Evohome client (August 2017 update)
Soulplayer
Re: Evohome client (August 2017 update)
Post by Soulplayer » Thursday 09 November 2017 14:05
I also have a question: I have two controllers but I cannot seem to select both it always gives me the first location although I select 1 or 2 or ... It creates those zones.
I use the Evohome via Web Api. Do I have to change something else?
Soulplayer
Post by Soulplayer » Thursday 09 November 2017 18:06
Settings are saved and it gets the information. It just seem to ignore the location setting
Soulplayer
Post by Soulplayer » Sunday 12 November 2017 19:06
So nothing I can do probably?
Soulplayer
Post by Soulplayer » Sunday 12 November 2017 20:45
Guess I'll have to wait a bit until it reaches the stable version. I'm using docker so I can't update to the beta :(.
Target OS: Raspberry Pi
Post by waaren » Friday 24 November 2017 18:11
With every new Domoticz Beta version following 8627 is get the following error
2017-11-24 17:02:49.230 (Evohome) connect to Evohome server
2017-11-24 17:02:49.389 Error: (Evohome) HTTP client error at login!
I compile from source using a spare RPI. If I try to update using the updatebeta script I got segmentation fault (when run from command line) or Fatal signal 11 (daemon)
If I copy my version 8627 back it will connect and update my temperatures and setpoints so I assume settings in domoticz database are correct.
Is there a way to solve this ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
mariobrosch
Domoticz version: latest
Post by mariobrosch » Sunday 09 September 2018 19:13
I to had the issue of wrong login. After several attempt fixing the issue I logged in into totalconnect website. Edited my profile by changing the hungarian language to dutch. Hungarian is a good default honeywell!
After that I stopped and started the web api device in domoticz and it started connected my home :)
