[RELEASED] Python plugin to control Onkyo receivers
JimmyH1969
Re: [RELEASED] Python plugin to control Onkyo receivers
Post by JimmyH1969 » Tuesday 27 February 2018 18:10
I know, but that's a domotic thingy. The max is 100%, but for a selector switch there should be no limit i think.
dwmw2
Post by dwmw2 » Monday 12 March 2018 16:52
biggles
Target OS: Raspberry Pi
Post by biggles » Monday 30 April 2018 22:03
JimmyH1969 wrote:
Sunday 18 February 2018 16:06
You can move the inputs up and down when you modify the selectorswitch. Moving the desired input up at a level below 100 should do the trick.
Hi Jimmy,
I found something else that is weird and i am unable to find a solution.
If i edit the ONKY Selector switch and i delete the value at the Selector Actions / Action (let say there is a value of 05) then i am unable to put in a new value as it is expecting to start with script of http and i am unable to put in any action value like a number.
Is there a workaround for this ?
Regards,
Biggles.
Varazir
Post by Varazir » Wednesday 04 July 2018 11:29
Any update on this script ?
1x Raspberry PI A with a RaZberry board
1x GreenWave 6 port Power node
1x tellstick
1x Qubino ZMNHOD1 ( controlling a Ikea blinder )
1x ZW075 Smart Switch Gen5
Several nexa/proove devices
Live Long and Prosper \\//_
dwmw2
Post by dwmw2 » Wednesday 04 July 2018 15:57
The 4.9700 stable release was made a week or two ago, containing built-in support for Onkyo amps.
Varazir
Post by Varazir » Monday 09 July 2018 21:09
yes I know, it was in the beta for some time and it works fine but I hate that I can't force connect.
It's hard set to 30 sec.
1x tellstick
dwmw2
Post by dwmw2 » Monday 09 July 2018 21:33
Hm, that's the first time I've spotted that complaint. Why's it a problem? You can connect to the amp even if it's "off"... do you use a hard power switch with it?
It probably isn't hard to fix; I think it sends a multicast when it starts up (and periodically thereafter). But I didn't see this "complaint" until after the stable release happened so it'll be a while before it gets fixed in the next stable release...
Patches welcome :)
Varazir
Post by Varazir » Thursday 12 July 2018 14:56
Patches welcome :)
I turn off and on the power to my amp using my greewave switch. So the build in tries to connect every 30 sec.
So when I turn it on I have to wait up to 30 sec until I can turn it on. I wish I could use a script to force connect when the amp responds to ping.
Turn it on and unmute.
1x tellstick
ronald1977
Post by ronald1977 » Thursday 12 July 2018 23:17
Hi i have now update Domoticz to 4.9700 and I can see more of my Onkyo 609.
But I wish to switch with selector or button from radio broadcast, but I see in the log that he sees it, but there is nothing created in the hardware list.
Must I make a script or is there a way around?
jake
Post by jake » Monday 16 July 2018 10:00
ronald1977 wrote:Hi i have now update Domoticz to 4.9700 and I can see more of my Onkyo 609.
I assume you use the built in version for the Onkyo? That is not the same (topic) as this Python version.
silver323
Post by silver323 » Monday 05 November 2018 13:10
Does somebody know why i get the following in my log:
2018-11-05 12:07:15.562 (Onkyo) Pushing 'onHeartbeatCallback' on to queue
2018-11-05 12:07:15.608 (Onkyo) Processing 'onHeartbeatCallback' message
2018-11-05 12:07:15.608 (Onkyo) Calling message handler 'onHeartbeat'.
2018-11-05 12:07:15.608 (Onkyo) onHeartbeat called
2018-11-05 12:07:15.609 (Onkyo) Checking if discovery data has been received
2018-11-05 12:07:15.709 (Onkyo) Sending UDP discovery packet
2018-11-05 12:07:15.710 (Onkyo) UDP Discovery packet send succesfully
Its repeats over and over. Can't get any devices..
My Onkyo is online.
jake
Post by jake » Wednesday 07 November 2018 13:51
@jorgh, is there still a benefit for using this plugin versus the built in hardware within domoticz?
I use the NR535 receive.
Users browsing this forum: EdwinK and 4 guests
