Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderator: wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
squandor
Target OS: Raspberry Pi
Domoticz version: 3.5837
Re: Domoboard - General Discussions
Post by squandor » Saturday 24 February 2018 15:00
schorrie wrote:
Wednesday 14 February 2018 23:06
Ok, i am a newbie here at domoticz and have a question about domoboard
After installation of the domoboard, is it still possible to access domoticz in the normal way,
i'm asking this because i would like to use domoboard only on my tablet that will be fixed against the wall,
on my phone i would like to keep the normal domoticz site
Sorry for the late reply my life is a little bit changed at the moment with the birth of my daughter so my time is limited at the moment :)
but yes, you can still access domoticz in the normal way. you only have problems if you set the port in de config for domoboard at the same port as domoticz.
florisi
Domoticz version: v4.9732
Post by florisi » Tuesday 10 April 2018 10:06
installed Domoboard, running ok.
Now I want to run wunderground.
But demoboard crashes and in the logfile it says:
Error occured during loading imports for the plugin wunderground: No module named geocoder. Install it with 'easy_install geocoder' or 'pip install geocoder'
Did the install but still get the same error.
Someone knows a work around?
squandor
Post by squandor » Tuesday 10 April 2018 13:11
Hi Florisi,
How do you start domoboard? is it running in an env or simply on the server?
if you start an python shell and type import geocoder does it say anything?
Gr. Squandor
florisi
Post by florisi » Tuesday 10 April 2018 13:14
Its running as a service on the same raspberry pi as Domoticz.
What is the command to test the python import?
squandor
Post by squandor » Tuesday 10 April 2018 14:54
i think that its installed in an env that way. in that case you need to install geocoder also in the env.
it should work with this code:
/home/<user>/domoboard/bin/pip install geocoder
where <user> is you're pi user (possibly "pi")
florisi
Post by florisi » Tuesday 10 April 2018 15:09
it doesn't crash anymore, but underground is empty.
squandor
Post by squandor » Tuesday 10 April 2018 15:10
i think that thats an configuration issue. How is you're wunderground config?
florisi
Post by florisi » Tuesday 10 April 2018 15:14
I've already figured it out, you can only choose English.
florisi
Post by florisi » Monday 16 April 2018 14:39
A new question.
Installed the iCloud plugin.
Now when I open the dashboard I got on my iPhone and Mac that a new device want to have access to iCloud.
Of course this correct, but I can't type the verification code at any place.
Is there a solution for this?
squandor
Post by squandor » Tuesday 17 April 2018 7:41
thats a good question, i don't use the 2 factor authentication so i wont get that message but my colleague does so i will ask it for you.
nvb9
Post by nvb9 » Sunday 01 July 2018 12:46
First of all, i'm really suprised there is so less activity in this sub forum. Domoboard looks really cool!
I've got a question about light control. I can add my light IDX to domoboard, but it shows up with a RGB selector.
The lights that I want to control (Milight FUT103) are RGBWW/CCT. I don't have an option in domoboard to use a RGBWW selector, so I can control Kelvin/White.
Does someone knows how to implement a RGBWW selector?
squandor
Post by squandor » Tuesday 03 July 2018 12:39
Hi there,
Thank you for the kind words and my apologies for the low activity. (having an baby and building an house are some things that are on the priority list otherwise the misses will get angry ;) )
I think that that function isn't fully supported in domoboard. With the new release of domoticz we will try to get back on strack a.s.a.p because they did also made some changes to the selector switches.
Greetings, Squandor
nvb9
Post by nvb9 » Wednesday 04 July 2018 9:18
Hi there,
Greetings, Squandor
You're totally right! No need to apology :) Thank you for your answer and I'm looking forward to the next update.
Wish you all the best with your house and family.
philleaerts
Post by philleaerts » Monday 23 July 2018 14:51
In the config file you can specify different users as configured in domoticz.
Also the login page of the domoboard server works accordingly.
however, there don't seem to be a way to have custom pages/layout per user.
In domoticz you can designate specific devices to a user so only these devices show up when logged in as that user.
It would even be better that you could use the config file to make specific configurations per user.
This way you could have an admin account and a 'kids' account look completely different.
maybe this is already possible but I don't know how to configure this. :?
Please help
patricknooijen
Post by patricknooijen » Monday 05 November 2018 20:32
I am getting a keyerror on the ANWB plugin?
Anyone else still using this?
