Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Target OS: Raspberry Pi
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by Madgeni » Wednesday 13 June 2018 19:56
Albynokwan wrote:
Wednesday 13 June 2018 19:55
So I'm still trying to find the problem. I have checked and I'm able to reach Domoticz from the Internet using the same port as I have used in my Controlicz profile. I don't have my own ssl certificate, I'm using the builtin from Domoticz, and have always used that. But is it not possible to use this anymore? Because the only problem I can see now is that I have to accept that the certificate isn't trusted, and then I can use the login as usual.
Hello
I have the exact same problem and it's been three days I've been fighting to connect controlicz, if someone can give me a hint of what you've done to solve it ?
Thanks in advance
Sorry to hear that - can you mail me from your Controlicz profile? Thanks
To be fair, Raptor's problem was fixed by upgrading Domoticz
Native Alexa skill and Google app - register at https://www.controlicz.com
Albynokwan
Target OS: OS X
Post by Albynokwan » Wednesday 13 June 2018 20:00
Hello Madgeni, just did.
Thanks for your proposed support
Madgeni
Post by Madgeni » Wednesday 13 June 2018 20:09
email sent :)
Albynokwan
Target OS: OS X
Post by Albynokwan » Wednesday 13 June 2018 20:15
Thanks Madgeni, testing app and will come back for review ;)
Albynokwan
Target OS: OS X
Post by Albynokwan » Thursday 14 June 2018 11:05
Hi again,
reviewed and paypaled.
Thanks again for app and job
Madgeni
Post by Madgeni » Thursday 14 June 2018 11:14
Thank you very much Albynokwan - appreciate it
hayman
Domoticz version: 3.8153
Post by hayman » Thursday 21 June 2018 21:23
hello Madgeni,i'm a very old user to the skill with Alexa few days ago i got Google home,some time when i command to turnoff lights its'tell me skill not online,but when i askd alexa it does it without any probleem ...?
is there something i can do at my side ..?
thanks keep the good work
Madgeni
Post by Madgeni » Thursday 21 June 2018 21:59
Hey Hayman - it's probably me :)
Am working on new functionality, which means some intermittent outages (they should be over now :) )
hayman
Post by hayman » Friday 22 June 2018 11:34
okey thanks friend................
after 20 days we celebrate 1 year yeahhhhhhhhhhhhhh..
should be rewards with paypal ;)
xavierlp
Post by xavierlp » Friday 22 June 2018 20:21
Hello Madgeni
I used Controlicz on Alexa for 10 days now and all is OK. It's a very usefull skill easy to use thanks for you job!
Since I updated the username on the profile page in controlicz to use a specific user for this usage I've got some issues.
From Contolicz I can't see any devices.
So I changed the user name with initial values and I could see devices again :-)
But With Alexa (app or echo) no actions were send.... :-(
So I deleted all devices manuelly , desactivate the skill, Reactivate and since this action I can't see any devices in the app.
If i remove a device in the plan, controlicz is correctly updated.
Thanks for any suggestions
Madgeni
Post by Madgeni » Friday 22 June 2018 20:32
Hi - so just make sure your new user has access to the devices in Domoticz (Edit Users>Set Devices)
xavierlp
Post by xavierlp » Friday 22 June 2018 20:59
Madgeni wrote:Hi - so just make sure your new user has access to the devices in Domoticz (Edit Users>Set Devices)
Thanks a lot for your feedback
I use currently the user with full control : I can see all my devices in controlicz - but nothing in alexa
It was ok ok before with the same user ?
Do I need to reset my account ?
Madgeni
Post by Madgeni » Friday 22 June 2018 21:03
nevermind, just seen your mail :)
credenty
Post by credenty » Saturday 23 June 2018 10:48
Good Morning,
From Amazon are working to bring the Amazon soon to Spain.
Will Controloicz work in Spanish?
Greetings.
Madgeni
Post by Madgeni » Monday 25 June 2018 10:31
Hi all - the 'Test' button is now fully operational - should give you specific errors for each issue.
Lyrex
Post by Lyrex » Friday 29 June 2018 9:09
Hey since weeks i cant use my google home with controlicz (unable to connect). Am i missed anything?
felix63
Domoticz version: 3.8275
Post by felix63 » Friday 29 June 2018 9:13
Just to say I am so happy with Controlicz. It really was the missing link to make a geeky thing into a workable domotica set-up!
Madgeni
Post by Madgeni » Friday 29 June 2018 9:18
Thanks Felix :)
Madgeni
Not good! Mail me from your controlicz profile and i'll take a look
Lyrex
Post by Lyrex » Friday 29 June 2018 9:30
Nevermind: i needed to remove everything and wait a few minutes... its working again but i found a bug wiht alexa an selector switches:
I've got an ceiling fan with 4 levels:
Off - Level
Level 1 - Level 3
When calling: Alexa turn the ceiling fan off i see that the icon is greyed out but it stays on Level 2 for example. I need to say "Alexa set the ceiling fan to 0 percent". Can you work around this?
I think its a good idea to map Off to 0% as this is the selector switch default
Users browsing this forum: No registered users and 7 guests
