Telldus
Melotron
Target OS: Raspberry Pi
Telldus
Postby Melotron » Sunday 08 January 2017 13:39
I'm running Domoticz and tdtool on a Raspberry B (256MB) with a USB-connected Tellstick (original).
I've gotten the basic functionality on turning the switches on and off with scripts.
But I have 3 dimable lamps with and nexa script to dim them for OFF, 20, 40, 60, 80 and ON will leave me with 15 virtual switches and for 3 lamps.
Setting up a few scenarios with them on dim for tv and night will be a hassle.
Are there any way to get native support for Tellstick original and duo in Domoticz
Or should I invest in an RFXCOM transceiver and will they work with my current Nexa switches?
I really like on what you can do with Domoticz and want to use it as much as possible =)
Regards Magnus Svensson
Minglarn
Re: Telldus
Postby Minglarn » Sunday 08 January 2017 18:25
Hej Magnus! =)
The NEXA switches work out from the box with RFX433E. I'm currently using dimmers and NEXA/ANSLUT switches without any issues.
Regarding the Tellstick DUO... Invest in a RFX433E if possible. Much better and greater support.
Melotron
Re: Telldus
Postby Melotron » Monday 09 January 2017 0:18
Thanks alot :-)
I haven't seen them in any store and the ones that I've found on eBay are only sellers will less then 200 feedback.
Where did you get hold of yours?
I'm starting to get hang of the system now and I can say that it's truly remarkable. So I want to continue to use it and that means to invest in an rfxcom :-)
Minglarn
Re: Telldus
Postby Minglarn » Monday 09 January 2017 0:40
Here you go: https://www.m.nu/tellstick-rfxtrx/rfxtr ... ransceiver
Fast and a very good store. But dont browse to much as you will get addicted.. I promise :)
Melotron
Re: Telldus
Postby Melotron » Monday 09 January 2017 11:18
Thanks again =)
Just placed an order on the transceiver, but I had to just brows a little. So much good things there =)
Guess its time to put in an order for alot of over time =)
Minglarn
Re: Telldus
Postby Minglarn » Monday 09 January 2017 23:14
You're welcome!
Hope you'll enjoy it as much as I do...
Btw, here is the perfect installations guide for the RFX433...
http://www.vesternet.com/resources/appl ... HP9AxvhCUk
Melotron
Re: Telldus
Postby Melotron » Wednesday 11 January 2017 22:13
Thanks alot.
It's installed and working now =)
It feels wonderful to be able to dim the lights now.
Next up are to get it to read the nexa PIR and order an led stripe dimmer =)
Then go to work on getting order on my events and start learning LUA LOL
Return to “General Discussion”
