Remeha eTwist
Jaomrodri
Target OS: Raspberry Pi
Remeha eTwist
Post by Jaomrodri » Tuesday 03 January 2017 11:41
Is there anyway to connect domoticz the Remeha eTwist thermostat?
Or will it be in the near future?
https://www.remeha.nl/consument/producten/etwist.htm
Thanks in advance.
manjh
Domoticz version: 3.8153
Re: Remeha eTwist
Post by manjh » Tuesday 03 January 2017 12:31
They say it is OpenTherm compatible. Has to be, otherwise they could never claim that it will work with all heaters in their program.
So if you use the OTGW at this moment, you should be OK.
Having said that, I don't know how their gateway will work, there is no information available . I guess we'll have to wait for the first actual user and see how it can connect to Domoticz...
Hans
dynasticorpheus
Domoticz version: 2.3295
Re: Remeha eTwist
Post by dynasticorpheus » Tuesday 03 January 2017 19:08
Jaomrodri wrote:Is there anyway to connect domoticz the Remeha eTwist thermostat?
Thanks in advance.
Since there is no public API available I decompiled the android APK trying to figure out how we can get the information exposed as available in the app. Simply using MITMPROXY is not working as they use certificate pinning in combination with websockets. (so no simple HTTP API)
So far I am able to retrieve gas usage but only because this is the only thing not done via websockets. Will keep you posted of my findings but so far not succcesfull in either disabling the pinning or adding the mitmproxy certificate to the app. (I am however not really an expert so still learning as I am trying to figure this one out)
Jaomrodri
Re: Remeha eTwist
Post by Jaomrodri » Wednesday 04 January 2017 10:11
Thanks in advance.
Thanks. I hope that this will work in the near future. i have one since a few weeks and must say that it works very fine.
dynasticorpheus
Re: Remeha eTwist
Post by dynasticorpheus » Monday 27 February 2017 19:51
No ETA but did get confirmation from Remeha on twitter they are planning to create a public API and/or web based solution for the eTwist.
Jaomrodri
Re: Remeha eTwist
Post by Jaomrodri » Thursday 09 March 2017 11:24
dynasticorpheus wrote:No ETA but did get confirmation from Remeha on twitter they are planning to create a public API and/or web based solution for the eTwist.
Thanks for your input. we'll keep waiting!! ;)
ESFnl
Domoticz version: 3.4834
Re: Remeha eTwist
Post by ESFnl » Friday 06 October 2017 23:37
Any progress in this field? I did receive an eTwist from a friend and was in doubt to connect or not. Google still can't find the API :(
ESFnl
Re: Remeha eTwist
Post by ESFnl » Thursday 12 October 2017 18:54
Just received a disappointing reply from the Remeha service & after sales department:
Beste Erik,
Tot op heden is er nog helemaal niks bekend over een eventuele API t.b.v de eTwist thermostaat.
Zo doende kan ik ook nog niks melden over de status hier van op dit moment.
Met vriendelijke groet / Best regards,
Service & After Sales
Remeha
Remeha B.V.
Marchantstraat 55, 7332 AZ Apeldoorn
P.O. Box 32, 7300 AA Apeldoorn T:
E: service@remeha.nl
remeha.nl
Freely translated: currently nothing is known about the eTwist API.
They don't give me the impression they're working on it :(
manjh
Re: Remeha eTwist
Post by manjh » Monday 04 December 2017 23:54
OK, so Domoticz cannot connect directly to the eTwist. But there is still the wired connection between the eTwist and the boiler.
Did anyone try to put an OTGW on that link? (OTGW = OpenTherm GateWay).
I've used it on a Remeha Calenta/iSense combination, works great.
This means the Remeha "speaks" rather pure OpenTherm, I think.
Will it work on a Remeha Tzerra/eTwist? Any experience?
If this works, it means Domoticz has access to most of the boiler settings, including room temperature setting.
What won't work is controlling the clock thermostat settings from Domoticz.
Hans
manjh
Re: Remeha eTwist
Post by manjh » Thursday 07 December 2017 1:23
Does anyone know how "clean" the OpenTherm dialect of the eTwist is?
Hans
dynasticorpheus
Re: Remeha eTwist
Post by dynasticorpheus » Sunday 18 March 2018 19:46
DeBaat
Domoticz version: V3.8153
Re: Remeha eTwist
Post by DeBaat » Sunday 01 April 2018 12:07
Hai,
I've got a Remeha Tzerra in combination with a iSenseRF / iBase.
Can this be controlled via Domoticz?
Any suggestions on how to achieve this?
gizmocuz
Re: Remeha eTwist
Post by gizmocuz » Sunday 01 April 2018 12:17
Its compatible with opentherm, so use an opentherm gateway ?
DeBaat
Re: Remeha eTwist
Post by DeBaat » Sunday 01 April 2018 14:00
The manual describes two types iSense:
• iSense OpenTherm
• iSense RF (wireless), in combination with iBase (basisstation) RF-zender
I have the latter, so probably no OpenTherm?
manjh
Re: Remeha eTwist
Post by manjh » Monday 14 May 2018 18:04
• iSense OpenTherm
I would expect that the iBase is connected to the boiler with a wire, and that the protocol on that wire would be OpenTherm... Just guessing, but I would gamble on an OTGW unit between the boiler and the iBase. That would give you access to all OpenTherm values, but it would not touch any clock program in the thermostat.
I use an iSense myself, with an OTGW on the wire to the boiler. Whenever I go on vacation, I set the vacation program in the iSense. When I return home early, I can simple change the base temperature via Domoticz.
Hans
DeBaat
Re: Remeha eTwist
Post by DeBaat » Monday 14 May 2018 23:05
Hai manjh,
Thanks for this reply.
Can you tell me which OTGW you have installed?
And how you have wired it?
I'm reasonably with software but hardware...
Thanks again.
manjh
Re: Remeha eTwist
Post by manjh » Tuesday 15 May 2018 12:45
Hai manjh,
Thanks again.
I got the OTGW from the Nodo webshop, which can be found on letscontrolit.com.
You will need the OTGW print, an Arduino Mega, and an ESP unit for WiFi access. Also a power unit and (optionally) a case to mount the unit in.
Wiring is easy: beside a ppower unit (18V, I believe), there are four screwed wire attachements: two will go to the boiler, the other two to the thermostat. Effectively the OTGW is electrically located between thermostat and boiler.
Software for the ESP unit can be downloaded there as well, and there is a good installation and configuration manual.
Hans
manjh
Re: Remeha eTwist
Post by manjh » Tuesday 12 June 2018 11:14
I just checked again with Remeha, they confirm that there is no interface available.
Pity, I am getting a new Tzerra with an eTwist thermostat next week, would have been great if the thermostat would interface directly with Domoticz.
I guess that OTGW is the only option...
Hans
manjh
Re: Remeha eTwist
Post by manjh » Tuesday 03 July 2018 19:58
OK, one step ahead.
Last week my old boiler (in my summerhome) was replaced by a new Remeha Tzerra, which came with an iSense or eTwist thermostat, I picked the eTwist.
It is connected by wire to a base unit which is mounted next to the boiler; from there a wire to the boiler.
As I understand from the guy installing the boiler, the thermostat does not "speak" OpenTherm. It was actually developed for the latest Remeha model: the Ace.
The Tzerra boiler does expect OpenTherm, and that's where the base unit (called GateWay) comes in.
Everything works just fine, thermostat can be controlled manually, or via a Remeha App on Android.
My next step will be to insert an OTGW unit between the Remeha Gateway and the boiler. That should be "clean" OpenTherm, so should work. I won't be able to change the thermostat settings, I think. There is no API available from Remeha. But the OTGW will be able to pick up status info from the boiler, and probably also be able to override temperature temporarily.
As soon as I have the OTGW I will try it an report back.
Hans
