Logitech Harmony Hub - thread seems to have ended unexpectedly
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
tillo
Target OS: Raspberry Pi
Domoticz version: 3.9030
Re: Logitech Harmony Hub - thread seems to have ended unexpectedly
Post by tillo » Tuesday 24 October 2017 11:30
bump
Raspberry Pi 2 B - Raspbian Jessie + Domoticz + RFXtrxcom 433, House(dimmers, sockets, harmonyhub, Temp / Humidity Sensors, PIR, ESP8266)
Swifty
Post by Swifty » Wednesday 25 October 2017 16:57
Just to chime in that I also see this issue.. I have two Harmony Hubs, my hub that is downstairs (closest to the router) doesn't ever seem to have this issue.
However, my upstairs hub does experience the problem - I do occasionally notice the hub turns red as it misses the wifi connection, but it's usually green!
So this seems to be the plugin process dies when the hub goes offline, and then domoticz reports the thread ended unexpectedly and doesn't try to restart it? - Is there anyone actively working on this plugin?
tillo
Post by tillo » Wednesday 29 November 2017 12:35
Short answer: No!
Users have been complaining about this for some time now. Some have tried to get in touch with the old dev. But no-one have responded.
The next step right now would be to create a ticket in the domoticz git. So if you could do that, that would be great. Or anyone!
gordonb3
Domoticz version: Custom
Post by gordonb3 » Friday 13 April 2018 16:29
Hi, just stumbled over this old thread through Google.
I'm currently doing work on the Harmony Hub connector as it turned out to have a lot of issues with my Hub. Short story: didn't work the way it was supposed to and killed the web UI of Domoticz. I was almost prepared to give the green light on submitting this to the beta when I noticed the message from this topic appearing in my log. At first I thought it was related to what I had done, but after finding this thread I knew it had to be something else. And I think I found the cause, which appears to be a previously unknown API requirement. Currently running final tests and if everything passes I should be able to submit the full rework this weekend.
freakshock
Post by freakshock » Friday 13 April 2018 16:40
Awesome! Please update us when you have news :P
gordonb3
Post by gordonb3 » Friday 13 April 2018 20:03
Looks like I nailed it. Not quite happy with how it responds when the Hub is powered down though (which still causes above error). still some work to do...
gordonb3
Post by gordonb3 » Monday 16 April 2018 21:17
You'll love the new beta ;)
PjotrS
Domoticz version: 2.2284
Post by PjotrS » Tuesday 17 April 2018 10:29
Awesome. Much appreciated!
bxlouis
Domoticz version: 3.5510
Post by bxlouis » Thursday 22 November 2018 17:04
hi,
I'm running the latest stable Domoticz version on RPi (Version: 4.9700) and still experience the same issue with the Harmony Hub.
Here is a log of the errors over the last minutes:
2018-11-22 15:37:30.722 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:38:00.728 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:38:30.733 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:39:00.739 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:39:30.746 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:40:00.914 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:40:30.920 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:41:00.926 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:41:30.931 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:42:00.937 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:42:30.943 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:43:00.948 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:43:30.954 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:44:00.960 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:44:30.966 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:45:01.137 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:45:30.142 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:46:00.148 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:46:30.154 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:47:00.159 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:47:30.165 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:48:00.171 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:48:30.176 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:49:00.182 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:49:30.188 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:50:00.424 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:50:30.430 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:51:00.435 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:51:30.441 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:52:00.447 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:52:30.453 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:53:00.459 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:53:30.465 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:54:00.471 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:54:30.476 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:55:02.187 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:55:30.193 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:56:00.198 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:56:30.204 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:57:00.210 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:57:30.215 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:58:00.220 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:58:30.226 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:59:00.231 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 15:59:30.236 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 16:00:00.489 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 16:00:30.495 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 16:01:00.501 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 16:01:30.506 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
2018-11-22 16:02:00.511 Error: Logitech Harmony Hub hardware (10) thread seems to have ended unexpectedly
When this happens, it is not possible to launch new Activities using Domoticz.
Is there any news on this thread?
Can we expect a fix in a next release?
Thank you very much for your help!
osiris1337
Post by osiris1337 » Sunday 09 December 2018 1:10
hi,
Did you hapen to find a solution? Going crazy here. Log is flooded with errors, activities just stopped working, ... :(
