Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
Flopp
Post by Flopp » Monday 31 October 2016 10:11
I got this Error anyone seen it before or know what it means?
I am using 3. 5721 on RPi. I am using JSON to get node data to a webpage, if it can have something to with JSON
felix63
Target OS: Raspberry Pi
Domoticz version: 3.8275
Re: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
Post by felix63 » Monday 23 January 2017 14:55
Same error. Anyone?
berta
Post by berta » Friday 17 November 2017 9:58
Same error i got this morning, no idea what this mean?
Using vs 3.8153 domoticz
StratosHF
Domoticz version: 3.8153
Post by StratosHF » Sunday 28 January 2018 19:43
Me too...
2018-01-27 07:00:59.177 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
v3.8153
RPi3
DAVIZINHO
Post by DAVIZINHO » Tuesday 30 January 2018 21:46
me to, never see this error
2018-01-30 20:24:11.381 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: ...z/scripts/dzVents/../../dzVents/runtime/EventHelpers.lua:374: attempt to concatenate field 'hardwareName' (a nil value)
2018-01-30 20:25:16.259 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-01-30 20:25:16.260 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
beta v3.8872
RPi3
urbaxe
Domoticz version: 3.9629
Post by urbaxe » Wednesday 30 May 2018 11:34
Me to, from this morning.
2018-05-30 11:30:56.341 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-05-30 11:30:57.345 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-05-30 11:30:58.350 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-05-30 11:30:59.357 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
Have any one some information of what this is for kind of problem?
Raspberry Pi 3/v3.9629 - Tellstick DUO - Aeon Z-Stick gen5 - RaspBee - Wall mounted tablet + Imperihome - MANY switches/sensors
Flopp
Post by Flopp » Monday 11 June 2018 15:01
I didn’t remember that I have had this error before.
A few days ago it started to give me this error again and now it is gone again.
Nothing changed and no restarts of PC or software.
If more users starts to get this again it must be something with Domoticz that sends data to somewhere?
Siewert308SW
Post by Siewert308SW » Monday 11 June 2018 17:28
Yep, seen it a few times on my Rpi3 loaded Domoticz.
Never understood it but also never payed attention to it as it occurs very rarely.
Also no clue on how to reproduce as i don't know the culprit.
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
Flopp
Post by Flopp » Monday 11 June 2018 19:36
I am using a laptop since 6-12 months back with Debian.
So it doesn’t seem to be related to RPi
Post by waaren » Monday 11 June 2018 20:32
It has something to do with webserver not being able to connect to other processes on the server. This is not bound to a specific kind of server.
In fact if the code reaches that point it protects the server from getting locked because of an exception. If you understand c++ and low level network connection stuff it might be worthwhile for you to look into the source (webserver/connection.cpp starting at line number 89)
For me it is far too complicated to understand the details of what is going on.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
urbaxe
Post by urbaxe » Tuesday 12 June 2018 14:31
I switched firewall recently from ipfire to pfsense and after that the problems occurred the first time.
I'll try to disable some security features in the firewall tonight to see if that could be a problem.
I will return with results.
urbaxe
Post by urbaxe » Tuesday 12 June 2018 22:30
I can not really say what caused the problem to end for me.
I did not find that the firewall would be the problem.
I switched the domoticz port from 8080 to 80 and then the problem disappeared to return again after a while. Then I switched back to 8080 and then the error message disappeared and has not returned. Did some reboots too. So I really can not say what caused my problems to end.
urbaxe
Post by urbaxe » Wednesday 13 June 2018 8:24
...and now it's back
2018-06-13 08:22:22.401 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-06-13 08:22:23.403 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-06-13 08:22:24.448 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
2018-06-13 08:22:25.498 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
