NUT Mini BATTERY SERVICE
All kinds of 'OS' scripts
emme
Target OS: Raspberry Pi
Domoticz version: latest
Post by emme » Monday 27 February 2017 23:19
Thanks to my fellows we finally managed the script for the battery service for NUT mini beacons...
this is something that actually NUTSpace does not provide either (sorry guys, but this is a great goal for us :P :P :P)
here are the specs:
Nut Mini is a simple BLE device.
it does nothing more that its presence AND now we were able to identify the battery service and its value.
Here is how it works:
This script just check the battery and write the value to Domoticz
you have an array to populate with all the datas you need
Because the battery inquiry could drain it, it would be better to run the script once/twice a day (via cron)
in my specific scenario I have a beacon service that check the presence of NUTs... but both script cannot cohexist, so the service must be disabled first if you do not have a service you will be able to skip this part)
Here are the Domoticz requirements:
- String Variable for each NUT where to store the value
- ON/OFF Switch linked to the NUT to check state for continuing (this can be avoided)
- NUT MAC ADDRESS
here is the script:
#!/bin/bash
# SETTING UP PARAMETERS
## DOMOTICZ SETUP (no authentication required, ensure that you have IP in whitelist)
DOMOIP="127.0.0.1"
DOMOPORT="8080"
DAWVAR="/json.htm?type=command&param=updateuservariable&vname=VARIABLENAME&vtype=2&vvalue=VARIABLEVALUE"
DARDEV="/json.htm?type=devices&rid=DEVICEIDX"
DCHECKSTS="1"
#Check status of switches before continuing
#Set to 0 to force all configured NUT
BATTUUID="0x2a19"
BATTAWAYMSG="UNAVAILABLE"
# Creating Main array (MAC Address - Variable Name - Switch Name)
NUTBATT=(
   "00:00:00:00:00:00" "Variabile_Nome_Batteria" "IDX switch ON/OFF"
# Other Parameters
USEBEACONSERVICE="1"
#Set to 0 if you do not have a beaconing serive deamon running
BEACONSERVICENAME="NomeServizioBeacon.service"
HCIINTERFACE="hci0"
function domoWriteVar () {
    URLREQ="http://"$DOMOIP":"$DOMOPORT$DAWVAR
    URLREQ="${URLREQ/VARIABLENAME/${NUTBATT[arrNut+1]}}"
    URLREQ="${URLREQ/VARIABLEVALUE/$1}"
    dzAPIWriteVar=$(curl -s "$URLREQ" )
function domoGetStatus {
    URLREQ="http://"$DOMOIP":"$DOMOPORT$DARDEV
    #echo $URLREQ
    dzAPIStatus="${URLREQ/DEVICEIDX/${NUTBATT[arrNut+2]}}"
# Getting switch status prom Domoticz
    dzDevRAW=$(curl -s "$dzAPIStatus")
    dzDevJSON=$(echo ${dzDevRAW} | jq .result[0].Data)
    dzDevSTATUS=$(echo $dzDevJSON | sed "s/\"//g")
function svcBeacon() {
    if [[ $1 == "stop" ]]; then
        echo "Stopping Beaconing Service"
        sudo systemctl stop ${BEACONSERVICENAME}
    fi
    if [[ $1 == "start" ]]; then
        echo "Starting Beaconing Service"
        sudo systemctl start ${BEACONSERVICENAME}
    fi
function restartHCI () {
    sudo hciconfig ${HCIINTERFACE} down
    sleep 1
    sudo hciconfig ${HCIINTERFACE} up
function getBLEBat (){
    restartHCI
    HANDLE=$(sudo hcitool lecc --random ${NUTBATT[arrNut]} | awk '{print $3}')
    sleep 1
    sudo hcitool ledc $HANDLE
    BATHEX=$(sudo gatttool -t random --char-read --uuid $BATTUUID -b ${NUTBATT[arrNut]} | awk '{print $4}')
    BATDEC=$((0x$BATHEX))
    if [ "$BATDEC" == "0" ]; then
       BATDEC=$BATTAWAYMSG
    fi
    echo "Risultato finale: HEX :"$BATHEX" DEC: "$BATDEC
    domoWriteVar $BATDEC
# BEGINNING MAIN SCRIPT
if [[ $USEBEACONSERVICE == "1" ]]; then
    svcBeacon "stop"
fi
    printf "\n- - - - - - - - - - - - - - -\n"
for arrNut in $(seq 0 3 $((${#NUTBATT[@]} - 1))); do
    if [[ $DCHECKSTS == "1" ]]; then
        domoGetStatus
        echo "Analyzing NUT: "${NUTBATT[arrNut+1]}" Domoticz State: "$dzDevSTATUS
        dzDevSTATUS="On"
    fi
    if [[ $dzDevSTATUS == "On" ]]; then
        echo "Proceeding seeking for Battery Info"
        restartHCI
        getBLEBat
        dzDevSTATUS="Off"
       echo "NUT Unavailable, skipping"
    fi
done
    svcBeacon "start"
fi
hope you will enjoy it! :P
"We always done this way"
deennoo
Re: NUT Mini BATTERY SERVICE
Post by deennoo » Wednesday 01 March 2017 2:10
Great script !
Beacon Presence and battery check can be run on the same time ! just need to get two ble dongle ;-)
Please can you englize a bit your script or change name for the beacon presence script ? NomeServizioBeacon.service ?
how long it takes to get batterie statuts from the nut ?
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
emme
Post by emme » Wednesday 01 March 2017 16:26
using the onboard BT radio on mi PI3 I cannot scan and get UUID ad the same time.
I need to recycle the interface HCI0
More, but I think this is Nut related, you cannot scan from one inferface and query from another....
here's a copy of a much more comprehensive script :P
ciao
M
#!/bin/bash
# NUTSpace NUT Mini Battery Service Inquiry
# Author: MrEmme
# ver.: 1.0
# INSTRUCTION
# This script will gather battery information
# from BLE device NUT Mini
# and update a Domoticz Variable with its value
# Minimal user parameters are required:
DOMOIP="127.0.0.1"   # Domoticz Server IP
DOMOPORT="8080"      # Domoticz Server Port
# DOMOTICZ STATUS INQUIRY
# Set to "1" if you want to check if the NUT switch is on before
#            getting the battery data
# Set to anything else if you DO NOT want to check the status
#        and process all the NUT in the list (could take longer
#        and generate errors due to unavailability
DCHECKSTS="1"
# If a NUT is unaccessible enter the result string
# Otherwise it would be set to 0
# BEACON SERVICE DISCOVERY
# Battery and Beacon cannot coexist at the same time
# if you have a Beacon discovery service running
# this is the right place to identify it and
# disable it while getting Batt information
# Set to "1" if you want to disable the service
# Set to anything else if you DO NOT want to disable the service
# Set the Service name
BEACONSERVICENAME="beaconServiceName.service"
# INTERFACE NAME
# Once stopped the service, BLE interface needs to be resetted
# normally it is hci0
HCIINTERFACE="hci0"
# NUT LIST
# Set the "MAC ADDRESS" "Domoticz Variable Name" "Switch IDX"
# each line is a NUT
# Add as many line as you need
NUTBATT=(
# DO NOT CHANGE ANYTHING BEYOND THIS POINT
BATTUUID="0x2a19"   # UUID for Battery HEX Value
    #echo $URLREQ
    fi
    fi
    sleep 1
    restartHCI
    sleep 1
       BATDEC=$BATTAWAYMSG
    fi
    svcBeacon "stop"
fi
        domoGetStatus
        dzDevSTATUS="On"
    fi
        restartHCI
        getBLEBat
        dzDevSTATUS="Off"
    fi
done
    svcBeacon "start"
fi
emme
Post by emme » Wednesday 30 August 2017 12:57
little short update....
I now used a different approach in contacting BLEs and check their availbility:
I use the result of hcitool lescan to grep the mac of my nuts... (uh oh... :o :o sounds wired... :o :o ) handling a simple boolean if there is or there is not...
I use one script to check presence and gathering the battery data.
Here's how it works:
I have 2 variable for each NUT: presence (Home/Away) and Battery level
and a switch for each person (that owns a Nut)
the script will:
- gather BLE device in the air
- Check the Macs
- Get the related switch status
- Compare presence/switch status and update accordingly
- if the state change from OFF to ON check the battery
here is the script:
#!/bin/bash
DOMOIP="127.0.0.1"
DOMOPORT="8080"
DCHECKSTS="1"
BATTUUID="0x2a19"
# Creating Main array (MAC Address UPPERCASE - Variable Name - Switch Name - NUT Device (variable) Name )
NUTBATT=(
   "XX:XX:XX:XX:XX:XX" "NUT_Name_Batery" "999" "NUT_Name"
   "XX:XX:XX:XX:XX:XX" "NUT_Name_Batery2" "998" "NUT_Name2"
# Other Parameters
USEBEACONSERVICE="0"
BEACONSERVICENAME="ble.service"
HCIINTERFACE="hci0"
BLEDISCOVERY=5   #Timeout for BLE Discovery
BLEDISCFILE="/home/pi/ScanResult.txt"
#    URLREQ="${URLREQ/VARIABLENAME/${NUTBATT[arrNut+1]}}"
    URLREQ="${URLREQ/VARIABLENAME/$2}"
    #echo $URLREQ
    fi
    fi
    sleep 1
    restartHCI
    sleep 1
#    if [ "$BATDEC" == "0" ]; then
#       BATDEC=$BATTAWAYMSG
#    fi
   if [ "$BATDEC" -ne "0" ]; then
       domoWriteVar $BATDEC ${NUTBATT[arrNut+1]}
    fi
function discBLE (){
   restartHCI
   timeout -s SIGINT ${BLEDISCOVERY}s hcitool -i $HCIINTERFACE lescan > $BLEDISCFILE
   restartHCI
function nutLookup (){
   if [ -s $BLEDISCFILE ]; then
      if grep -q "${NUTBATT[arrNut]}" ${BLEDISCFILE}; then
	     printf "== NUT found in BLE Scan!\n"
		 if [[ $dzDevSTATUS == "Off" ]]; then
		    printf "Updating Variable AWAY => HOME\n"
			domoWriteVar "HOME" ${NUTBATT[arrNut+3]}
			getBLEBat
		 fi
	     printf "XX NUT not found in BLE Scan!\n"
		    printf "Updating Variable HOME => AWAY\n"
			domoWriteVar "AWAY" ${NUTBATT[arrNut+3]}
		 fi
	  fi
   fi
discBLE
    svcBeacon "stop"
fi
for arrNut in $(seq 0 4 $((${#NUTBATT[@]} - 1))); do
        domoGetStatus
        echo "Analyzing NUT: "${NUTBATT[arrNut+3]}" Domoticz State: "$dzDevSTATUS
        dzDevSTATUS="On"
    fi
    nutLookup
done
    svcBeacon "start"
fi
it requires jq utility
I also placed the script as a cronjob under ROOT (as pi it does not works :( )
* * * * * sleep 30; /home/pi/script.sh
so it runs every 30 secs
It clould also work as a service placing a loop and a sleep ;)
RedFish
Post by RedFish » Saturday 10 February 2018 15:16
Hi;
For this moment i work with JSON code here =>www.domoticz.com/wiki/Presence_detectio ... _Beacon%29
But for upload battery poucent you're code is very good; but i should know if you're code test presence and battery always or just changed switch when nut change status.
Sorry for my english.....
emme
Post by emme » Sunday 11 February 2018 21:22
the script tests battery only once the first time the nut became available
it means that (for example) during the weened (from friday to monday) you won't get battery test if you don't go out :P :P
RedFish
Post by RedFish » Tuesday 13 February 2018 19:54
Ok; i test this for watch !!
Have you got script for ring the Nut ??
RedFish
Post by RedFish » Tuesday 13 February 2018 21:59
I try you're script but i've got an error:
pi@raspberry:/home/domoticz/scripts $ sudo python test.py
File "test.py", line 34
SyntaxError: invalid syntax
emme
Post by emme » Wednesday 14 February 2018 9:08
that is not a python script but a bash
you should name it .sh, give it +x rights and run it as sudo ./script.sh ;)
Olivrius
Post by Olivrius » Thursday 12 July 2018 11:02
Thank you very much for your script, it's great !!!
I try do use it and i have this following message with an error at the end :
Risultato finale: HEX :64 DEC: 100
./bat_nut_info.sh: ligne 292: erreur de syntaxe : fin de fichier prématurée
Sorry, it's in French, the last line says : Line 292: syntax error: prematured end of file
I don't understand, there is no line 292 in your script. Can you still help me please ?
Raspberry Pi 3 - RFlink - Ardunio - NUT - IR com - Xiaomi
emme
Post by emme » Thursday 12 July 2018 11:28
so.. it runs (you got the first BLE checked) but then there is an error....
line numbers changes if you add/remove BLE config... so....
could you please post line 292?
thanks
ciao
M
P.S.
line 292?!... the script does not arrive to such a line.....
Olivrius
Post by Olivrius » Thursday 12 July 2018 12:13
Hi emme,
Finaly it's OK, i've paste a bad code in the script.
I have this answer :
Résultat final: HEX :64 DEC: 100
So my battery is still a level available of 64%. Isn't it ?
Thank you !!!
emme
Post by emme » Thursday 12 July 2018 13:44
no.. 64 is the BLE HEX returned value
it gets converted to DEC ==> 100
in my opinion based on my experience with NUT that value is not extremely reliable... I don0t know exactely how NUT handle the battery service (NUTSPACE won't deliver API :( )
based on this... I changed the way to handle BLE... and I have discontinued the battery inquiry.... a 3 months reminder to replace the battery is enough
Even if I have seen lower RSSI values when the battery drains.
Olivrius
Post by Olivrius » Thursday 12 July 2018 15:45
OK thank you one more time for your advices.
So, if i understand, in my case, my battery is 100% charged.
emme
Post by emme » Thursday 12 July 2018 15:50
that's correct
pimseb
Post by pimseb » Sunday 23 September 2018 19:34
Hello
I have an error when trying to run the script :
sudo sh battery.sh
battery.sh: 20: battery.sh: Syntax error: "(" unexpected
line 20 corresponds to : NUTBATT=(
What's going on ?
Thank you
emme
Post by emme » Monday 24 September 2018 8:14
if you copy/paste from the browser to the telnel/ssh console on a windows PC you could get some troubles with the CR code....
can you please post few lines above and under line 20?
ciao
M
pimseb
Post by pimseb » Monday 24 September 2018 9:03
I copied it from the browser into my linux terminal (I'm under linux). I've also tried in windows
pi@raspberrypi:~/domoticz $ sh beacon_battery.sh
beacon_battery.sh: 21: beacon_battery.sh: Syntax error: "(" unexpected
Here is my sh file :
BATTUUID="0x2a19"
NUTBATT=(
   "A0:EF:34:0A:81:B0" "Tag_pim" "presence_pim" "NUT_pim"
# Other Parameters
emme
Post by emme » Monday 24 September 2018 9:07
mmmh... probably if you have just one nut, you won't need to split by lines....
tru with
NUTBATT=("A0:EF:34:0A:81:B0" "Tag_pim" "presence_pim" "NUT_pim")
also...
try with:
chmod +x <scriptname.sh>
and then call it using ./<scriptname.sh>
pimseb
Post by pimseb » Monday 24 September 2018 9:17
it now works when I cal l it with ./<scriptname.sh> instead of sudo sh <scriptname.sh> !!
Thank you
Users browsing this forum: echeberri77 and 2 guests
