e, Date: 2018-05-28 14:09:12
2018-05-31 20:46:54.303 Startup Path: /home/pi/domoticz/
2018-05-31 20:46:54.467 EventSystem: reset all events...
2018-05-31 20:46:54.474 PluginSystem: 'IKEA' Registration ignored, Plugins are not enabled.
2018-05-31 20:46:54.507 WebServer(HTTP) started on address: :: with port 8080
2018-05-31 20:46:54.530 WebServer(SSL) started on address: :: with port 443
2018-05-31 20:46:54.532 Proxymanager started.
2018-05-31 20:46:54.533 Camera: settings (re)loaded
2018-05-31 20:46:54.535 TCPServer: shared server started...
2018-05-31 20:46:54.535 RxQueue: queue worker started...
2018-05-31 20:46:55.697 PROXY: Authenticate result: success.
2018-05-31 20:46:56.536 Wunderground: Worker started...
2018-05-31 20:46:56.538 ToonThermostat: Worker started...
The operative line is "2018-05-31 20:46:54.474 PluginSystem: 'IKEA' Registration ignored, Plugins are not enabled." You should see a line confirming the presence of python, like
2018-06-01 00:04:36.253  PluginSystem: Started, Python version '3.6.5'
Have you installed the python libs and dev?
$ sudo apt-get install python3 python3-dev
I think the python3 package is installed by default, allowing python3 to run from the command line, but you actually need the libs from the dev-package to run embedded python like in domoticz!
Regards,
M
Mario
Target OS: Raspberry Pi
Post by Mario » Friday 01 June 2018 8:15
Dear M,
See below,
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3 is already the newest version.
python3 set to manually installed.
python3-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So what else can we try?
moroen
Post by moroen » Saturday 02 June 2018 1:12
Dear M,
See below,
Ok, let's take a step back: Are you using a precompiled binary or are compiling from source? Beta or stable?
Regards,
M
Mario
Post by Mario » Saturday 02 June 2018 9:38
Dear M,
See below,
Regards,
M
Goodmorning M,
First time I used the following:
1. wget https://www.python.org/ftp/python/3.5.2 ... 5.2.tar.xz
2. tar -xvf Python-3.5.2.tar.xz
3. cd Python-3.5.2
4. ./configure
5. make
6 make altinstall
It was not working and I noticed you said something about Python 3.6 and then I installed following:
sudo apt-get update
$ sudo apt-get install build-essential tk-dev libncurses5-dev libncursesw5-dev libreadline6-dev libdb5.3-dev libgdbm-dev libsqlite3-dev libssl-dev libbz2-dev libexpat1-dev liblzma-dev zlib1g-dev
If one of the packages cannot be found, try a newer version number (e.g. libdb5.4-dev instead of libdb5.3-dev).
Download and install Python 3.6. When downloading the source code, select the most recent release of Python 3.6, available on the official site. Adjust the file names accordingly.
$ wget https://www.python.org/ftp/python/3.6.5 ... 6.5.tar.xz
$ tar xf Python-3.6.5.tar.xz
$ cd Python-3.6.5
$ ./configure
$ make
$ sudo make altinstall
I figure this is the stable one. When I need another version can you direct me n where to get it?
Again thanks for the help
moroen
Post by moroen » Sunday 03 June 2018 1:18
Dear M,
See below,
Regards,
M
Goodmorning M,
3. cd Python-3.5.2
4. ./configure
5. make
6 make altinstall
sudo apt-get update
$ cd Python-3.6.5
$ ./configure
$ make
Any version of python > 3.4 should work, so 3.6 is great! I figure that either domoticz can't find the pythonX.so (lib-file) or somehow have been compiled without python support.
Regards,
M
Mario
Post by Mario » Sunday 03 June 2018 22:27
Dear Moroen,
Don't ask me what I did but everything is working now. I would like to thank you for your help and your patience. it is much appreciated.
Kind regards,
Mario
moroen
Post by moroen » Monday 04 June 2018 16:45
Dear Moroen,
Kind regards,
Mario
Glad it worked out! :) And no problem!
Regards,
M
Mario
Post by Mario » Wednesday 06 June 2018 20:57
Dear Moroen,
I was too excited. Domoticz will run for a day and then goes offline. After reboot I notice the following error in Domoticz:
Something shuts down. Can you figure out what?
Thx, Mario
moroen
Post by moroen » Wednesday 06 June 2018 21:07
Dear Moroen,
Thx, Mario
Hm, strange. Are you using any other python-plugins? You're on a raspberry pi, if memory serves me correctly? Have you tried starting from scratch, using a frem download of raspbian.img?
Regards,
M
Mario
Post by Mario » Wednesday 06 June 2018 21:44
No other python plugins. Only a rfxcom.
And yes, installation was from scratch. A Jessie raspberry PI image.
moroen
Post by moroen » Wednesday 06 June 2018 22:24
Compiling domoticz from source or using a prebuilt binary?
Regards,
M
redfirebrooks
Post by redfirebrooks » Sunday 24 June 2018 22:44
just to mention that it looks like the plugin does not work with de v4.9 :
2018-06-24 22:25:15.879 Error: (IKEA-TRADFRI) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2018-06-24 22:25:16.782 Error: (IKEA-TRADFRI) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
I hope it will be updated soon.
Kaitsu
Post by Kaitsu » Monday 25 June 2018 21:39
redfirebrooks wrote:Hello,
Development branch works with latest stable.
Lähetetty minun ONEPLUS A5010 laitteesta Tapatalkilla
m0rph13
Domoticz version: 3.4834
Post by m0rph13 » Sunday 01 July 2018 17:34
Gettting the latest version from Master branch and restarting my Pi made the above mentioned problem go away. The only strangeness that remains (for me now) is that none of the Trådfri devices are shown anywhere except for under Settings -> Devices.
Anyone else encountered this and found a fix for it?
https://github.com/moroen/IKEA-Tradfri-plugin/issues/39
dzjr
Domoticz version: 4.9700
Post by dzjr » Friday 06 July 2018 19:37
Hello everybody,
I am a newbie whit Domoticz and i hope that i can control my home and garden whit Domoticz.
As a start i was trying to install the Ikea Tradfri plugin because i already have some Tradfri components, and thats a good start i thought .
So, i have a raspberry 3 clean install whit "Raspbian stretch 2018-06-28" and also a clean install of "Domoticz 4.9700"
After the install of Domoticz i tried to Install libcoap as per ggravlingen's description, only whit that script gave a error of missing some file's (it Couldn't find áutoconfig', 'aclocal', 'libtool', 'libtoolize')
(i dind't make a copy of these error's).
Whit some help of google i found at https://learn.pimoroni.com/tutorial/san ... om-your-pi a working instruction for Coap, so first step dune.
Next i followed the instruction from the Github, it looks like everything was installed oké,
So, i configured IKEA Tradfri in Domoticz, and in the log there was the following error:
2018-07-06 18:39:53.965 (Tradfri) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2018-07-06 18:39:53.965 (Tradfri) Device has disconnected
I looked in some message's on this board and(re) installed/updated OpenSSL and twisted as suggested and also Run tradfri.tac whit Python3 and it display a error message after i pressed RUN
Warning (from warnings module):
  File "", line 0
UserWarning: You do not have a working installation of the service_identity module: 'No module named 'service_identity''.
Please install it from <https://pypi.python.org/pypi/service_identity> and make sure all of its dependencies are satisfied.
Without the service_identity module, Twisted can perform only rudimentary TLS client hostname verification.
Many valid certificate/hostname mappings may be rejected.
So i google-ed for service-identity and tried to install is whit " sudo pip install service_identity"
after re-run " sudo pip install service_identity " the commandline came whit the message that is is installed in Phyton2,7
only that don't get a solution probably because it is installed in Phyton 2,7 instead of 3,5, the next error display-ed in Phyton-3 after run tradfri.tac;
I don't know how to install the service-identyti in phyton3,5.
Connected from IPv4Address(TCP, '127.0.0.1', 44672)
Data received: b'{"groups": "False", "identity": "***************", "pollinterval": "30", "psk": "{\\"9091\\":\\"****************\\",\\"9029\\":\\"1.4.0015\\"}", "gateway": "192.168.0.19", "action": "setConfig", "observe": "False"}'
Initializing gateway
Unhandled Error
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/log.py", line 103, in callWithLogger
    return callWithContext({"system": lp}, func, *args, **kw)
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/log.py", line 86, in callWithContext
    return context.call({ILogContext: newCtx}, func, *args, **kw)
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/context.py", line 122, in callWithContext
    return self.currentContext().callWithContext(ctx, func, *args, **kw)
  File "/usr/local/lib/python3.5/dist-packages/twisted/python/context.py", line 85, in callWithContext
    return func(*args,**kw)
--- <exception caught here> ---
  File "/usr/local/lib/python3.5/dist-packages/twisted/internet/posixbase.py", line 614, in _doReadOrWrite
    why = selectable.doRead()
  File "/usr/local/lib/python3.5/dist-packages/twisted/internet/tcp.py", line 205, in doRead
    return self._dataReceived(data)
  File "/usr/local/lib/python3.5/dist-packages/twisted/internet/tcp.py", line 211, in _dataReceived
    rval = self.protocol.dataReceived(data)
  File "/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac", line 76, in dataReceived
    self.factory.initGateway(self, command)
  File "/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac", line 275, in initGateway
    self.devices = self.api(self.api(self.gateway.get_devices()))
  File "/home/pi/.local/lib/python3.5/site-packages/pytradfri/api/libcoap_api.py", line 96, in request
    return self._execute(api_commands, timeout=timeout)
  File "/home/pi/.local/lib/python3.5/site-packages/pytradfri/api/libcoap_api.py", line 85, in _execute
    raise RequestTimeout() from None
pytradfri.error.RequestTimeout:
Disconnected
(the ******** is because i removed the official code)
in the log of Domoticz the following message's show up;
2018-07-06 19:07:24.279 (Tradfri) Connected successfully to: 192.168.0.19
2018-07-06 19:07:35.202 PluginSystem: Restarting I/O service thread.
2018-07-06 19:07:35.203 (Tradfri) Device has disconnected
Also the tradfri hub is not working when i run tradfri.tac (probably because the error) , after stop tradfri.tac it the HUB is working again.
I hope some of you can help me whit this problem.
Again, i have a new raspbian en domoticz install and only configured the IKEA Tradfri plugin.
