strange error..
R0yk3
Target OS: Raspberry Pi
strange error..
Post by R0yk3 » Friday 10 March 2017 23:42
i get this error:
2017-03-10 22:29:00.288 Error: EventSystem: Lua script error (Blockly), Name: huiskamer_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare number with string
2017-03-10 22:29:00.289 Error: EventSystem: Lua script error (Blockly), Name: huiskamer_2 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare number with string
2017-03-10 22:29:00.289 Error: EventSystem: Lua script error (Blockly), Name: huiskamer_3 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare number with string
2017-03-10 22:29:00.289 Error: EventSystem: Lua script error (Blockly), Name: huiskamer_4 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare string with number
With this script:
http://prntscr.com/eifrn1
Each line apart works, only together i get the error..
Raspberry PI 3, raspbian, ZwaveMe, RFLink
DutchHans
Re: strange error..
Post by DutchHans » Thursday 16 March 2017 16:17
Hi maybe you should have the time between two times... If time ≥ 21.30 and time < 22.00 then...
Hope this helps.
Cheers,Hans
EDsteve
Re: strange error..
Post by EDsteve » Friday 25 May 2018 22:11
The reason is that you can use the "Level(%)" only in a DO statement and not in a IF-statement.
If you want to change that behavior: viewtopic.php?f=62&t=23584
Cheeers
ED
