Airplanes and Domoticz :-)
freijn
Target OS: Raspberry Pi
Post by freijn » Tuesday 21 March 2017 0:18
More then a year ago I "build" my ADS-B receiver on my Raspberry ver. 1 to monitor airplanes flying in my country.
https://flightaware.com/adsb/piaware/build Recently (dec last year)
I started with Domoticz in my house, running on a Rasp ver. 3.
https://domoticz.com/
Now I wrote a Python script to bind the two together. Counting airplanes flying less than 10 km from my house.
Usefull NO! Fun YES !! :-)
krizzz
Re: Airplanes and Domoticz :-)
Post by krizzz » Wednesday 22 March 2017 7:45
Looks like Fun! I see in your counter that on the top is is mentioning 2 planes and in the text within the sensor 5 planes. Is the number 5 the previous count?
freijn
Post by freijn » Monday 27 March 2017 20:58
No :-)
Its total airplanes seen and total airplanes today :-)
Still am testing the script to have it robust.
It is now signalling airplanes in a circle of 20km around my house.
The aim is to count the lifeliner ( Yellow resque Heli ) and the ZXPxx Police heli are flying around above my hometown.
Of course I must get a trigger on my mobile when the do :-) But that is only the next step....
Let me know if you are interested in the (simple ) phyton script. I think I have a good working version soon :-)
phoenixblue
Domoticz version: 3.7392
Post by phoenixblue » Monday 27 March 2017 23:36
Do your receive the ADS-B info from the Internet or with an RTL-SDR stick?
I like to integrate it in my Domoticz system.
scripts on github: Link
assenzuid
Post by assenzuid » Tuesday 28 March 2017 8:32
I'm interested in the script actually.
Kind regards.
freijn wrote:No :-)
freijn
Post by freijn » Tuesday 28 March 2017 23:17
phoenixblue wrote:Do your receive the ADS-B info from the Internet or with an RTL-SDR stick?
I had an old Rasp 1 ( slow ) , so build the receiver with that one and indeed a RTL-SDR stick :
https://nl.flightaware.com/adsb/piaware/build
I can recommend to build a tuned antenna for it as it helps a lot in receiving longer distances.
So my Domoticz is on a SEPARATE Rasp 3 !!! Just to keep things nice, clear and separated :-)
freijn
Post by freijn » Tuesday 28 March 2017 23:19
assenzuid wrote:Hi,
Kind regards.
I will share it here after the weekend. Still need to correct 1 error.
assenzuid
Post by assenzuid » Tuesday 28 March 2017 23:20
Great,
Verstuurd vanaf mijn E6653 met Tapatalk
freijn
Post by freijn » Saturday 01 April 2017 22:18
As promished, here the first working version of my airplane python script.
Copy the code and name it plane.py
The following additional libraries in python are required : json, yaml,math,time,requests
The install command is depending on the OS. Please use google for HowTo.
The following line need modifications !! :
http://192.168.1.155:8080/json.htm?type ... 7&svalue=1
The ip address of your Domoticz and the idx number used for counter.
Please update your Geocoordinates Lonhome and lathome easy to find using google maps.
The # means python comment. As you can see you can filter on plane name and distance, or no filter at all :-).
Any questions please let me know. Any ( positive or negative ) results please share !
Have fun.
Frank
#Frank Reijn's airplane to Domoticz Pyhton script.
# This script is loading the flights json file and print all the objects with the key "flight"
# Additional of  the following libraries in python are required : json, yaml,math,time,requests
# The install command is depending on the OS. Please use google for HowTo.
# Many thanks to Ilaria for helping out here.
import json
import yaml
import math
import time
import requests
#Switch on debug statements
debug =0
Planes=[]
RemovePlanes=[]
planenumber=0
planealreadyfound=0
Dist2Plane=15
lonhome = 4.9402058
lathome = 52.4955744
CurrentList=[]
PreviousList=[]
MyNewPlanes=[]
difference=[]
def distance(lat1, lng1, lat2, lng2):
    #return distance as meter if you want km distance, remove "* 1000"
    radius = 6371 * 1000
    dLat = (lat2-lat1) * math.pi / 180
    dLng = (lng2-lng1) * math.pi / 180
    lat1 = lat1 * math.pi / 180
    lat2 = lat2 * math.pi / 180
    val = math.sin(dLat/2) * math.sin(dLat/2) + math.sin(dLng/2) * math.sin(dLng/2) * math.cos(lat1) * math.cos(lat2)
    ang = 2 * math.atan2(math.sqrt(val), math.sqrt(1-val))
    return radius * ang
#Start main routine
#going into endless loop
while True:
	#Open the file
	#json_data = open('/run/dump1090-fa/aircraft.json').read()
	with open('/run/dump1090-fa/aircraft.json') as f:
		json_data = f.read()
	#Loads the json file
	#json.loads(json_data)
	#Loads the file uisng yaml, that clean up of unecode stuff
	data = yaml.safe_load(json_data)
	list=data["aircraft"]
	#Just print the whole list of dictionaries
	#print(list)
	#search for the planes
	for item in list:
		if 'flight' in item.keys():
			#print "      "
			#print(item['flight'])
			flightname = item['flight']
			#if  flightname.find("KLM") <> -1:
			#print "KLM Gevonden!!!"
			if 'lon' in item.keys():
				lon6=(item['lon'])
				lat6=(item['lat'])
				#print lon6
				#print lat6
				dist= int ( distance(lonhome,lathome,lon6,lat6)/1000)
				if debug:
					print str(dist)+ " Km"
				if dist < Dist2Plane:
					#print str(round(dist/1000))+ " Km"
					# if airplane is in my distance, I put it in CurrentList
					CurrentList.append(flightname)
	if debug:
		print " ####Planes################## "
		print "CurrentList", CurrentList
		print "PreviousList", PreviousList
	difference=set(CurrentList).difference(PreviousList)
	if debug:
		print "difference", difference
	for item in difference:
		if item not in PreviousList:
			MyNewPlanes.append(item)
			if debug:
				print "New Plane found = " + item
			r=requests.get('http://192.168.1.155:8080/json.htm?type=command&param=udevice&idx=87&svalue=1')
		#else:
			#MyNewPlanes.remove(item)
	if debug:
		print "Planes in list= " + str(len(CurrentList))
	#print" Lets sleep for 1 sec....."
	#time.sleep(1)
	if debug:
		print "MyNewPlanes=" , MyNewPlanes
	PreviousList=CurrentList
	CurrentList=[]
	MyNewPlanes=[]
	f.close()
	#sleep 5 sec
	time.sleep(5)
HansieNL
Post by HansieNL » Sunday 02 April 2017 2:57
Great fun project. I got a spare Raspberry Pi, so for a few Euro's I can have a lot of fun.
Thanks for sharing.
Blah blah blah
assenzuid
Post by assenzuid » Sunday 02 April 2017 11:48
Thanks,
I will try implementing it.
freijn wrote:As promished, here the first working version of my airplane python script.
Have fun.
Frank
import json
import yaml
import math
import time
import requests
debug =0
Planes=[]
RemovePlanes=[]
planenumber=0
planealreadyfound=0
Dist2Plane=15
lonhome = 4.9402058
CurrentList=[]
PreviousList=[]
MyNewPlanes=[]
difference=[]
    return radius * ang
#Start main routine
while True:
	#Open the file
	#print(list)
	for item in list:
			#print "      "
				lon6=(item['lon'])
				lat6=(item['lat'])
				#print lon6
				#print lat6
				if debug:
	if debug:
	if debug:
			if debug:
		#else:
	if debug:
	#time.sleep(1)
	if debug:
	CurrentList=[]
	MyNewPlanes=[]
	f.close()
	#sleep 5 sec
	time.sleep(5)
assenzuid
Post by assenzuid » Sunday 02 April 2017 11:50
One remark, Also update the lonhome & lathome settings.
freijn
Post by freijn » Sunday 02 April 2017 17:38
Have fun and please let me know any suggestions of questions ?
If complete and interesting I could make a wiki for it.
I have updated lon and lat home in the previous post. Thanks Assen :-)
assenzuid
Post by assenzuid » Sunday 02 April 2017 21:25
One question, how do you get "vliegtuigen" in the counter?
assenzuid
Post by assenzuid » Sunday 02 April 2017 22:25
For some reason my /etc/rc.local is not running after I reboot my Raspberry PI with PiAware installed on it....
What's the best way to stat this Python script after a reboot automatically?
freijn
Post by freijn » Monday 03 April 2017 9:18
assenzuid wrote:One question, how do you get "vliegtuigen" in the counter?
Assen
Goto the 'utility' or 'overige' page. Select 'modify' or 'aanpassen' on the counter image.
You will find the parameters as the picture below :
assenzuid
Post by assenzuid » Monday 03 April 2017 20:55
That's very easy :roll:
Only thing to fix is that /etc/rc.local is not running after I reboot my Raspberry PI with PiAware
freijn
Post by freijn » Monday 03 April 2017 20:56
So I have added a Resque and Police Heli counter. Fortunately both are not flying around my town every hour. Unfortunately the both counters are declared dead if not heard from in 60 min....
So I have added some additional code as a keep alive task. Calling the same url but now with value ZERO.
new added code only :
#defines
#keep alive timer
tick1=0
#refresh in seconds
refreshtimer=1500
#just after the start of the while loop
if (time.time() - tick1) > refreshtimer:
		if debug:
			print ">>>Refresh URL called<<<"
		# call counter with dummy zero for keep alive ( Sensor red )
		r=requests.get('http://192.168.1.155:8080/json.htm?type=command&param=udevice&idx=87&svalue=0')
		r=requests.get('http://192.168.1.155:8080/json.htm?type=command&param=udevice&idx=98&svalue=0')
		r=requests.get('http://192.168.1.155:8080/json.htm?type=command&param=udevice&idx=99&svalue=0')
		tick1 = time.time()
The full new script
#Frank Reijn's airplane to Domoticz Pyhton script. V1.1
import json
import yaml
import math
import time
import requests
debug =0
Planes=[]
RemovePlanes=[]
planenumber=0
planealreadyfound=0
#distance around your location
Dist2Plane=10
#your location erasy to find with google maps
lonhome = 4.9402058
CurrentList=[]
PreviousList=[]
MyNewPlanes=[]
difference=[]
#keep alive timer
tick1=0
#refresh in seconds
refreshtimer=60
#distance calculator
    return radius * ang
#Start main routine
#get start time in ticks
ticks1=time.time()
while True:
		if debug:
		tick1 = time.time()
	#Open the file
	#print(list)
	for item in list:
			#print "      "
				lon6=(item['lon'])
				lat6=(item['lat'])
				#print lon6
				#print lat6
				if debug:
	if debug:
	if debug:
			if debug:
			if item.find("Life") <> -1:
				#add to lifeliner counter
				r=requests.get('http://192.168.1.155:8080/json.htm?type=command&param=udevice&idx=98&svalue=1')
			if item.find("ZXP") <> -1:
				r=requests.get('http://192.168.1.155:8080/json.htm?type=command&param=udevice&idx=99&svalue=1')
		#else:
	if debug:
	#time.sleep(1)
	if debug:
	CurrentList=[]
	MyNewPlanes=[]
	f.close()
	#sleep 5 sec
	time.sleep(5)
assenzuid
Post by assenzuid » Monday 03 April 2017 21:18
Nice modification / Add-On.
assenzuid
Post by assenzuid » Sunday 09 April 2017 14:51
Everytime Domoticz update (running beta) the feed from PiAwares stops working (I have to restart the script or reboot PiAware).
Is there a solutions to check if the feed is running, if not to restart it agian?
