switch type garage door
heistje
Domoticz version: ltstbeta
Post by heistje » Monday 13 March 2017 23:41
maybe somebody could help me with this:
I have a garage door that is operated with a push button:
-> push when open: close door
-> push while moving: stop
-> next push after stop: reverse
-> push when closed: open
I installed a Qubino ZMNHBD1 and I'm using one of its contacts as a push button in parallel with the hardware push button.
I'm also using a Finaro binary sensor (FGBS-001 - 2 contacts) to determine if the garage door is open or closed.
In Domoticz I'm using the switch type "push on button" to operate the garage door, (--> ZMNHBD1)
a switch type "On/Off" (Light/Switch) to see when the door is open, (--> FGBS-001 CH1)
and also a switch type "On/Off" "Light/Switch" to see when the door is closed... (--> FGBS-001 CH2)
Works fine but Isn't there a solution where I could work with just one switch type? I mean where all information is integrated in one type?
As you can see in next image I already tried to add the 2 "On/Off" switches as slave devices in the "push on button" and this works,
the button becomes red once the door is open or closed and becomes grey in between the 2
BUT unfortunately I can't see the difference between open and close... both --> red
garage door.JPG (24.27 KiB) Viewed 2312 times
I would really appreciate your ideas/suggestions!.
Thx!
QNAP TS251+ 8GB, Ubuntu Server 16.04 on Virt. Station
RFXtrx433E, Aeotec Z-Stick Gen5, Eth8020
TheeDude
Re: switch type garage door
Post by TheeDude » Thursday 27 April 2017 1:12
This is something I am interested in also!
Tried to do something in Blockly, with a couple of virtual switches, but didn´t have much success.
Have you found a solution?
MYLE
Post by MYLE » Monday 08 May 2017 21:31
I use the blinds icon as I have a magent switch telling me if open / close
Thinking out side the square / garage why not make them hidden switches and use blockly script to change the blinds status remember reading some I think putting a $ in front of the name make it hidden I think
Only been doing this for a month
heistje
Post by heistje » Sunday 14 May 2017 20:46
found this solution:
I'm using a virtual switch (selector --> 'blinds inverted') with an other set of icons (icon for 'open' and one for 'closed')
Below "devices" I found that the Idx of this virtual Switch is 204
I downloaded a garage switch from https://drive.google.com/drive/folders/ ... WdHV1Qxbm8 (unther 'D' you will find a garage door..)
Uploaded them in Domoticz with the help from this: https://www.domoticz.com/wiki/Custom_ic ... binterface
I installed a Fibaro Universal switch which detects if the door is open or closed (electrical contacts).
Below "Edit" from the On/Off switch that detects garage door=open I've put following JSON command by "On action":
"http://ipadresDomoticz:8080/json.htm?type=command&param=switchlight&idx=204&switchcmd=On"
idx204=the idx of the virtual switch.
Below "Edit" from the On/Off switch that detects garage door=closed I've put following JSON command by "On action":
"http://ipadresDomoticz:8080/json.htm?type=command&param=switchlight&idx=204&switchcmd=Off"
Hope this helps..
grtz!
magichew
Post by magichew » Saturday 30 June 2018 11:28
I've read your messages regarding the garage door and I think you and I are trying to achieve the same thing yet I have had no success yet.
I have a Xaiomi MI Home Hub with various different sensors, switches etc. All working well through Domoticz. I have a contact sensor on my Garage Door which functions as expected and separately I have a Sonoff SV unit which opens and closes the door. The Sonoff is set up in Domoticz so that when the button is pressed, 1 second later the button turns off. So one press begins opening, another press stops the door and then the next press will close.
I'm looking for a way of merging the button and the sensor in to one button which can be pressed to open, stop, close and also reports the status of the door.
Any advice?
Users browsing this forum: SteveShaw and 1 guest
