Yamaha AV Receiver Plugin
Dnpwwo
Target OS: Raspberry Pi
Re: Yamaha AV Receiver Plugin
Post by Dnpwwo » Monday 01 January 2018 23:15
@sion,
Download a copy of SQLiteBrowser and update the database directly (after backing it up obviously :!: :!: :!: )
Go to the "Browse Data" tab, select the Hardware table, set the Enabled field to 0 for the affected plugin and hit Write Changes.
Or you could wait and try the next beta. That has a number of fixes to the plugins and python event system.
sion
Post by sion » Thursday 04 January 2018 13:26
ok,
so i reupgraded to the latest beta of domoticz.
but also upgraded python from 3.4 to 3.4.3 and its all now working perfectly, using zicht's changes all zone 2 features working perfectly to.
Is there a way to select airplay on zone 2?
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
pro2call
Domoticz version: 3.5877
Post by pro2call » Monday 19 February 2018 17:47
This plugin is working good.
is there also an option to combine the HDMI and AV inputs? or make them selectable i dont use all of them and also want to add "NET RADIO" and "Radio".
Please Help
raymond1972
Domoticz version: 4.9796
Post by raymond1972 » Wednesday 28 February 2018 14:06
Hello Thomas,
Great plugin.
Although I miss some options i definitely will use like scenes and radio input stations.
I still get some error in my domotica log.
Could you help me with that?
every now and then i get:
2018-02-28 13:02:40.510 Error: (Yamaha RX-V475) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
Kind regards,
Raymond
HW:Raspberry Pi 3 B, Pi B,Nano w, Aeon Labs Aeotec Gen 5 Z-Wave USB
getdown
Post by getdown » Wednesday 28 February 2018 14:52
raymond1972 wrote:Hello Thomas,
Great plugin.
Kind regards,
Raymond
Do you use beta or stable version of Domoticz ?
Wich version of python is install on your raspberry ?
Try to upgrade python and use the last beta or Domoticz and it should be ok.
Envoyé de mon ONEPLUS A3003 en utilisant Tapatalk
suchar
Post by suchar » Saturday 10 March 2018 23:19
I'm newbie and I'd like ask to help. I create two test buttons "Test tlacitko 1" and "Test tlacitko 2" and I'd like to change the Yamaha Source to "HDMI 1" after click the button.
And I'm not sure if the condition is write correctly. But after I click the button nothing hapend.
Please could anyone help me? Thanks
fennec62
Post by fennec62 » Sunday 11 March 2018 14:18
thanks a lot for you job
I use plugin with RX-V473
But i have error
2018-03-11 13:14:16.529 (rfxcom) Temp + Humidity (Temp ext Devant)
2018-03-11 13:14:19.435 (Yamaha) Calling message handler 'onHeartbeat'.
2018-03-11 13:14:19.435 (Yamaha) onHeartbeat called. Connected: False
2018-03-11 13:14:19.435 (Yamaha) Transport set to: 'TCP/IP', 10.0.0.156:50000.
2018-03-11 13:14:19.435 PluginSystem: Starting I/O service thread.
2018-03-11 13:14:19.435 (Yamaha) Connect directive received, action initiated successfully.
2018-03-11 13:14:19.485 (Yamaha) Calling message handler 'onConnect'.
2018-03-11 13:14:19.485 (Yamaha) onConnect called. Status: 0
2018-03-11 13:14:19.485 (Yamaha) onHeartbeat called. Connected: True
2018-03-11 13:14:19.485 (Yamaha) Sending 13 bytes of data:.
2018-03-11 13:14:19.485 (Yamaha) 40 4d 41 49 4e 3a 50 57 52 3d 3f 0d 0a .. .. .. .. .. .. .. @MAIN:PWR=?..
2018-03-11 13:14:19.485 (Yamaha) 40 4d 41 49 4e 3a 56 4f 4c 3d 3f 0d 0a .. .. .. .. .. .. .. @MAIN:VOL=?..
2018-03-11 13:14:19.485 (Yamaha) 40 4d 41 49 4e 3a 49 4e 50 3d 3f 0d 0a .. .. .. .. .. .. .. @MAIN:INP=?..
2018-03-11 13:14:19.485 (Yamaha) Sending 14 bytes of data:.
2018-03-11 13:14:19.485 (Yamaha) 40 4d 41 49 4e 3a 4d 55 54 45 3d 3f 0d 0a .. .. .. .. .. .. @MAIN:MUTE=?..
2018-03-11 13:14:19.485 (Yamaha) Sending 18 bytes of data:.
2018-03-11 13:14:19.485 (Yamaha) 40 4d 41 49 4e 3a 53 4f 55 4e 44 50 52 47 3d 3f 0d 0a .. .. @MAIN:SOUNDPRG=?..
2018-03-11 13:14:19.535 (Yamaha) Received 12 bytes of data:.
2018-03-11 13:14:19.535 (Yamaha) 40 4d 41 49 4e 3a 50 57 52 3d 4f 6e .. .. .. .. .. .. .. .. @MAIN:PWR=On
2018-03-11 13:14:19.535 (Yamaha) Calling message handler 'onMessage'.
2018-03-11 13:14:19.535 Error: (Yamaha) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2018-03-11 13:14:19.535 (Yamaha) Received 15 bytes of data:.
2018-03-11 13:14:19.535 (Yamaha) 40 4d 41 49 4e 3a 56 4f 4c 3d 2d 34 34 2e 35 .. .. .. .. .. @MAIN:VOL=-44.5
2018-03-11 13:14:19.535 (Yamaha) 40 4d 41 49 4e 3a 49 4e 50 3d 48 44 4d 49 31 .. .. .. .. .. @MAIN:INP=HDMI1
2018-03-11 13:14:19.535 (Yamaha) Received 14 bytes of data:.
2018-03-11 13:14:19.535 (Yamaha) 40 4d 41 49 4e 3a 4d 55 54 45 3d 4f 66 66 .. .. .. .. .. .. @MAIN:MUTE=Off
2018-03-11 13:14:19.536 (Yamaha) Received 25 bytes of data:.
2018-03-11 13:14:19.536 (Yamaha) 40 4d 41 49 4e 3a 53 4f 55 4e 44 50 52 47 3d 35 63 68 20 53 @MAIN:SOUNDPRG=5ch.S
2018-03-11 13:14:19.536 (Yamaha) 74 65 72 65 6f .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. tereo
2018-03-11 13:14:19.536 (Yamaha) Calling message handler 'onMessage'.
2018-03-11 13:14:19.536 Error: (Yamaha) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
On linux with domoticz 3.8153
Thanks for help
assenzuid
Post by assenzuid » Wednesday 14 March 2018 21:46
I have this error.
Transport is not connected, write directive to 'Yamaha connection' ignored.
Running latest beta and installed the plugin with the plugin manager.
assenzuid
Post by assenzuid » Thursday 15 March 2018 12:06
I have an RX-A1010, the plugin works in the basic, but switching between sources isn't working (HDMI 1-7).
How I create a switch to switch between Tuner, or other input?
reboon
Domoticz version: V3.8153
Post by reboon » Sunday 08 April 2018 18:23
Hi all, based on the great plugin from Thomas I changed the script so that it fits my needs. I used large part of his code and the images.
BTW the images you must place in folder /www/images in your domoticz home folder....
That is I wanted to have and have added:
  • 1 input device (per zone)
  • Add my own description to the inputs
  • Add ZONE2
  • Switch PARTY mode on/off
  • Add PARTY/all zone volume control that changes volume in all zones equally
If you run this script as per Thomas instruction it will create 6 devices:
1) Party & status that shows and switches Party mode ON/Off and shows Surround decode
2) Main zone Volume that also switches Main ON/OFF
3) Main zone Input (if you push Off as Input also Main will be switched OFF)
4) Zone2 Volume that also switches Zone2 ON/OFF
5) Zone2 Input (if you push Off as Input also Zone2 will be switched OFF)
6) Party/all zone Volume that also switches all zones ON/OFF
It is working great for me, and again THANKS to Thomas!!
PS attached Python script must be renamed to plugin.py and replace the file of Thomas
PS2 I use the Homebridge to be able to use Homekit from Apple. And these devices allow you to voice control your stereo, how cool is that 'He Siri, increase the volume a little' and 'turn party mode on', although I haven't been able to find a nice integration for the input selection or showing status....
plugin.txt
(16.49 KiB) Downloaded 58 times
StasDemydiuk
Post by StasDemydiuk » Sunday 15 April 2018 17:40
  • Add ZONE2
Great update! Thank you!!!
Just had issues with my latest beta of domoticz - it throws error in onMessage callback.
Additionally I've faced that the plugin is doing continuous updates to domoticz devices when receiver is in Standby mode,
rewriting the same values again and again:
2018-04-15 15:55:08.189 (Yamaha RX-V683) @MAIN:PWR=Standby
2018-04-15 15:55:08.189 (Yamaha RX-V683) @ZONE2:PWR=Standby
2018-04-15 15:55:08.190 (Yamaha RX-V683) @MAIN:SOUNDPRG=Standard
2018-04-15 15:55:08.190 (Yamaha RX-V683) @MAIN:VOL=-48.0
2018-04-15 15:55:08.190 (Yamaha RX-V683) @MAIN:INP=HDMI2
2018-04-15 15:55:08.190 (Yamaha RX-V683) @MAIN:MUTE=Off
2018-04-15 15:55:08.190 (Yamaha RX-V683) @ZONE2:VOL=-36.0
2018-04-15 15:55:08.191 (Yamaha RX-V683) @ZONE2:MUTE=Off
2018-04-15 15:55:08.191 (Yamaha RX-V683) @ZONE2:INP=NET RADIO
2018-04-15 15:55:08.191 (Yamaha RX-V683) @SYS:PARTY=Off
I haven't found your git repository to create a PR, so forked from original one
https://github.com/stas-demydiuk/domoticz-yamaha-plugin
Thank you again for the great update!
DavidSof
Domoticz version: 3.8153
Post by DavidSof » Sunday 22 April 2018 18:38
Hi all, Thomas,
Thanks for the plugin, great idea! I'm trying to use it over a R-N602. First question is how is YNCA different from MusicCast control?
On my side, I also get this message. I'mu using a Synology NAS.
2018-04-22 18:34:40.990 Error: (R-N602_OK) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
Python 3.5.1
Domoticz stable.
Any idea?
Thanks,
David
Dnpwwo
Post by Dnpwwo » Monday 23 April 2018 13:26
you need to run the beta version of Domoticz
DavidSof
Post by DavidSof » Monday 23 April 2018 15:27
Thanks. Just updated to the latest beta version. New errors coming up
2018-04-23 15:24:48.188 (R-N602_OK) Initialized version 2.0.0, author 'thomasvillagers'
2018-04-23 15:24:48.264 Error: (R-N602_OK): Async Read Exception: 104, Connection reset by peer
2018-04-23 15:24:48.293 PluginSystem: Restarting I/O service thread.
2018-04-23 15:24:48.293 Error: (R-N602_OK) 'onMessage' failed 'IndexError':'list index out of range'.
2018-04-23 15:24:48.293 Error: (R-N602_OK) ----> Line 380 in /usr/local/domoticz/var/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-04-23 15:24:48.293 Error: (R-N602_OK) ----> Line 314 in /usr/local/domoticz/var/plugins/yamaha-av-receiver/plugin.py, function onMessage
And it repeats like that on every command. Am I missing something?
DavidSof
Post by DavidSof » Monday 23 April 2018 20:02
Replying to my message above,
I have change the port to 41100, which is the default port for Musiccast (supported by my R-N602), and there is no Python error anymore.
But unfortunately, It still does not work.
In fact I'm not sure this amp can support YNCA. Is there a list somewhere of Yamaha Amp supporting YNCA portocol?
2018-04-23 20:00:39.600 PluginSystem: Starting I/O service thread.
2018-04-23 20:00:39.600 (R-N602_Plugin) Connect directive received, action initiated successfully.
2018-04-23 20:00:39.601 (R-N602_Plugin) Pushing 'onConnectCallback' on to queue
2018-04-23 20:00:39.601 (R-N602_Plugin) Pushing 'DisconnectedEvent' on to queue
2018-04-23 20:00:39.650 (R-N602_Plugin) Processing 'onConnectCallback' message
2018-04-23 20:00:39.650 (R-N602_Plugin) Calling message handler 'onConnect'.
2018-04-23 20:00:39.651 (R-N602_Plugin) onConnect called. Status: 111
2018-04-23 20:00:39.651 (R-N602_Plugin) Processing 'DisconnectedEvent' message
2018-04-23 20:00:39.651 (R-N602_Plugin) Disconnect event received for '192.168.1.131:41100'.
2018-04-23 20:00:39.651 (R-N602_Plugin) Pushing 'onDisconnectCallback' on to queue
2018-04-23 20:00:39.651 (R-N602_Plugin) Processing 'onDisconnectCallback' message
2018-04-23 20:00:39.651 (R-N602_Plugin) Calling message handler 'onDisconnect'.
2018-04-23 20:00:39.651 (R-N602_Plugin) onDisconnect called
2018-04-23 20:00:59.553 (R-N602_Plugin) Pushing 'onHeartbeatCallback' on to queue
2018-04-23 20:00:59.578 (R-N602_Plugin) Processing 'onHeartbeatCallback' message
2018-04-23 20:00:59.578 (R-N602_Plugin) Calling message handler 'onHeartbeat'.
2018-04-23 20:00:59.578 (R-N602_Plugin) onHeartbeat called. Connected: False
2018-04-23 20:01:19.556 (R-N602_Plugin) Pushing 'onHeartbeatCallback' on to queue
2018-04-23 20:01:19.604 (R-N602_Plugin) Processing 'onHeartbeatCallback' message
2018-04-23 20:01:19.604 (R-N602_Plugin) Calling message handler 'onHeartbeat'.
2018-04-23 20:01:19.604 (R-N602_Plugin) onHeartbeat called. Connected: False
2018-04-23 20:01:39.559 (R-N602_Plugin) Pushing 'onHeartbeatCallback' on to queue
2018-04-23 20:01:39.584 (R-N602_Plugin) Processing 'onHeartbeatCallback' message
2018-04-23 20:01:39.584 (R-N602_Plugin) Calling message handler 'onHeartbeat'.
2018-04-23 20:01:39.584 (R-N602_Plugin) onHeartbeat called. Connected: False
2018-04-23 20:01:39.584 (R-N602_Plugin) Pushing 'ConnectDirective' on to queue
2018-04-23 20:01:39.584 (R-N602_Plugin) Processing 'ConnectDirective' message
2018-04-23 20:01:39.584 (R-N602_Plugin) Transport set to: 'TCP/IP', 192.168.1.131:41100.
2018-04-23 20:01:39.584 PluginSystem: Starting I/O service thread.
2018-04-23 20:01:39.584 (R-N602_Plugin) Connect directive received, action initiated successfully.
2018-04-23 20:01:39.585 (R-N602_Plugin) Pushing 'onConnectCallback' on to queue
2018-04-23 20:01:39.585 (R-N602_Plugin) Pushing 'DisconnectedEvent' on to queue
2018-04-23 20:01:39.634 (R-N602_Plugin) Processing 'onConnectCallback' message
2018-04-23 20:01:39.634 (R-N602_Plugin) Calling message handler 'onConnect'.
2018-04-23 20:01:39.634 (R-N602_Plugin) onConnect called. Status: 111
2018-04-23 20:01:39.635 (R-N602_Plugin) Processing 'DisconnectedEvent' message
2018-04-23 20:01:39.635 (R-N602_Plugin) Disconnect event received for '192.168.1.131:41100'.
2018-04-23 20:01:39.635 (R-N602_Plugin) Pushing 'onDisconnectCallback' on to queue
2018-04-23 20:01:39.635 (R-N602_Plugin) Processing 'onDisconnectCallback' message
2018-04-23 20:01:39.635 (R-N602_Plugin) Calling message handler 'onDisconnect'.
2018-04-23 20:01:39.635 (R-N602_Plugin) onDisconnect called
assenzuid
Post by assenzuid » Tuesday 24 April 2018 20:25
Log still filled with
2018-04-24 20:24:15.955 Error: (Yamaha RX-A1010) 'onHeartbeat' failed 'AttributeError':''BasePlugin' object has no attribute 'zones''.
2018-04-24 20:24:15.955 Error: (Yamaha RX-A1010) ----> Line 396 in /home/pi/domoticz/plugins/YamahaPlug/plugin.py, function onHeartbeat
2018-04-24 20:24:15.955 Error: (Yamaha RX-A1010) ----> Line 350 in /home/pi/domoticz/plugins/YamahaPlug/plugin.py, function onHeartbeat
mrkrabs
Domoticz version: 3.9589
Post by mrkrabs » Saturday 21 July 2018 6:42
Hi, thanks for the great plugin! But unfortunately i am having an issue ever since i upgraded to the latest version. When i start the plugin, it floods the log with:
2018-07-21 06:40:18.412 Status: (Yamaha) Started.
2018-07-21 06:40:19.184 Status: (Yamaha) Initialized version 2.0.0, author 'thomasvillagers'
2018-07-21 06:40:19.185 Status: (Yamaha) Entering work loop.
2018-07-21 06:40:19.457 Error: (Yamaha) 'onMessage' failed 'KeyError'.
2018-07-21 06:40:19.457 Error: (Yamaha) ----> Line 380 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.457 Error: (Yamaha) ----> Line 317 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.457 Error: (Yamaha) ----> Line 132 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function handleMessage
2018-07-21 06:40:19.458 Error: (Yamaha) ----> Line 106 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function getMediaDevice
2018-07-21 06:40:19.463 Error: (Yamaha) 'onMessage' failed 'KeyError'.
2018-07-21 06:40:19.463 Error: (Yamaha) ----> Line 380 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.463 Error: (Yamaha) ----> Line 317 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.463 Error: (Yamaha) ----> Line 136 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function handleMessage
2018-07-21 06:40:19.463 Error: (Yamaha) ----> Line 201 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function setVolume
2018-07-21 06:40:19.464 Error: (Yamaha) ----> Line 112 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function getVolumeDevice
2018-07-21 06:40:19.464 Error: (Yamaha) 'onMessage' failed 'KeyError'.
2018-07-21 06:40:19.465 Error: (Yamaha) ----> Line 380 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.465 Error: (Yamaha) ----> Line 317 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.465 Error: (Yamaha) ----> Line 134 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function handleMessage
2018-07-21 06:40:19.465 Error: (Yamaha) ----> Line 216 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function setInput
2018-07-21 06:40:19.466 Error: (Yamaha) ----> Line 109 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function getInputDevice
2018-07-21 06:40:19.466 Error: (Yamaha) 'onMessage' failed 'KeyError'.
2018-07-21 06:40:19.467 Error: (Yamaha) ----> Line 380 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.467 Error: (Yamaha) ----> Line 317 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.467 Error: (Yamaha) ----> Line 139 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function handleMessage
2018-07-21 06:40:19.467 Error: (Yamaha) ----> Line 112 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function getVolumeDevice
2018-07-21 06:40:19.468 Error: (Yamaha) 'onMessage' failed 'KeyError'.
2018-07-21 06:40:19.468 Error: (Yamaha) ----> Line 380 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.468 Error: (Yamaha) ----> Line 317 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function onMessage
2018-07-21 06:40:19.469 Error: (Yamaha) ----> Line 141 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function handleMessage
2018-07-21 06:40:19.469 Error: (Yamaha) ----> Line 204 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function setDspProgram
2018-07-21 06:40:19.469 Error: (Yamaha) ----> Line 115 in '/home/pi/domoticz/plugins/yamaha-av-receiver/plugin.py, function getDspProgramDevice
I have tried completely removing the plugin including the directory and reinstalling but with the same result. Does anyone have any ideas? Thank you.
Fleshi
Post by Fleshi » Wednesday 12 September 2018 21:52
I have the same problem, did you find a solution?
raymond1972
Post by raymond1972 » Friday 12 October 2018 14:36
Great plugin.
Kind regards,
Raymond
Hi getdown,
Seemed like i had to remove the existing yamaha icons.
After that i added my receiver again and it worked.
mrfusion
Post by mrfusion » Thursday 18 October 2018 19:59
Hi everyone and thanks to thomasvillagers for this great plugin.
I did put it in place with my RXV-2067 and all is working great apart one thing.
If the receiver is in "Straight mode" it is impossible to change DSP effect. You have to enable a dsp from the remote before to be able to switch to another one with the plugin.
It is down to yamaha and is kind of weird the way implemented it as "straight" is not in the list of DSP but a apparently in separate function.
@thomas: would it be possible to detect if the amp is in straight mode and switch this mode off to allow the DSP to be appliued then?
DSP status would need to be slightly reworked also to display that the Amp is currently in straight mode when it is the case and no DSP is applied.
So far it display the last DSP used even if in straight mode.
Hopefully this is not me doing something wrong.
This issue is quite annoying because straight mode is the only way to ensure you don't apply some useless DSP on sources already encoded in multi channel.
Users browsing this forum: No registered users and 3 guests
