TOON died within Domoticz
EdwinK
Target OS: Raspberry Pi
Re: TOON died within Domoticz
Post by EdwinK » Sunday 14 January 2018 11:33
astrapowerrr wrote:
Monday 08 January 2018 0:36
Does anyone here has the issue that in the log the toon is set to 6 degrees. At every Sunday morning about 00:02...
I see this constantly coming back only at that moment.
That is a known bug within Toon. Since not everyone is having that problem, it seems hard to fix. If you go to forum.toon.nl I believe it has been discussed there.
Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
astrapowerrr
Post by astrapowerrr » Thursday 18 January 2018 23:04
Correct!! Its a bug. Thanks for the tip!
rjblake
Post by rjblake » Friday 09 February 2018 16:17
Good luck getting this resolved. I filed a bug report with Eneco about this bug over 6 months ago and it has never been fixed to date.
michaelm86
Domoticz version: 3.8153
Post by michaelm86 » Tuesday 27 February 2018 14:55
Hi GUys,
hope that you can help me.
i added Toon to domoticz. but i cannot get the scenes working. when i select comfort it keeps flipping back to weg (away). But when i perform the json call bij hand in the browser it just works...does anybody know how to slove this?
i configured the following:
Setpoint:
Toon Scens:
see attachement and picture bellow:
error:
2018-02-27 13:40:40.147 Error: Error opening url: http://xx.xx.xx.xx:8080/json.htm?type=c ... =5&state=0
(i replaces the ip bi xx.xx.xx.xx)
lua script
-- script_time_toonselector.lua
-- Reads the Toon Thermostat Setpoint Temperature and updates the
-- selector in Domoticz to represent the current Active State.
-- Off scene is an option, leave it out if not needed.
-- Action commands will not be executed.
-- Settings: Configure as desired
-- Name of the switch with the temperature setpoint.
ThermostatSetPointName = 'Thermostaatinstelling' --Must match the name of you SetPoint device
-- Temperature SetPoints.
OffSetPoint = '6.00' --optional
AwaySetPoint = '16.50'
SleepSetPoint = '17.00'
HomeSetPoint = '19.00'
ComfortSetPoint = '20.00'
-- Name of the selector for Toon
ToonSelector = 'Thermostaat' --Must match (including case) the name of your Selector Switch
-- Name of the levels in the selector
OffLevel = 'Off' --optional
AwayLevel = 'Weg'
SleepLevel = 'Slapen'
HomeLevel = 'Thuis'
ComfortLevel = 'Comfort'
-- Values from each level name
OffLevelValue = '0' --optional
AwayLevelValue = '10'
SleepLevelValue = '20'
HomeLevelValue = '30'
ComfortLevelValue = '40'
-- End of settings
-- Toon Thermostat SetPoint:
ThermostatSetPoint = otherdevices_svalues[ThermostatSetPointName]
if (ThermostatSetPoint == HomeSetPoint) then
        --print("SetPoint equals to Home");
		if (otherdevices[ToonSelector] ~= HomeLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. HomeLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..HomeLevelValue
elseif (ThermostatSetPoint == ComfortSetPoint) then
        --print("SetPoint equals to Comfort");
		if (otherdevices[ToonSelector] ~= ComfortLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. ComfortLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..ComfortLevelValue
elseif (ThermostatSetPoint == SleepSetPoint) then
        --print("SetPoint equals to Sleep");
		if (otherdevices[ToonSelector] ~= SleepLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. SleepLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..SleepLevelValue
elseif (ThermostatSetPoint == AwaySetPoint) then
        --print("SetPoint equals to Away");
		if (otherdevices[ToonSelector] ~= AwayLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. AwayLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..AwayLevelValue
-- Optional
elseif (ThermostatSetPoint == OffSetPoint) then
        --print("SetPoint equals to Off");
		if (otherdevices[ToonSelector] ~= OffLevel) then
		print("Updating '" .. ToonSelector .. "' selector to '" .. OffLevel .. "'")
		commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..OffLevelValue
Domoticz 3.8153 on linux laptop ubuntu 17.10 | Toon Thermostat | RFlink usb gateway
Plantje
Post by Plantje » Tuesday 27 February 2018 16:06
I didn't know it was possible to connect the programm settings of Toon to Domoticz. Can you also read and write the programm itself?
I will see if I can try this as well and if I can reproduce the issue.
michaelm86
Post by michaelm86 » Wednesday 28 February 2018 18:41
does anybody have an idea?
HansieNL
Post by HansieNL » Wednesday 28 February 2018 20:24
I stopped sending state commands long ago and use temp commands. No problems at all:
http://192.168.x.xx.8080/json.htm?type= ... value=20.5
Blah blah blah
michaelm86
Post by michaelm86 » Wednesday 28 February 2018 23:39
Can you explain what you did for configuration and setup? because ik i repaced the command in the toon scenes switch and i have the same issues.. :(
Error: Error opening url: http://192.168.116.98:8080/json.htm?par ... =5&state=2
when i push the button on the switch is does not work and when i open a new tab in the browser it works:
http://192.168.116.98:8080/json.htm?typ ... value=20.5
   "status" : "OK",
   "title" : "Update Device"
michaelm86
Post by michaelm86 » Thursday 01 March 2018 0:08
   "status" : "OK",
I found the issue! now i have to find a solution...
i configured a username and password for domoticz for the portal. when i remove this the scens work..
when i activate the pw and username again an di change the url to:
http://username:password@192.168.116.98 ... =5&state=2
it does not work... any ideas?
HansieNL
Post by HansieNL » Thursday 01 March 2018 0:41
Have you included your local network in the Domoticz settings: Local Networks (no username/password)?
Blah blah blah
michaelm86
Post by michaelm86 » Thursday 01 March 2018 12:52
Yes. the localhost, ip of the machine itself and the subnet.
EdwinK
Post by EdwinK » Wednesday 06 June 2018 9:12
And since about a day now, Toon, and the smart plug's connected to it, are again not working with Domoticz :(
EdwinK
Post by EdwinK » Thursday 06 December 2018 11:08
deleted
madpatrick
Domoticz version: 4.9700
Post by madpatrick » Thursday 06 December 2018 20:41
It looks like the other forum (www.domoticaforum.eu) is having certificate problems :(
There is no link between Toon or Domoticz and the forum.
ClearOS v7.5.0 - Toon2 v4.19.10 (rooted) - Domoticz v4.9700
madpatrick
Post by madpatrick » Thursday 06 December 2018 20:44
Have you checked the log ?
EdwinK
Post by EdwinK » Thursday 06 December 2018 22:11
This is from about 6 months ago.
Plantje
Post by Plantje » Friday 07 December 2018 0:09
And did you check the log? :)
