Domoticz Remote Access
sghazagh
Target OS: Raspberry Pi
Post by sghazagh » Friday 28 October 2016 1:41
I am new to Domoticz and have some issue with remote access to the server.
That's not about network configuration.My router is forwarding properly to the server inside my LAN and port has been configured correctly.
I also can see the login page and can login to Domoticz as well.
My issue is that, when I login remotely, none of the settings shows and it looks like you have started from the scratch.
When I connect through LAN or VPN to my LAN, all the settings , devices and... are there.
Why I cannot see my stuff when I login from outside my LAN? :?: :!:
sghazagh
Re: Domoticz Remote Access
Post by sghazagh » Tuesday 01 November 2016 22:03
Nobody have this issue? at least tell me if it's only my problem!
I still cannot get it loaded properly from outside of my LAN!
Skippiemanz
Domoticz version: 3.5859
Post by Skippiemanz » Tuesday 01 November 2016 22:08
Already cleared the cache and refreshed your page?
Or try a different browser for testing.
sghazagh
Post by sghazagh » Tuesday 01 November 2016 22:11
Yes mate, I tried both.
When I login remotely, I only can see the Setup button. and it has nothing. Like you started from the scratch!!! :(
jvdz
Domoticz version: Stable
Post by jvdz » Tuesday 01 November 2016 22:14
have you checked the access rights for the username you use to access remotely?
Jos
sghazagh
Post by sghazagh » Tuesday 01 November 2016 22:16
Where is it?
I am using my main username...
I am double checking now....give me a minute...
sghazagh
Post by sghazagh » Tuesday 01 November 2016 22:22
I only see my main login under "Website Protection" which I normally use to login to dashboard.Authentication is set to "login Page".
In front of that, there is "Security Panel" which I use the same password , delay is set to 30 seconds.
Bellow is "Remote Share Port" which I have set to the port I am accessing from outside!
sghazagh
Post by sghazagh » Tuesday 01 November 2016 22:30
Oh God,
I don't know what was wrong but I have created another user and changed the Login from "Login Page" to "Basic-authenticate" and it's now working!!!
sghazagh
Post by sghazagh » Tuesday 01 November 2016 22:35
Guys,
I can confirm that the issue is for login method.
The "Basic-Auth" works fine but "Login Page" doesn't!
OldPensionado
Domoticz version: 3.8153
Post by OldPensionado » Sunday 05 March 2017 14:12
sghazagh wrote:Guys,
I encountered more or less the same problem: in my situation I couldn't login at all. After entering username and password (these were correct, no messages about wrong username/password combination) I see the login screen again, and again. (Although it is weird that the proposed username is "Admin" and a four characters password.)
Lucky enough I had made a backup of the SD-card (using USB Backup) so I restored the backup, booted the RPi up and I got into the Webgui without any password.
Then I entered again a username/password at "Website Protection" but now with Basic-Auth. And this works indeed fine!
Lessons learned: to backup or not to backup, that's the question...
RPi 1, model B
Raspbian Jessie Lite
Domoticz V3.8153
Well, such is life. And it's getting sucher and sucher...
amplituda
Post by amplituda » Tuesday 11 September 2018 6:58
Guys,
Thank you very much, it works and now it's good!)
Users browsing this forum: arass and 4 guests
