Moderators: robgeerts, htilburgs
Herman-H
Post by Herman-H » Friday 10 August 2018 19:19
First of all i will thanks Rob Geerts for this nice piece of software and the community for the samples and tips etc.
I'm a noob with this kind of programs so it was a lot of reading and testing.
But now i have two questions:
1: When i change somthing in the settings menu and will save it it doesn't work.
2: I have 'currentweather_big','weather' in my CONFIG.js but i don't see it again.
I have a key of Weather Underground.
What do i wrong? Any help will appreciate.
CONFIG.js
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'My-IP';
config['wu_api'] = 'My_Key';
config['wu_city'] = 'Hengelo';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['standby_after'] = 10;
/* REMOVE THIS LINE, INCLUDING THIS TEXT IF YOU WANT TO USE THE CODE BELOW, ALS REMOVE THE LAST LINE OF THIS FILE ( the asterisk * with the slash)
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'hengelo/bushalte-bruninkshoek', show_lastupdate:true, provider: '9292-bus', icon: 'bus', width:6, results: 6 }
publictransport.ovinfotrain= { station: 'station-hengelo', show_lastupdate:true, provider: '9292-train', icon: 'train', width:6, results: 6 };
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos',url: 'http://nos.nl'}
buttons.tweakers = {key: 'tweakers', width:12, icon: 'fa-newspaper-o', title: 'Tweakers', newwindow:true, url: 'http://tweakers.net'}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', newwindow:true, url: 'https://gadgets.buienradar.nl/gadget/zo ... &overname=$
//************************************************** 'blocktitle_1' **********************************************************************
//Lampen kamer
blocks[66] = {} //Woonkamer Duo lampen
blocks[66]['width'] = 6;
blocks[67] = {} //Woonkamer L & R naast TV
blocks[67]['width'] = 6;
blocks[345] = {} //Woonkamer staande schemerlamp
blocks[345]['width'] = 6;
blocks[346] = {} //Woonkamer staande schemerlamp lezen
blocks[346]['width'] = 6;
blocks[779] = {} //WC-Raam
blocks[779]['width'] = 6;
//************************************************** 'blocktitle_2' ************************************************************************
blocks[2170] = {} //Temperatuur slaapkamer
blocks[2170]['width'] = 6;
blocks[3268] = {} //Temperatuur zolder
blocks[3268]['width'] = 6;
var blocks = {}
//Block Titles
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['key'] = 'blocktitle_2';
blocks['blocktitle_2']['title'] = 'Temperatuur';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['key'] = 'blocktitle_3';
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Bus en Trein';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['key'] = 'blocktitle_4';
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Info en Weer';
columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',66,67,345,346,779,'blocktitle_2',2170,3268]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_3','currentweather_big','weather',publictransport.ovinfobus,publictransport.ovinfotrain]
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_4','clock','sunrise',buttons.nunl,buttons.nos,buttons.tweakers,buttons.buienradar]
columns[3]['width'] = 4;
//************************************************** 'Standby' ************************************************************************
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
custom.css
CUSTOM CSS FILE
HansieNL
Target OS: Raspberry Pi
Domoticz version: Stable
Post by HansieNL » Friday 10 August 2018 19:43
1. Settings are only saved when running php.
2. Have you tried config['auto_positioning'] = 0; ? https://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
Blah blah blah
Herman-H
Post by Herman-H » Friday 10 August 2018 20:25
i don't use php so point 1 is clear.
for point 2 i tried auto positioning. same 'currentweather_big','weather not visible.
When i use the data from the original CONFIG_DEFAULT.js of github and my wu key i have the same result.
And that do i don't understand.
HansieNL
Post by HansieNL » Friday 10 August 2018 22:10
@Herman-H: can you try to enlarge the width for the column containing weather block to 5?
Blah blah blah
Herman-H
Post by Herman-H » Friday 10 August 2018 22:49
@ HansieNL, the same, no weather or currentweather_big. Is there a relation between the key of WU and showing this items?
HansieNL
Post by HansieNL » Friday 10 August 2018 23:01
@Herman-H: If the key is not right the item only shows 4 small blocks without info.
Blah blah blah
poudenes
Domoticz version: 3.8993
Post by poudenes » Saturday 11 August 2018 9:29
poudenes wrote:Hi All,
Can someone help me. Volt is ok. Volt as text and value below. But Gas vandaag, Totaal Gas, And the rest are not switched also not the title is showing
// P1 INFO
blocks[23] =    {width: 4, icon: 'fa-bolt', show_lastupdate: false,  hide_data: true, switch: true,   title: 'Watt'    };
blocks[24] =    {width: 4, icon: 'fa-bolt', show_lastupdate: false,  hide_data: true, switch: true,   title: 'Volt'    };
blocks[25] =    {width: 4, icon: 'fa-fire',  show_lastupdate: false,  hide_data: true, switch: true,   title: 'Gas'    };
To bad. Didn't solve this issue yet
Verzonden vanaf mijn iPhone met Tapatalk Pro
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
Herman-H
Post by Herman-H » Saturday 11 August 2018 11:37
@ HansieNL,
Even what your picture shows i don't see.
I loaded now the config.js from github. The only thing what i changed is the ip adres and this is what i see.
With Edge, Firefox and Chrome i see the same results.
commentator
Post by commentator » Saturday 11 August 2018 14:29
Installed it yesterday. All Domoticz items are working.
How to show the default news?
var config = {}
config['domoticz_ip'] = 'myip:myport';
config['user_name'] = 'username';
config['pass_word'] = 'password';
config['default_news_url'] = 'https://cors-anywhere.herokuapp.com/http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 1;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['use_favorites'] = 1;
config['last_update'] = 1;
Herman-H
Post by Herman-H » Saturday 11 August 2018 15:30
@ HansieNL,
Problem solved:
When i loaded this from Rob Geurts config file:
config['wu_api'] = 'a14940b730424939';
config['wu_city'] = 'Eindhoven';
config['wu_name'] = '';
The blocks are visible. Then i changed the key with my own key and all was working.
The problem was that the name of my city was unknown for Wunderground.
Herman-H
Post by Herman-H » Sunday 12 August 2018 18:52
var config = {}
Maybe this can help you, i didn't test it by myself. http://www.domoticz.com/forum/viewtopic ... 20#p127589
commentator
Post by commentator » Sunday 12 August 2018 20:53
nope. still no news
Maybe @robgeerts can explain me how the out of the box newsfeed should be working?
btw it doesn't matter which rss (tried 3 different sites) and also with and without the https://cors-anywhere.herokuapp.com/ part
kiddigital
Domoticz version: 4.9788
Post by kiddigital » Sunday 12 August 2018 21:57
commentator wrote:nope. still no news
How does your blocks definition look like? Do you have the ‘news’ block defined somewhere?
Check https://www.domoticz.com/wiki/Dashticz ... ositioning to see some examples.
Also, check your browser debugger/dev tools/console to see if your browser is even trying to load the newsfeed and if/why it might fail.
One RPi with Domoticz, RFX433e, aeon labs z-wave plus stick GEN5, ha-bridge 5.1.0 for Alexa
commentator
Post by commentator » Sunday 12 August 2018 22:54
I don't have bloks. I'm using the standard from install. As it is default in the setting I expect to see it somewhere without adding extra bloks
kiddigital
Post by kiddigital » Monday 13 August 2018 8:59
commentator wrote:I don't have bloks. I'm using the standard from install. As it is default in the setting I expect to see it somewhere without adding extra bloks
That probably means that you have auto_configure active and that will only show Domoticz items.
If you want other items like news or weather, you need to start defining your own blocks including the ones you would like from Domoticz.
commentator
Post by commentator » Monday 13 August 2018 9:31
tanks, going to try it tonight.
Bit strange a default template with non working items in it
Derik
Post by Derik » Monday 13 August 2018 21:03
Dear All....
Is there perhaps someone that have a option to set the camera's into a nice steady place?
IMG_20180813_205206 2.jpg (38.75 KiB) Viewed 96 times
Now i cannot set the second radar [ test for my cam ] to a fixed place..
Every time a switch is changing, my board is going crazy...
