Generic Denon / Marantz python plugin
FabrizioA
Re: Generic Denon / Marantz python plugin
Post by FabrizioA » Sunday 14 October 2018 13:03
Hi, currently Marantz/Denon plug-in works ok with my Marantz SR5012 but, if I power on my Marantz from domoticz, either main zone and second zone power on.... there’s a way to force only main zone to power on?
Did you have same situation?
Inviato dal mio iPad utilizzando Tapatalk
autopete
Target OS: Raspberry Pi
Post by autopete » Thursday 06 December 2018 22:32
Wonder if anyone can help me with a repeated error message below?
Error: (Marantz Amplifier) Telnet has not responded to 10 pings, terminating connection.
Error: (Marantz Amplifier) Disconnected from: 192.168.1.146:23
I have a Melody Stream M-CR510 and most of the time the plugin works fine, however, maybe 1 in 20 it fails. I use it to turn off the amp before lots of other gear and it if fails I get nasty speaker damaging thumps so reliability is important for me.
I'm not sure of the significance of the error message as I'll also see successful connections as below.
2018-12-06 20:23:31.261 Error: (Marantz Amplifier) Telnet has not responded to 10 pings, terminating connection.
2018-12-06 20:23:31.312 Error: (Marantz Amplifier) Disconnected from: 192.168.1.146:23
2018-12-06 20:23:41.325 (Marantz Amplifier) Connected successfully to: 192.168.1.146:23
2018-12-06 20:23:41.387 (Marantz Amplifier) Update 0:'Off' (Marantz Amplifier - Power)
2018-12-06 20:23:41.390 (Marantz Amplifier) Update 0:'0' (Marantz Amplifier - Main Zone)
2018-12-06 20:23:41.401 (Marantz Amplifier) Update 0:'28' (Marantz Amplifier - Main Volume)
Running on a Pi as below
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 15:24:51
dzVents Version: 2.4.6
Python Version: 3.5.3 (default, Jan 19 2017, 14:11:04) [GCC 6.3.0 20170124]
Thanks to the developer and any ideas much appreciated.
Dnpwwo
Post by Dnpwwo » Friday 07 December 2018 11:55
There are a couple of versions of this plugin kicking around.
Can you supply a link to one you are using?
autopete
Post by autopete » Monday 10 December 2018 0:31
Firstly thanks for replying. Sorry it's a slow reply from me I'll have to work out how to get notifications on update.
I think the URL was https://github.com/dnpwwo/Domoticz-Denon-Plugin and also if I look at the plugin on the the filesystem it matches the source at github with the line plugin key="Denon4306" version="3.2.5".
If there's anything I can do to troubleshoot I'd be keen to try.
Cheers
Pete
Dnpwwo
Post by Dnpwwo » Monday 10 December 2018 1:57
@autopete,
How often does this happen? It looks like a network issue.
If it happens a lot you could turn debugging on to help work out exactly how often much may help pin point the problem.
Every heartbeat (10 seconds) the plugin polls the amplifier for details about status of various components. After receiving no response after 10 heartbeats it disconnects and attempts to reconnect. This gives you a total of around 110 seconds time if the amplifier stops responding before the plugin reconnects.
You could edit the plugin.py file and change line 363 to make the time it waits be less than 10 heartbeats which might make things better but won't address the underlying problem.
autopete
Post by autopete » Tuesday 11 December 2018 0:25
Thanks again for replying.
Yes it happens all the time. I've wired cat 6 cable between the Marantz amp and the Pi executing the plugin with the other problems, maybe its the amp. I've turned on debug and added a trace from the output. If you have time and spot anything odd be great to know.
I'll have a play with self.oustandingPings > 10 and see what happens.
Cheers !
marantz-diagnotics.txt
(12.55 KiB) Downloaded 3 times
Dnpwwo
Post by Dnpwwo » Tuesday 11 December 2018 12:25
@autopete,
I Don't think playing with outstanding pings will make a difference.
My log looks like this:
2018-12-11 21:11:44.323 (Denon) Protocol set to: 'Line'.
2018-12-11 21:11:44.323 (Denon) Transport set to: 'TCP/IP', xxx.xxx.xxx.xxx:23.
2018-12-11 21:11:44.323 (Denon) Connect directive received, action initiated successfully.
2018-12-11 21:11:44.374 (Denon) Connected successfully to: xxx.xxx.xxx.xxx:23
2018-12-11 21:11:44.374 (Denon) Sending 4 bytes of data
2018-12-11 21:11:44.374 (Denon) 50 57 3f 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. PW?.
2018-12-11 21:11:44.424 (Denon) Received 10 bytes of data
2018-12-11 21:11:44.425 (Denon) 50 57 53 54 41 4e 44 42 59 0d .. .. .. .. .. .. .. .. .. .. PWSTANDBY.
2018-12-11 21:11:44.425 (Denon) Received 10 bytes of data
2018-12-11 21:11:44.425 (Denon) 53 53 48 44 50 20 4f 46 46 0d .. .. .. .. .. .. .. .. .. .. SSHDP.OFF.
2018-12-11 21:11:44.425 (Denon) onMessage called with Data: 'PWSTANDBY'
2018-12-11 21:11:44.425 ($Denon - Power) Updating device from 0:'Off' to have values 0:'Off'.
2018-12-11 21:11:44.430 (Denon) Update 0:'Off' ($Denon - Power)
2018-12-11 21:11:44.430 (Denon) Updating device from 0:'0' to have values 0:'0'.
2018-12-11 21:11:44.435 (Denon) Update 0:'0' (Denon)
2018-12-11 21:11:44.435 (Denon - Volume) Updating device from 0:'50' to have values 0:'50'.
2018-12-11 21:11:44.449 (Denon) Update 0:'50' (Denon - Volume)
2018-12-11 21:11:44.449 (Denon - Zone 2) Updating device from 0:'0' to have values 0:'0'.
2018-12-11 21:11:44.456 (Denon) Update 0:'0' (Denon - Zone 2)
2018-12-11 21:11:44.456 (Denon - Volume 2) Updating device from 0:'33' to have values 0:'33'.
2018-12-11 21:11:44.460 (Denon) Update 0:'33' (Denon - Volume 2)
2018-12-11 21:11:44.460 (Denon - Zone 3) Updating device from 0:'0' to have values 0:'0'.
2018-12-11 21:11:44.464 (Denon) Update 0:'0' (Denon - Zone 3)
2018-12-11 21:11:44.465 (Denon - Volume 3) Updating device from 0:'43' to have values 0:'43'.
2018-12-11 21:11:44.472 (Denon) Update 0:'43' (Denon - Volume 3)
2018-12-11 21:11:44.472 (Denon) onMessage called with Data: 'SSHDP OFF'
2018-12-11 21:11:44.518 Status: LUA: Device 'Denon' event, status 'Off'.
2018-12-11 21:11:44.537 Status: LUA: Denon event fired on 'Denon', value 'Off', Lounge Kodi state 'Off', Lounge Radio state 'Off'
2018-12-11 21:11:44.576 Status: LUA: Device 'Denon - Volume' event, status 'Off'.
2018-12-11 21:11:44.605 Status: LUA: Device 'Denon - Zone 2' event, status 'Off'.
2018-12-11 21:11:45.025 (Denon) Sending 4 bytes of data
2018-12-11 21:11:45.025 (Denon) 5a 4d 3f 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ZM?.
2018-12-11 21:11:45.075 (Denon) Received 6 bytes of data
2018-12-11 21:11:45.075 (Denon) 5a 4d 4f 46 46 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. ZMOFF.
2018-12-11 21:11:45.076 (Denon) onMessage called with Data: 'ZMOFF'
2018-12-11 21:11:46.028 (Denon) Sending 4 bytes of data
2018-12-11 21:11:46.028 (Denon) 5a 32 3f 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z2?.
2018-12-11 21:11:46.079 (Denon) Received 6 bytes of data
2018-12-11 21:11:46.079 (Denon) 5a 32 44 56 44 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z2DVD.
2018-12-11 21:11:46.079 (Denon) Received 5 bytes of data
2018-12-11 21:11:46.079 (Denon) 5a 32 33 33 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z233.
2018-12-11 21:11:46.097 (Denon) onMessage called with Data: 'Z2DVD'
2018-12-11 21:11:46.097 (Denon) onMessage called with Data: 'Z233'
2018-12-11 21:11:46.148 (Denon) Received 6 bytes of data
2018-12-11 21:11:46.148 (Denon) 5a 32 4f 46 46 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z2OFF.
2018-12-11 21:11:46.148 (Denon) onMessage called with Data: 'Z2OFF'
2018-12-11 21:11:47.049 (Denon) Sending 4 bytes of data
2018-12-11 21:11:47.050 (Denon) 5a 33 3f 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z3?.
2018-12-11 21:11:47.100 (Denon) Received 6 bytes of data
2018-12-11 21:11:47.100 (Denon) 5a 33 44 56 44 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z3DVD.
2018-12-11 21:11:47.100 (Denon) Received 5 bytes of data
2018-12-11 21:11:47.100 (Denon) 5a 33 34 33 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z343.
2018-12-11 21:11:47.100 (Denon) onMessage called with Data: 'Z3DVD'
2018-12-11 21:11:47.100 (Denon) onMessage called with Data: 'Z343'
2018-12-11 21:11:47.151 (Denon) Received 6 bytes of data
2018-12-11 21:11:47.151 (Denon) 5a 33 4f 46 46 0d .. .. .. .. .. .. .. .. .. .. .. .. .. .. Z3OFF.
2018-12-11 21:11:47.151 (Denon) onMessage called with Data: 'Z3OFF'
with debug on while yours has no message handling at all, even though your debug mask has requested it. After connection the plugin goes through a whole bootstrap process to assess the amplifiers capabilities but yours does not.
One difference is that I use network discovery and you don't but that shouldn't matter.
autopete
Post by autopete » Wednesday 12 December 2018 23:55
Maybe its the amp. I've changed the cable, used another router port. Various desperate attempts at restarting the amp domoticz etc. Also tried with and without discovery (not sure I did this correctly though). Sometimes it connects sometimes not.
For example in the trace below it connects, updates the status then logs the "last response seen n heartbeats ago" message. Very odd!
2018-12-12 21:38:55.373 (Marantz Amplifier) onHeartbeat called, last response seen 0 heartbeats ago.
2018-12-12 21:38:55.373 (Marantz Amplifier) Protocol set to: 'Line'.
2018-12-12 21:38:55.373 (Marantz Amplifier) Transport set to: 'TCP/IP', 192.168.1.104:23.
2018-12-12 21:38:55.373 PluginSystem: Starting I/O service thread.
2018-12-12 21:38:55.373 (Marantz Amplifier) Connect directive received, action initiated successfully.
2018-12-12 21:38:55.424 (Marantz Amplifier) Connected successfully to: 192.168.1.104:23
2018-12-12 21:38:55.424 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:38:55.474 (Marantz Amplifier) Received 10 bytes of data
2018-12-12 21:38:55.474 (Marantz Amplifier) onMessage called with Data: 'PWSTANDBY'
2018-12-12 21:38:55.474 (Marantz Amplifier - Power) Updating device from 0:'Off' to have values 0:'Off'.
2018-12-12 21:38:55.486 (Marantz Amplifier) Update 0:'Off' (Marantz Amplifier - Power)
2018-12-12 21:38:55.486 (Marantz Amplifier - Main Zone) Updating device from 0:'0' to have values 0:'0'.
2018-12-12 21:38:55.491 (Marantz Amplifier) Update 0:'0' (Marantz Amplifier - Main Zone)
2018-12-12 21:38:55.491 (Marantz Amplifier - Main Volume) Updating device from 0:'28' to have values 0:'28'.
2018-12-12 21:38:55.495 (Marantz Amplifier) Update 0:'28' (Marantz Amplifier - Main Volume)
2018-12-12 21:38:56.046 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:38:57.048 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:38:58.000 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:39:05.371 (Marantz Amplifier) onHeartbeat called, last response seen 0 heartbeats ago.
2018-12-12 21:39:05.371 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:39:05.371 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:39:15.349 (Marantz Amplifier) onHeartbeat called, last response seen 1 heartbeats ago.
2018-12-12 21:39:15.349 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:39:15.349 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:39:25.367 (Marantz Amplifier) onHeartbeat called, last response seen 2 heartbeats ago.
2018-12-12 21:39:25.367 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:39:25.367 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:39:35.333 (Marantz Amplifier) onHeartbeat called, last response seen 3 heartbeats ago.
2018-12-12 21:39:35.333 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:39:35.334 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:39:45.349 (Marantz Amplifier) onHeartbeat called, last response seen 4 heartbeats ago.
2018-12-12 21:39:45.349 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:39:45.349 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:39:55.365 (Marantz Amplifier) onHeartbeat called, last response seen 5 heartbeats ago.
2018-12-12 21:39:55.365 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:39:55.365 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:40:05.335 (Marantz Amplifier) onHeartbeat called, last response seen 6 heartbeats ago.
2018-12-12 21:40:05.335 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:40:05.335 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:40:15.354 (Marantz Amplifier) onHeartbeat called, last response seen 7 heartbeats ago.
2018-12-12 21:40:15.354 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:40:15.354 (Marantz Amplifier) Sending 4 bytes of data
2018-12-12 21:40:25.384 (Marantz Amplifier) onHeartbeat called, last response seen 8 heartbeats ago.
2018-12-12 21:40:25.384 (Marantz Amplifier) onHeartbeat: self.lastMessage PW, Sending 'ZM'.
2018-12-12 21:40:25.384 (Marantz Amplifier) Sending 4 bytes of data
