Python plugin: Kodi
Dnpwwo
Target OS: Raspberry Pi
Re: Python plugin: Kodi
Post by Dnpwwo » Thursday 07 June 2018 14:13
@Brutus,
The python plugin uses a different command set to the native implementation.
I've documented it on github: https://github.com/dnpwwo/Domoticz-Kodi-Plugin
Brutus
Post by Brutus » Thursday 07 June 2018 15:11
That explains a lot :lol: :roll: I need to use "Trigger"
Going to change my scripts tonight.
Thnx for your answer.
1x Intel NUC D54250WYK (Windows 7 x64)
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
19x Fibaro Modules
Brutus
Post by Brutus » Thursday 07 June 2018 18:21
So I changed my scripts. The "Trigger" Favorites works great.
But the Volume doesn't. That command isn't changed:
commandArray['Kodi TV Woonkamer'] = 'Set Volume 100'
The Log says it works:
2018-06-07 18:17:20.530 (Kodi) onCommand called for Unit 1: Parameter 'Set Volume', Level: 100, Connected: True
Using the manual remote control you can change the volume.
2018-06-07 19:00:23.003 (Kodi) Update 2:'80' (Kodi - Volume)
2018-06-07 19:00:23.446 (Kodi) Update 2:'82' (Kodi - Volume)
Am I doing something wrong?
Greetings
19x Fibaro Modules
Dnpwwo
Post by Dnpwwo » Friday 08 June 2018 5:20
@Brutus,
You are sending the command to the wrong device. The plugin creates 4 devices , one of them is the 'Volume' device (Unit #3). Assuming ''Kodi TV Woonkamer" is what you named the hardware then try:
commandArray['Kodi TV Woonkamer - Volume'] = 'Set Volume 100'
If you renamed the 'Volume' device to something else you will obviously need to use its new name
You should see some thing like this in the log:
2018-06-07 18:17:20.530 (Kodi) onCommand called for Unit 3: Parameter 'Set Volume', Level: 100, Connected: True
Brutus
Post by Brutus » Friday 08 June 2018 8:48
@Dnpwwo
That makes sense but still nothing changes:
Command:
commandArray[1]={['Kodi - Volume'] = 'Set Volume 75'}
Log:
2018-06-08 08:41:50.148 (Kodi) onCommand called for Unit 3: Parameter 'Set Volume', Level: 75, Connected: True
Devices:
19x Fibaro Modules
jake
Post by jake » Friday 15 June 2018 22:52
@Dnpwwo:
Have you had time to look into my 'crash log' o Domoticz after the Kodi plugin didn't find Kodi for a second?
jake wrote:I am running the last version of the Kodi plugin, 2.5.6
Today my Domoticz crashed: these are the last lines in the log:
First:
(Kodi Woonkamer) Device has disconnected
(Kodi Woonkamer) Update 9:'Screensaver' (Kodi Woonkamer - Status)
(Kodi Woonkamer) Update 20:'20' (Kodi Woonkamer - Source)
(Kodi Woonkamer) Update 2:'100' (Kodi Woonkamer - Volume)
(Kodi Woonkamer) Update 0:'0' (Kodi Woonkamer - Playing)
then a couple seconds later:
Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to 'onHeartbeat:9090'
(Kodi Woonkamer) Connect directive received, action initiation failed.
Domoticz received fatal signal 11 !...
/home/pi/domoticz/domoticz() [0x2522b8]
/home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x252370]
/lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76cb3180]
The weird thing is that nobody used/started Kodi at all today. Kodi is running fine on it's own pi as well.
A restart of Domoticz got things rolling again, but a plugin crashing the whole setup wasn't what I had in mind today ;-)
jake
Post by jake » Friday 15 June 2018 23:00
@Dnpwwo
You introduced the nice 'Rewind' feature that I use every time a Kodi video or audio starts while the receiver is still off.
I put the stream on 'pause', start/boot the receiver and rewind the playing stream, not to miss the start.
This works fine for 'Audio' (it rewinds and starts playing from 0.00), but 'Video' always keeps paused. Both 'audio' and 'video' trigger the same log registration, but for 'video' I always manually have to hit 'play' again (it also hasn't rewinded to 0:00)
2018-06-15 22:43:17.073 (Kodi Woonkamer) onCommand called for Unit 4: Parameter 'Rewind', Level: 0, Connected: True
Could it be something in the plugin that doesn't properly rewind 'video', that it differs from 'Audio'?
Dnpwwo
Post by Dnpwwo » Saturday 16 June 2018 6:10
@jake,
Theoretically it should work for every media type, the decription of the Kodi method is "Seek through the playing item" for the active player. The rewind method just does a seek to "0" which should be pretty robust in theory so I'm surprised you are having issues.
A couple of questions/suggestions:
  • One potential difference between audio and video is often duration. Could you try a short video (song length) or long audio (movie length) stream to see if stream length is a factor?
  • Does seeking in general work on your video streams using the "Playing" device?
  • You could try changing line 426 in plugin.py to be
                        self.KodiConn.Send('{"jsonrpc":"2.0","method":"Player.Seek","params":{"playerid":' + str(self.playerID) + ',"value":{ "hours":0, "minutes":0, "seconds":0, "milliseconds":0}}}')
    to move from a percentage based rewind to a time based one. (I haven't tried this and the doco is far from clear so it may be incorrect)
jake
Post by jake » Saturday 16 June 2018 21:11
@Dpnwwo
I don't have a long audio and short video at hand.
Shuffling around during a video with the 'playing' device works fine, backwards, forward, no problem
I updated line 426 with the revised code, but the behaviour stays the same
The rewinding action for video is executed partly, because it does rewind the video to 0:00. It only doesn't start to play.
It doesn't make a difference whether I start a local video file or a video stream from an add-on like youtube or 'uitzending gemist', the Dutch replay service from the national television.
Anyhow, since I saw that the video file was properly rewinded, I added a 'Play' command with a 1 second delay (dzVents) to the rewind command. This works fine for video and doesn't seem to hurt (stutter) for audio.
poudenes
Domoticz version: 3.8993
Post by poudenes » Monday 18 June 2018 17:49
Hi All,
I get this error sometimes and then a Signal 11 error:
2018-06-18 16:59:02.375  Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to 'onHeartbeat:9090'
2018-06-18 16:59:02.375  (Kodi) Connect directive received, action initiation failed.
2018-06-18 16:59:02.376  Error: (Kodi) 'onConnect' failed 'AttributeError':''str' object has no attribute 'Address''.
2018-06-18 16:59:02.376  Error: Domoticz received fatal signal 11 !...
2018-06-18 16:59:02.379  Error:   /home/pi/domoticz/domoticz() [0x25458c]
2018-06-18 16:59:02.379  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x254644]
2018-06-18 16:59:02.379  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c0a6b0]
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
jake
Post by jake » Monday 18 June 2018 17:53
Last night my domoticz crashed again on the same symptoms with the Kodi plugin. I have already put the "time out of lost devices" on 'false' before this crash.
jake
Post by jake » Monday 18 June 2018 23:53
Tonight domoticz crashed again on Kodi. It is really a pity that the whole system goes down on a hiccup in a single plugin. In winter time I am running a virtual thermostat from domoticz. Downtime has effects by then :). (on the WAF for sure)
In the meantime I now enabled all debugging on the Kodi plugin to have a better record at the next crash.
