Moderators: robgeerts, htilburgs
HansieNL
Target OS: Raspberry Pi
Post by HansieNL » Friday 10 August 2018 19:43
1. Settings are only saved when running php.
2. Have you tried config['auto_positioning'] = 0; ? https://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
Blah blah blah
Herman-H
Post by Herman-H » Friday 10 August 2018 20:25
i don't use php so point 1 is clear.
for point 2 i tried auto positioning. same 'currentweather_big','weather not visible.
When i use the data from the original CONFIG_DEFAULT.js of github and my wu key i have the same result.
And that do i don't understand.
HansieNL
Post by HansieNL » Friday 10 August 2018 22:10
@Herman-H: can you try to enlarge the width for the column containing weather block to 5?
Blah blah blah
Herman-H
Post by Herman-H » Friday 10 August 2018 22:49
@ HansieNL, the same, no weather or currentweather_big. Is there a relation between the key of WU and showing this items?
HansieNL
Post by HansieNL » Friday 10 August 2018 23:01
@Herman-H: If the key is not right the item only shows 4 small blocks without info.
Blah blah blah
poudenes
Domoticz version: 3.8993
Post by poudenes » Saturday 11 August 2018 9:29
poudenes wrote:Hi All,
Can someone help me. Volt is ok. Volt as text and value below. But Gas vandaag, Totaal Gas, And the rest are not switched also not the title is showing
// P1 INFO
blocks[23] =    {width: 4, icon: 'fa-bolt', show_lastupdate: false,  hide_data: true, switch: true,   title: 'Watt'    };
blocks[24] =    {width: 4, icon: 'fa-bolt', show_lastupdate: false,  hide_data: true, switch: true,   title: 'Volt'    };
blocks[25] =    {width: 4, icon: 'fa-fire',  show_lastupdate: false,  hide_data: true, switch: true,   title: 'Gas'    };
To bad. Didn't solve this issue yet
Verzonden vanaf mijn iPhone met Tapatalk Pro
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
Herman-H
Post by Herman-H » Saturday 11 August 2018 11:37
@ HansieNL,
Even what your picture shows i don't see.
I loaded now the config.js from github. The only thing what i changed is the ip adres and this is what i see.
With Edge, Firefox and Chrome i see the same results.
commentator
Post by commentator » Saturday 11 August 2018 14:29
Installed it yesterday. All Domoticz items are working.
How to show the default news?
var config = {}
config['domoticz_ip'] = 'myip:myport';
config['user_name'] = 'username';
config['pass_word'] = 'password';
config['default_news_url'] = 'https://cors-anywhere.herokuapp.com/http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 1;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['use_favorites'] = 1;
config['last_update'] = 1;
Herman-H
Post by Herman-H » Saturday 11 August 2018 15:30
@ HansieNL,
Problem solved:
When i loaded this from Rob Geurts config file:
config['wu_api'] = 'a14940b730424939';
config['wu_city'] = 'Eindhoven';
config['wu_name'] = '';
config['wu_country'] = 'NL';
The blocks are visible. Then i changed the key with my own key and all was working.
The problem was that the name of my city was unknown for Wunderground.
Herman-H
Post by Herman-H » Sunday 12 August 2018 18:52
var config = {}
Maybe this can help you, i didn't test it by myself. http://www.domoticz.com/forum/viewtopic ... 20#p127589
commentator
Post by commentator » Sunday 12 August 2018 20:53
nope. still no news
Maybe @robgeerts can explain me how the out of the box newsfeed should be working?
btw it doesn't matter which rss (tried 3 different sites) and also with and without the https://cors-anywhere.herokuapp.com/ part
kiddigital
Domoticz version: 4.9788
Post by kiddigital » Sunday 12 August 2018 21:57
commentator wrote:nope. still no news
How does your blocks definition look like? Do you have the ‘news’ block defined somewhere?
Check https://www.domoticz.com/wiki/Dashticz ... ositioning to see some examples.
Also, check your browser debugger/dev tools/console to see if your browser is even trying to load the newsfeed and if/why it might fail.
One RPi with Domoticz, RFX433e, aeon labs z-wave plus stick GEN5, ha-bridge 5.1.0 for Alexa
commentator
Post by commentator » Sunday 12 August 2018 22:54
I don't have bloks. I'm using the standard from install. As it is default in the setting I expect to see it somewhere without adding extra bloks
kiddigital
Post by kiddigital » Monday 13 August 2018 8:59
commentator wrote:I don't have bloks. I'm using the standard from install. As it is default in the setting I expect to see it somewhere without adding extra bloks
That probably means that you have auto_configure active and that will only show Domoticz items.
If you want other items like news or weather, you need to start defining your own blocks including the ones you would like from Domoticz.
commentator
Post by commentator » Monday 13 August 2018 9:31
tanks, going to try it tonight.
Bit strange a default template with non working items in it
Derik
Post by Derik » Monday 13 August 2018 21:03
Dear All....
Is there perhaps someone that have a option to set the camera's into a nice steady place?
IMG_20180813_205206 2.jpg (38.75 KiB) Viewed 1153 times
Now i cannot set the second radar [ test for my cam ] to a fixed place..
Every time a switch is changing, my board is going crazy...
alarm_guy1
Post by alarm_guy1 » Friday 17 August 2018 4:06
Hi just getting into Dashticz but am struggling, I am a complete newbie.
All I really want at this point is my lounge light on the main screen, I understand that Dashticz should pull from Domoticz anyyhing that is on the dashboard.
unfortunately this appears not to be the case.
I have a password on my domoticz so in the CONFIG.js file I added the following lines
config['domoticz_ip'] = 'http://192.168.2.137:8081';
config['user_name'] = 'domoticz';
config['pass_word'] = 'domoticz';
config['loginEnabled'] = 1;
but I see nothing from Domoticz at all, just the stock screen
Any help appreciated
HansieNL
Post by HansieNL » Friday 17 August 2018 4:44
@alarm_guy1: can you post your complete CONFIG.js as code?
Blah blah blah
alarm_guy1
Post by alarm_guy1 » Friday 17 August 2018 12:14
Right here is my code. it is still very much the original code, I have only changed a few bits that dont work, but my real focus is Domoticz, the other bits are bells and whistles i'm not fussed about.
I have hopefully attached a screen shot of my Domoticz loaded so u can see the URL is correct.
cheers for your help
var config = {}
config['domoticz_ip'] = 'http://xxxxxxxx:xxxxxxxx@192.168.2.137:8081';
config['user_name'] = 'xxxxxxxx';
config['pass_word'] = 'xxxxxxx';
config['loginEnabled'] = 0;
config['auto_positioning'] = 1;
config['app_title'] = 'Home Stuff test ';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['auto_slide_pages'] = 0;
config['language'] = 'en_US';
config['calendarlanguage'] = 'en_US';
config['gm_api'] = 'ChIJ27L0utFs2UcR8HitjVqfz9U';
config['gm_zoomlevel'] = 15;
config['gm_latitude'] = 51.794990;
config['gm_longitude'] = 1.159090;
config['wu_city'] = 'Essex';
config['wu_country'] = 'UK';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 'http://192.168.2.137:6789';
config['spot_clientid'] = '1112f16564cf4f4d93ccbe8b52c58a44';
config['selector_instead_of_buttons'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = 0;
config['settings_icons'] = ["settings", "fullscreen"];
config['shortdate'] = 'D MMM';
config['longdate'] = 'D MMMM YYYY';
config['shorttime'] = 'HH:mm';
config['longtime'] = 'HH:mm:ss';
config['weekday'] = 'dddd';
config['no_rgb'] = 1;
config['standby_call_url'] = '' ;
config['standby_call_url_on_end'] = '' ;
config['hide_off_button'] = 1;
var _HOST_DOMOTICZ = 'http://192.168.2.137:8081';
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'UK', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Heart Radio Colchester","file":"http://media-the.musicradio.com:80/HeartColchesterMP3"},,
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'Keith';
blocks['blocktitle_1']['type'] = 'Keith1';
blocks['blocktitle_1']['title'] = 'Keith 2';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
domoticz ss.jpg (155.03 KiB) Viewed 1031 times
HansieNL
Post by HansieNL » Friday 17 August 2018 18:11
@alarm_guy1: First try a basic CONFIG.js and see if your Domoticz favorites are visible.
var config = {}
From there you can add more functions to your dashboard. See https://www.domoticz.com/wiki/Dashticz_V2 how to do that.
Blah blah blah
Users browsing this forum: dre68 and 0 guests
