Update RFXtrx433Ext firmware
Minglarn
Target OS: Raspberry Pi
Domoticz version: v3.8153
Post by Minglarn » Monday 09 January 2017 23:37
Hi!
Just noticed that there is a new FW for the RFX.
Downloaded the latest FW and see a lot of HEX files inside the zip archive.
RFXtrx433_Ext_251.hex
RFXtrx433_Ext_1001.hex
and last one is:
RFXtrx433_Ext_1012.hex.
Which one sould I use?
Domoticz report that my FW is:
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: 249
Is the 251.hex proper one or is it 1012.hex the one I should use?
b_weijenberg
Re: Update RFXtrx433Ext firmware
Post by b_weijenberg » Monday 09 January 2017 23:53
Update firmware only if there is a need for.
Check the firmware history file which is in the firmware zip files or http://blog.rfxcom.com/
RFXtrx433, RFXtrx433E
Minglarn
Post by Minglarn » Tuesday 10 January 2017 0:45
So easy... Thanks!
As I can see, the 3 digit FW version is abandoned with FW release 433_1001 18-02-2016
And from 1001 and on its 4 digits. ..
Again, thanks.
kevster
Post by kevster » Friday 13 January 2017 22:02
I have one of these as well. What is the difference between an Ext and Ext2 model ? Mine is marked as a batch 1016 I think......
b_weijenberg
Post by b_weijenberg » Friday 13 January 2017 22:39
See chapter 2.2.2. in the RFXtrx User Guide for the list of supported protocols in each firmware type.
kevster
Post by kevster » Saturday 14 January 2017 21:09
thanks for the reply......
My question is however how do you know what hardware type you have..... i mean mine is three months old but it says nothing on it to make it clear.
b_weijenberg
Post by b_weijenberg » Saturday 14 January 2017 22:43
See the label on the bottom of the RFXtrx433E
Users browsing this forum: airfish and 1 guest
