Xiaomi Air Purifier 2
remb0
Target OS: Raspberry Pi
Re: Xiaomi Air Purifier 2
Post by remb0 » Thursday 08 March 2018 18:36
I move this great work to the right forum: python
All Domoticz compatible products at shop: https://www.domoticz.com/wiki/Compatibl ... n_gearbest
DAVIZINHO
Post by DAVIZINHO » Thursday 08 March 2018 21:33
kofec wrote:
Thursday 08 March 2018 16:57
If you want you can try the script 'MyAir.py" from https://github.com/kofec/domoticz-AirPurifier
e.g:
pi@raspberrypi:~/domoticz/plugins/domoticz-AirPurifier $ ./MyAir.py 192.168.1.40 933c4c22df26adaec86d6fd788f5af72
<AirPurifierStatus power=on, aqi=9,average_aqi=8,temperature=21.1, humidity=31%,mode=OperationMode.Auto,led=True,led_brightness=LedBrightness.Bright,buzzer=True, child_lock=False,favorite_level=10,filter_life_remaining=53, filter_hours_used=1614, use_time=7632371, purify_volume=77517, motor_speed=355>
Great!!! works fine. thanks a lot!
AiAmA
Post by AiAmA » Saturday 10 March 2018 18:26
kofec wrote:
Friday 02 February 2018 15:55
I have created a plugin: https://github.com/kofec/domoticz-AirPurifier
Nice plugin, thanks! I'm having a little hiccup though when
./MyAir.py 192.168.1.129 7d5474e308cf13f359373fd1c2b0e676 --debug
it returns
Namespace(IPaddress='192.168.1.129', debug=True, favoriteLevel=None, mode=None, power=None, token='7d5474e308cf13f359373fd1c2b0e676')
File "./MyAir.py", line 64, in <module>
print(MyAir.status())
File "/home/pi/.local/lib/python3.5/site-packages/miio/airpurifier.py", line 174, in __repr__
self.led_brightness,
File "/home/pi/.local/lib/python3.5/site-packages/miio/airpurifier.py", line 105, in led_brightness
return LedBrightness(self.data["bright"])
File "/usr/lib/python3.5/enum.py", line 241, in __call__
return cls.__new__(cls, value)
File "/usr/lib/python3.5/enum.py", line 476, in __new__
raise ValueError("%r is not a valid %s" % (value, cls.__name__))
ValueError: 9 is not a valid LedBrightness
And the domoticz log shows
2018-03-10 17:09:04.849 Error: (AirPurifier) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-AirPurifier/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-03-10 17:09:04.849 Error: (Mari Puri) Module Import failed, exception: 'ImportError'
2018-03-10 17:09:04.849 Error: (Mari Puri) Module Import failed: ' Name: miio'
2018-03-10 17:09:04.849 Error: (Mari Puri) Error Line details not available.
2018-03-10 17:10:00.421 Error: Mari Puri hardware (6) thread seems to have ended unexpectedly
:shock: :shock: :shock: :shock:
kofec
Post by kofec » Tuesday 27 March 2018 22:45
There was an issue in library python-miio
please install the latest version:
pip3 install -U python-miio
mgrom
Post by mgrom » Saturday 07 April 2018 8:24
MyAir.py is working like a charm, so I have python-miio installed, but the plugin is not loading correctly in domoticz:
2018-04-07 08:15:46.682 Error: (AirPurifier) failed to load 'plugin.py', Python Path used was '/home/osmc/domoticz/plugins/xiaomi-purifier/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-04-07 08:15:46.682 Error: (Purifier) Module Import failed, exception: 'ImportError'
2018-04-07 08:15:46.682 Error: (Purifier) Module Import failed: ' Name: miio'
2018-04-07 08:15:46.682 Error: (Purifier) Error Line details not available.
I think that this could be related to python path used, because pip3 install -U installs package in ~/.local/ but this path is not in the list from log:
Can you help me with this?
EDIT:
I've changed one of the lines to:
pathOfPackages = '/home/osmc/.local/lib/python3.5/site-packages'
And now it seems that the package is recognized, but.... I've got bigger problem. Domoticz crashes with:
2018-04-07 08:56:12.146  Error: Domoticz received fatal signal 11 !...
2018-04-07 08:56:12.148  Error:   /home/osmc/domoticz/domoticz() [0x24f04c]
2018-04-07 08:56:12.148  Error:   /home/osmc/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x24f104]
2018-04-07 08:56:12.148  Error:   /lib/arm-linux-gnueabihf/libc.so.6(+0x24fd0) [0x76c66fd0]
mgrom
Post by mgrom » Wednesday 11 April 2018 10:13
Ok, I've finally compiled domoticz from source and it's working :)
deennoo
Post by deennoo » Wednesday 30 May 2018 23:55
ben53252642 wrote:
Wednesday 18 January 2017 19:55
8) For those who want to load the Temperature, Humidity and Aqi (pm2.5 estimate) into Domoticz sensors, below is a updatedomoticz.sh bash script:
#!/bin/bash
while true; do
# Get the data
data=$(node airpurifier.js 192.168.0.240 status)
# Sort it
temperature=$(echo "$data" | grep "temperature" | sed -e s/[^0-9.]//g)
humidity=$(echo "$data" | grep "humidity" | sed -e s/[^0-9.%]//g)
aqi=$(echo "$data" | grep "aqi" | sed -e s/[^0-9.]//g)
# Load it into Domoticz
curl -s "http://USERNAME:PASSWORD@192.168.0.5/json.htm?type=command&param=udevice&idx=607&nvalue=0&svalue=${temperature};${humidity};0"
curl -s "http://USERNAME:PASSWORD@192.168.0.5/json.htm?type=command&param=udevice&idx=599&svalue=${aqi}"
sleep 60
done
I need your help for Xiaomi pm2.5 sensor; The Python Plugin doesn't work @ home.
I prefere your solution
i have modify your airpurifier.js for the pm2.5 sensor and result is :
{ power: true, aqi: 14, batteryLevel: 100, charging: true }
Of course i juste need aqi value
using
this give me the batterie level to = 14100, can you help me ?
Rfxtrxe / RFLink / Milight / Yeelight / ESP8266 / MQTT / BLE
http://domo-attitude.fr
DAVIZINHO
Post by DAVIZINHO » Thursday 31 May 2018 0:03
for aqi i use this:
aqi=$(echo "$data" | grep -Po ' aqi=\K[^,]+')
marafado88
Post by marafado88 » Sunday 10 June 2018 22:37
I have received tons of warnings at step 2) and 3) :( :
2) Install miIO Device Library: npm install --save miio
npm WARN engine miio@0.15.6: wanted: {"node":">=6.6.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine chalk@2.4.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine abstract-things@0.9.0: wanted: {"node":">=6.6.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine tinkerhub-discovery@0.3.1: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine supports-color@5.4.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine ansi-styles@3.2.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine has-flag@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine find-up@2.1.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine os-locale@2.1.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine string-width@2.1.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine locate-path@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine dwaal@0.1.4: wanted: {"node":">=6.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine execa@0.7.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine mem@1.1.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine strip-ansi@4.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine camelcase@4.1.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine p-locate@2.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine path-exists@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine ansi-regex@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine mimic-fn@1.2.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine p-finally@1.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine npm-run-path@2.0.2: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine get-stream@3.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine p-limit@1.3.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine path-key@2.0.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine p-try@1.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
3) Install miio command line utility: npm install -g miio
and in the end i was unable to run 4):
4) Run this command to discover and sync the key from your Air Purifier: miio --discover --sync
I have run all of those commands at root, who is the same user running domoticz.
