Solved: P1 Meter Issue since new beta?
Forum rules
Version: xxxx
Platform: xxxx
Description:
Cletus
Target OS: Raspberry Pi
Domoticz version: Latest
Postby Cletus » Thursday 01 September 2016 9:41
I've just updated to the new beta version version: 3.5582
Now i get these errors in my logfile, is this a known issue?
2016-09-01 09:38:54.017 P1: dismiss incoming - CRC failed
2016-09-01 09:39:03.900 P1: dismiss incoming - CRC failed
2016-09-01 09:39:13.768 P1: dismiss incoming - CRC failed
2016-09-01 09:39:19.554 Hardware Monitor: Fetching data (System sensors)
2016-09-01 09:39:23.620 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 09:39:27.274 (Thermostaat) Thermostat (Room Setpoint)
2016-09-01 09:39:27.276 (Thermostaat) Temp (Room Temperature)
2016-09-01 09:39:33.481 P1: dismiss incoming - CRC failed
2016-09-01 09:39:43.358 P1: dismiss incoming - CRC failed
2016-09-01 09:39:49.588 Hardware Monitor: Fetching data (System sensors)
2016-09-01 09:39:53.210 P1: dismiss incoming - CRC failed
2016-09-01 09:40:03.082 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 09:40:12.939 P1: dismiss incoming - CRC failed
2016-09-01 09:40:19.623 Hardware Monitor: Fetching data (System sensors)
2016-09-01 09:40:22.822 P1: dismiss incoming - CRC failed
2016-09-01 09:40:28.186 (Thermostaat) Thermostat (Room Setpoint)
2016-09-01 09:40:28.187 (Thermostaat) Temp (Room Temperature)
2016-09-01 09:40:32.699 P1: dismiss incoming - CRC failed
This is our world now... the world of the electron and the switch, the beauty of the baud.
mvveelen
Domoticz version: V3.6796
Re: P1 Meter Issue since new beta?
Postby mvveelen » Thursday 01 September 2016 10:01
Having the same issue. The values the P1 meter sends are OK, no strange values or whatsoever. These aren't errors, they are warnings. If I could turn it off, I would. The error log is now cluttered with all these warnings.....
Synology DS414 DSM6 (with Domoticz v3.6796)
RFXCOM rfxtrx433E fw 1009
Aeon Labs Z-Stick v2
gizmocuz
Postby gizmocuz » Thursday 01 September 2016 10:02
Support for CRC checking was added by Gordon (Thanks!), but maybe there is a small issue with it.
Are you using Serial or TCP with the smart meter ?
Could you add more logging, i would like to see all timestamps where it goes correctly.
For example goto the log viewer, and filter on 'Stroommeter'
Maybe you could do this for some time
https://github.com/domoticz/domoticz/pull/836
gizmocuz
Postby gizmocuz » Thursday 01 September 2016 10:03
We can always revert, but it would be nicer to get it working correctly.
@veelen, are you also seeing correct messages being received like above ?
What is the time interval between the error lines and a correct lines?
mvveelen
Postby mvveelen » Thursday 01 September 2016 10:08
Let me get back to you on that. I just found out that I haven't received these warnings for a while. I will watch the log for a while and copy / paste here if I find something.
I updated another Domoticz, and his log shows:
2016-09-01 10:04:19.931 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:04:29.968 P1: dismiss incoming - CRC failed
2016-09-01 10:04:40.036 P1: dismiss incoming - CRC failed
2016-09-01 10:04:44.353 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:04:50.069 P1: dismiss incoming - CRC failed
2016-09-01 10:05:00.097 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:05:10.190 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:05:15.063 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:05:20.227 P1: dismiss incoming - CRC failed
2016-09-01 10:05:30.274 P1: dismiss incoming - CRC failed
2016-09-01 10:05:40.337 P1: dismiss incoming - CRC failed
2016-09-01 10:05:45.763 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:05:50.376 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:05:50.377 (SmartMeter) P1 Smart Meter (Gas)
2016-09-01 10:06:00.430 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:06:10.496 P1: dismiss incoming - CRC failed
2016-09-01 10:06:16.443 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:06:20.564 P1: dismiss incoming - CRC failed
2016-09-01 10:06:30.657 P1: dismiss incoming - CRC failed
2016-09-01 10:06:40.726 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:06:47.153 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:06:50.760 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:07:00.815 P1: dismiss incoming - CRC failed
2016-09-01 10:07:10.883 P1: dismiss incoming - CRC failed
2016-09-01 10:07:17.913 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:07:20.914 P1: dismiss incoming - CRC failed
2016-09-01 10:07:30.950 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:07:41.043 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:07:48.893 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:07:51.078 P1: dismiss incoming - CRC failed
2016-09-01 10:08:01.113 P1: dismiss incoming - CRC failed
2016-09-01 10:08:11.176 P1: dismiss incoming - CRC failed
2016-09-01 10:08:19.623 Hardware Monitor: Fetching data (System sensors)
2016-09-01 10:08:21.213 (SmartMeter) P1 Smart Meter (Elektra)
gordonb3
Domoticz version: custom
Postby gordonb3 » Thursday 01 September 2016 10:17
The messages turn up with loglevel 1 (status+error). If you select loglevel=2 (only error) there will be no messages.
As you can see, there are messages that do pass, so obviously something must be wrong with those other messages. You do appear to have an extreme amount of fails though. I myself receive around 150 of those CRC fails a day and having logged the contents of those messages for about a week I could practically always spot the error.
Gordon
Excito B3 running Gentoo Linux, P1, Rfxtrx433 to read and control TFA, KaKu, EvoHome RFG100
Custom patched Domoticz v3.6584
mvveelen
Postby mvveelen » Thursday 01 September 2016 10:20
On my own setup of Domoticz, it stopped giving me these messages. On the setup of Domoticz for my father-in-law it shows me the warnings. I just updated his setup.
What error could I possible spot (and fix) ? The P1 cable is OK or it's not, right?
Cletus
Postby Cletus » Thursday 01 September 2016 10:31
Hi gizmocuz,
IS this what you are looking for? Filtered on P1 :)
Edit: It's a Prolific RS232 to USB converter with the 5v and grnd soldered onto the USB part and the Data on serial pin 2 to RJ11.
2016-09-01 10:21:19.696 P1: dismiss incoming - CRC failed
2016-09-01 10:21:29.564 P1: dismiss incoming - CRC failed
2016-09-01 10:21:39.436 P1: dismiss incoming - CRC failed
2016-09-01 10:21:49.316 P1: dismiss incoming - CRC failed
2016-09-01 10:21:59.166 P1: dismiss incoming - CRC failed
2016-09-01 10:22:09.029 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:22:18.895 P1: dismiss incoming - CRC failed
2016-09-01 10:22:28.778 P1: dismiss incoming - CRC failed
2016-09-01 10:22:38.628 P1: dismiss incoming - CRC failed
2016-09-01 10:22:48.498 P1: dismiss incoming - CRC failed
2016-09-01 10:22:58.370 P1: dismiss incoming - CRC failed
2016-09-01 10:23:08.237 P1: dismiss incoming - CRC failed
2016-09-01 10:23:18.089 P1: dismiss incoming - CRC failed
2016-09-01 10:23:27.951 P1: dismiss incoming - CRC failed
2016-09-01 10:23:37.829 P1: dismiss incoming - CRC failed
2016-09-01 10:23:47.712 P1: dismiss incoming - CRC failed
2016-09-01 10:23:57.589 P1: dismiss incoming - CRC failed
2016-09-01 10:24:07.452 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:24:07.454 (Stroommeter) P1 Smart Meter (Gas)
2016-09-01 10:24:17.323 P1: dismiss incoming - CRC failed
2016-09-01 10:24:27.201 P1: dismiss incoming - CRC failed
2016-09-01 10:24:37.053 P1: dismiss incoming - CRC failed
2016-09-01 10:24:46.922 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:24:56.793 P1: dismiss incoming - CRC failed
2016-09-01 10:25:06.665 P1: dismiss incoming - CRC failed
2016-09-01 10:25:16.542 P1: dismiss incoming - CRC failed
2016-09-01 10:25:26.396 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:25:36.254 P1: dismiss incoming - CRC failed
2016-09-01 10:25:46.135 P1: dismiss incoming - CRC failed
2016-09-01 10:25:55.986 P1: dismiss incoming - CRC failed
2016-09-01 10:26:05.855 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:26:15.715 P1: dismiss incoming - CRC failed
2016-09-01 10:26:25.597 P1: dismiss incoming - CRC failed
2016-09-01 10:26:35.475 P1: dismiss incoming - CRC failed
2016-09-01 10:26:45.330 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:26:55.185 P1: dismiss incoming - CRC failed
2016-09-01 10:27:05.068 P1: dismiss incoming - CRC failed
2016-09-01 10:27:14.939 P1: dismiss incoming - CRC failed
2016-09-01 10:27:24.788 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:27:34.649 P1: dismiss incoming - CRC failed
2016-09-01 10:27:44.528 P1: dismiss incoming - CRC failed
2016-09-01 10:27:54.379 P1: dismiss incoming - CRC failed
2016-09-01 10:28:04.253 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:28:14.108 P1: dismiss incoming - CRC failed
2016-09-01 10:28:23.991 P1: dismiss incoming - CRC failed
2016-09-01 10:28:33.840 P1: dismiss incoming - CRC failed
2016-09-01 10:28:43.711 P1: dismiss incoming - CRC failed
2016-09-01 10:28:53.583 P1: dismiss incoming - CRC failed
2016-09-01 10:29:03.461 P1: dismiss incoming - CRC failed
2016-09-01 10:29:13.332 P1: dismiss incoming - CRC failed
2016-09-01 10:29:23.184 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:29:23.186 (Stroommeter) P1 Smart Meter (Gas)
2016-09-01 10:29:33.042 P1: dismiss incoming - CRC failed
2016-09-01 10:29:42.925 P1: dismiss incoming - CRC failed
2016-09-01 10:29:52.802 P1: dismiss incoming - CRC failed
2016-09-01 10:30:02.656 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:30:12.531 P1: dismiss incoming - CRC failed
2016-09-01 10:30:22.408 P1: dismiss incoming - CRC failed
2016-09-01 10:30:32.260 P1: dismiss incoming - CRC failed
2016-09-01 10:30:42.129 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:30:52.000 P1: dismiss incoming - CRC failed
2016-09-01 10:31:01.883 P1: dismiss incoming - CRC failed
Last edited by Cletus on Thursday 01 September 2016 10:42, edited 2 times in total.
gordonb3
Postby gordonb3 » Thursday 01 September 2016 10:37
@mvveelen
I'd guess...
On average the 150 CRC fails plus some additional other fail messages come down to about one fail in every 8-9 minutes, once in every 50-60 messages. It happens at completely random intervals though. I've had them 10 seconds apart (i.e. two consecutive messages) and more than an hour. Whether it's the meter, the cable or the (CH341) driver I can't tell, but logic says the CRC was added for a reason. It must be noted though that not all fails would hurt Domoticz or the data you collect with it. Seeing the CRC warning means that all other validation rules on the fields that are actually being used did pass. I suppose it should be possible to make the CRC check optional through the settings screen if this turns out to result in too many discards in some environments.
Cletus
Postby Cletus » Thursday 01 September 2016 10:41
Not sure what you mean Gordon :)
Btw i've got a RS232 Prolific USB Serial Converter cut open and wired a RJ11 cable onto it. It worked fine with every 10 seconds an update, but now i see every 30 seconds an update or something?
Cletus
Postby Cletus » Thursday 01 September 2016 10:50
Some more logs:
2016-09-01 10:31:11.749 P1: dismiss incoming - CRC failed
2016-09-01 10:31:21.622 P1: dismiss incoming - CRC failed
2016-09-01 10:31:31.491 P1: dismiss incoming - CRC failed
2016-09-01 10:31:41.372 P1: dismiss incoming - CRC failed
2016-09-01 10:31:51.224 P1: dismiss incoming - CRC failed
2016-09-01 10:32:01.092 P1: dismiss incoming - CRC failed
2016-09-01 10:32:10.953 P1: dismiss incoming - CRC failed
2016-09-01 10:32:20.834 P1: dismiss incoming - CRC failed
2016-09-01 10:32:30.713 P1: dismiss incoming - CRC failed
2016-09-01 10:32:40.567 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:32:50.423 P1: dismiss incoming - CRC failed
2016-09-01 10:33:00.306 P1: dismiss incoming - CRC failed
2016-09-01 10:33:10.176 P1: dismiss incoming - CRC failed
2016-09-01 10:33:20.026 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:33:29.887 P1: dismiss incoming - CRC failed
2016-09-01 10:33:39.765 P1: dismiss incoming - CRC failed
2016-09-01 10:33:49.617 P1: dismiss incoming - CRC failed
2016-09-01 10:33:59.490 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:34:09.346 P1: dismiss incoming - CRC failed
2016-09-01 10:34:19.229 P1: dismiss incoming - CRC failed
2016-09-01 10:34:29.107 P1: dismiss incoming - CRC failed
2016-09-01 10:34:38.960 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:34:38.962 (Stroommeter) P1 Smart Meter (Gas)
2016-09-01 10:34:48.820 P1: dismiss incoming - CRC failed
2016-09-01 10:34:58.698 P1: dismiss incoming - CRC failed
2016-09-01 10:35:08.569 P1: dismiss incoming - CRC failed
2016-09-01 10:35:18.421 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:35:28.279 P1: dismiss incoming - CRC failed
2016-09-01 10:35:38.162 P1: dismiss incoming - CRC failed
2016-09-01 10:35:48.039 P1: dismiss incoming - CRC failed
2016-09-01 10:35:57.893 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:36:07.772 P1: dismiss incoming - CRC failed
2016-09-01 10:36:17.651 P1: dismiss incoming - CRC failed
2016-09-01 10:36:27.503 P1: dismiss incoming - CRC failed
2016-09-01 10:36:37.352 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:36:47.213 P1: dismiss incoming - CRC failed
2016-09-01 10:36:57.096 P1: dismiss incoming - CRC failed
2016-09-01 10:37:06.962 P1: dismiss incoming - CRC failed
2016-09-01 10:37:16.816 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:37:26.673 P1: dismiss incoming - CRC failed
2016-09-01 10:37:36.555 P1: dismiss incoming - CRC failed
2016-09-01 10:37:46.407 P1: dismiss incoming - CRC failed
2016-09-01 10:37:56.275 P1: dismiss incoming - CRC failed
2016-09-01 10:38:06.136 P1: dismiss incoming - CRC failed
2016-09-01 10:38:16.016 P1: dismiss incoming - CRC failed
2016-09-01 10:38:25.866 P1: dismiss incoming - CRC failed
2016-09-01 10:38:35.739 P1: dismiss incoming - CRC failed
2016-09-01 10:38:45.606 P1: dismiss incoming - CRC failed
2016-09-01 10:38:55.489 P1: dismiss incoming - CRC failed
2016-09-01 10:39:05.328 P1: dismiss incoming - CRC failed
2016-09-01 10:39:15.197 P1: dismiss incoming - CRC failed
2016-09-01 10:39:25.070 P1: dismiss incoming - CRC failed
2016-09-01 10:39:34.948 P1: dismiss incoming - CRC failed
2016-09-01 10:39:44.799 P1: dismiss incoming - CRC failed
2016-09-01 10:39:54.672 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:39:54.674 (Stroommeter) P1 Smart Meter (Gas)
2016-09-01 10:40:04.539 P1: dismiss incoming - CRC failed
2016-09-01 10:40:14.411 P1: dismiss incoming - CRC failed
2016-09-01 10:40:24.288 P1: dismiss incoming - CRC failed
2016-09-01 10:40:34.143 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:40:44.003 P1: dismiss incoming - CRC failed
2016-09-01 10:40:53.881 P1: dismiss incoming - CRC failed
2016-09-01 10:41:03.733 P1: dismiss incoming - CRC failed
2016-09-01 10:41:13.602 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:41:23.462 P1: dismiss incoming - CRC failed
2016-09-01 10:41:33.345 P1: dismiss incoming - CRC failed
2016-09-01 10:41:43.222 P1: dismiss incoming - CRC failed
2016-09-01 10:41:53.076 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:42:02.935 P1: dismiss incoming - CRC failed
2016-09-01 10:42:12.804 P1: dismiss incoming - CRC failed
2016-09-01 10:42:22.656 P1: dismiss incoming - CRC failed
2016-09-01 10:42:32.513 P1: dismiss incoming - CRC failed
2016-09-01 10:42:42.366 P1: dismiss incoming - CRC failed
2016-09-01 10:42:52.248 P1: dismiss incoming - CRC failed
2016-09-01 10:43:02.126 P1: dismiss incoming - CRC failed
2016-09-01 10:43:11.977 P1: dismiss incoming - CRC failed
2016-09-01 10:43:21.855 P1: dismiss incoming - CRC failed
2016-09-01 10:43:31.738 P1: dismiss incoming - CRC failed
2016-09-01 10:43:41.590 P1: dismiss incoming - CRC failed
2016-09-01 10:43:51.447 P1: dismiss incoming - CRC failed
2016-09-01 10:44:01.300 P1: dismiss incoming - CRC failed
2016-09-01 10:44:11.168 P1: dismiss incoming - CRC failed
2016-09-01 10:44:21.049 P1: dismiss incoming - CRC failed
2016-09-01 10:44:30.911 P1: dismiss incoming - CRC failed
2016-09-01 10:44:40.789 P1: dismiss incoming - CRC failed
2016-09-01 10:44:50.671 P1: dismiss incoming - CRC failed
2016-09-01 10:45:00.520 P1: dismiss incoming - CRC failed
2016-09-01 10:45:10.385 P1: dismiss incoming - CRC failed
2016-09-01 10:45:20.238 P1: dismiss incoming - CRC failed
2016-09-01 10:45:30.116 P1: dismiss incoming - CRC failed
2016-09-01 10:45:39.998 P1: dismiss incoming - CRC failed
2016-09-01 10:45:49.859 P1: dismiss incoming - CRC failed
2016-09-01 10:45:59.738 P1: dismiss incoming - CRC failed
2016-09-01 10:46:09.610 P1: dismiss incoming - CRC failed
2016-09-01 10:46:19.487 P1: dismiss incoming - CRC failed
2016-09-01 10:46:29.361 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:46:29.363 (Stroommeter) P1 Smart Meter (Gas)
2016-09-01 10:46:39.232 P1: dismiss incoming - CRC failed
2016-09-01 10:46:49.110 P1: dismiss incoming - CRC failed
2016-09-01 10:46:58.962 P1: dismiss incoming - CRC failed
2016-09-01 10:47:08.850 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:47:18.721 P1: dismiss incoming - CRC failed
2016-09-01 10:47:28.604 P1: dismiss incoming - CRC failed
2016-09-01 10:47:38.481 P1: dismiss incoming - CRC failed
2016-09-01 10:47:48.335 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:47:58.193 P1: dismiss incoming - CRC failed
2016-09-01 10:48:08.063 P1: dismiss incoming - CRC failed
2016-09-01 10:48:17.915 P1: dismiss incoming - CRC failed
2016-09-01 10:48:27.783 (Stroommeter) P1 Smart Meter (Stroomverbruik)
2016-09-01 10:48:37.655 P1: dismiss incoming - CRC failed
2016-09-01 10:48:47.536 P1: dismiss incoming - CRC failed
2016-09-01 10:48:57.415 P1: dismiss incoming - CRC failed
2016-09-01 10:49:07.287 P1: dismiss incoming - CRC failed
2016-09-01 10:49:17.144 P1: dismiss incoming - CRC failed
2016-09-01 10:49:26.997 P1: dismiss incoming - CRC failed
2016-09-01 10:49:36.848 P1: dismiss incoming - CRC failed
2016-09-01 10:49:46.717 (Stroommeter) P1 Smart Meter (Stroomverbruik)
Cletus
Postby Cletus » Thursday 01 September 2016 10:51
And some of Stroommeter only :)
2016-09-01 10:51:05.671 (Stroommeter) P1 Smart Meter (Stroomverbruik)
mvveelen
Postby mvveelen » Thursday 01 September 2016 10:56
I managed to filter on P1:
2016-09-01 10:48:58.684 P1: dismiss incoming - CRC failed
2016-09-01 10:49:08.689 P1: dismiss incoming - CRC failed
2016-09-01 10:49:18.680 P1: dismiss incoming - CRC failed
2016-09-01 10:49:28.655 P1: dismiss incoming - CRC failed
2016-09-01 10:49:38.641 P1: dismiss incoming - CRC failed
2016-09-01 10:49:48.663 P1: dismiss incoming - CRC failed
2016-09-01 10:49:58.649 P1: dismiss incoming - CRC failed
2016-09-01 10:50:08.630 P1: dismiss incoming - CRC failed
2016-09-01 10:50:18.621 P1: dismiss incoming - CRC failed
2016-09-01 10:50:28.607 P1: dismiss incoming - CRC failed
2016-09-01 10:50:38.600 P1: dismiss incoming - CRC failed
2016-09-01 10:50:48.586 P1: dismiss incoming - CRC failed
2016-09-01 10:50:58.578 P1: dismiss incoming - CRC failed
2016-09-01 10:51:08.559 (SmartMeter) P1 Smart Meter (Elektra)
2016-09-01 10:51:08.594 (SmartMeter) P1 Smart Meter (Gas)
2016-09-01 10:51:18.528 P1: dismiss incoming - CRC failed
2016-09-01 10:51:28.519 P1: dismiss incoming - CRC failed
2016-09-01 10:51:38.506 P1: dismiss incoming - CRC failed
2016-09-01 10:51:48.497 P1: dismiss incoming - CRC failed
2016-09-01 10:51:58.488 P1: dismiss incoming - CRC failed
2016-09-01 10:52:08.494 P1: dismiss incoming - CRC failed
2016-09-01 10:52:18.485 P1: dismiss incoming - CRC failed
2016-09-01 10:52:28.503 P1: dismiss incoming - CRC failed
2016-09-01 10:52:38.493 P1: dismiss incoming - CRC failed
2016-09-01 10:52:48.484 P1: dismiss incoming - CRC failed
2016-09-01 10:52:58.471 P1: dismiss incoming - CRC failed
2016-09-01 10:53:08.464 P1: dismiss incoming - CRC failed
2016-09-01 10:53:18.453 P1: dismiss incoming - CRC failed
2016-09-01 10:53:28.472 P1: dismiss incoming - CRC failed
2016-09-01 10:53:38.464 P1: dismiss incoming - CRC failed
2016-09-01 10:53:48.450 P1: dismiss incoming - CRC failed
2016-09-01 10:53:58.441 P1: dismiss incoming - CRC failed
2016-09-01 10:54:08.416 P1: dismiss incoming - CRC failed
2016-09-01 10:54:18.402 P1: dismiss incoming - CRC failed
2016-09-01 10:54:28.390 P1: dismiss incoming - CRC failed
2016-09-01 10:54:38.374 P1: dismiss incoming - CRC failed
2016-09-01 10:54:48.364 P1: dismiss incoming - CRC failed
2016-09-01 10:54:58.334 P1: dismiss incoming - CRC failed
2016-09-01 10:55:08.311 P1: dismiss incoming - CRC failed
2016-09-01 10:55:18.301 P1: dismiss incoming - CRC failed
It's a bit.....let me say.....annoying :) ?
gordonb3
Postby gordonb3 » Thursday 01 September 2016 10:56
Maybe this log snippet helps for understanding the changes
2016-08-31 06:36:08.842 P1: dismiss incoming - CRC failed
2016-08-31 06:44:49.386 P1: dismiss incoming - value in line "1-0:1.8.2(001753�385kWh)" is not a number
2016-08-31 07:00:11.306 P1: dismiss incoming - value in line "1-0:1.7.0(00.30M��U�H�1-0:2.7.0(00.000kW)" is oversized
In this logging you can see actual errors being detected in fields used by Domoticz (T2 counter and current usage respectively). The CRC is only done at the very end, if no other direct fails occurred. Possible reasons for CRC to fail include:
  • an error in a filed not used (i.e. ignored) by Domoticz
  • a reversed bit that causes a number to become another number, e.g 2 ==> 3
You wouldn't be able to see that last error when looking at a message, but you might see the numbers go up and down if you inspect a series of messages. Does that make sense?
gordonb3
Postby gordonb3 » Thursday 01 September 2016 11:26
mvveelen wrote:It's a bit.....let me say.....annoying :) ?
Yes, I can see how that would be annoying. Seeing the frequency of the warning you should be able to spot the faults quite easily though. Go to console and type:
cat < /dev/ttyUSB1
(replace '1' with the actual device number)
There's no locking of the serial port, so you can do this while Domoticz is running. To stop the dump to console, simply do a ctrl-C.
Edit: oops :oops: strike that. Doing `cat` will actually grab control over the tty so there will be no messages reaching Domoticz while you have that running.
Last edited by gordonb3 on Thursday 01 September 2016 15:09, edited 1 time in total.
mvveelen
Postby mvveelen » Thursday 01 September 2016 12:09
It's abracadabra to me, but maybe you can see something in this output:
DiskStation> cat < /dev/ttyUSB2
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901120753S)
0-0:96.1.1(4530303235303030303138373430383134)
1-0:1.8.1(002833.505*kWh)
1-0:1.8.2(002457.692*kWh)
1-0:2.8.1(000000.000*kWh)
1-0:2.8.2(000000.000*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.386*kW)
1-0:27.0(00.000*kW)
0-0:96.7.21(00005)
0-0:96.7.9(00003)
1-0:99.97.0(1)(0-0:96.7.19)(000101000001W)(2147483647*s)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:21.7.0(00.382*kW)
1-0:22.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303332353631323238333935333135)
0-1:24.2.1(160901120000S)(01561.434*m3)
!12EC
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901120803S)
1-0:1.8.2(002457.693*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.383*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00005)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:21.7.0(00.389*kW)
0-1:24.1.0(003)
!2DD9
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901120813S)
1-0:1.8.2(002457.694*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.379*kW)
0-0:96.7.21(00005)
0-0:96.7.9(0003)
1-0:32.32.0(00000)
1-0:32.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:21.7.0(00.379*kW)
0-1:24.1.0(003)
0-1:24.2.1(160901120000S)(01561.434m3)
!5F61
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901120823S)
1-0:1.8.2(002457.695*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.381*kW)
0-0:96.7.21(00005)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
10:3236.0(0000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:21.7.0(00.381*kW)
0-1:24.1.0003)
0-1:6.1.0(473030333253631323238333935333135)
!FE58
gordonb3
Postby gordonb3 » Thursday 01 September 2016 13:16
Wow!
Difficult to spot. Of the four messages, the second one tests correctly. Here are the relevant parts:
  1. diff -u meter1.txt meter2.txt
    -1-0:27.0(00.000*kW)
    +1-0:2.7.0(00.000*kW)
  2. diff -u meter3.txt meter2.txt
    -0-1:24.2.1(160901120000S)(01561.434m3)
    +0-1:24.2.1(160901120000S)(01561.434*m3)
  3. diff -u meter4.txt meter2.txt
    -0-1:6.1.0(473030333253631323238333935333135)
    +0-1:96.1.0(4730303332353631323238333935333135)
So you have a missing period in the first message, a missing asterisk in the third message (you should have a line in your log that says the value in line "0-1:24.2.1(160901120000S)(01561.434m3)" is not a number) and a missing 9 (@5) and 3 (@21/22) in the fourth message. The CRC fails are correct.
PS: Curious to learn why in your case characters are completely missing. Are you by chance using Putty from Windows to get to the console?
mvveelen
Postby mvveelen » Thursday 01 September 2016 13:44
I'm running Domoticz on a Synology NAS with a P1 USB cable to the smart meter (via a powered USB hub). I'm using Terminal on my MacBook Pro to SSH to the Synology.
Cletus
Postby Cletus » Thursday 01 September 2016 14:00
Hi Gordon,
Here is my output. Running from a Windows machine via Putty SSH to the Raspberry Pi on /dev/ttyUSB0
I can try to capture it on a Windows machine or anything else if you like?
[email protected]:~$ cat < /dev/ttyUSB0
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135807S)
0-0:96.1.1(4530303236303030303130303238343134)
1-0:1.8.1(005453.992*kWh)
1-0:1.8.2(005932.328*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.368*kW)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:99.97.0(1)(0-0:96.7.19)(000101000010W)(2147483647*s)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.283*kW)
1-0:41.7.0(00.026*kW)
1-0:42.7.0(00.000*kW)
1-0:61.7.0(00.072*kW)
1-0:62.7.0(00.000*kW)
!E05F
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135818S)
1-0:1.8.2(005932.329*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.367*kW)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.276*kW)
1-0:41.7.0(00.025*kW)
1-0:61.7.0(00.071*kW)
!615A
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135827S)
1-0:1.8.2(005932.331*kWh)
0-0:96.14.0(0002)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.272*kW)
!F34E
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135837S)
0-0:96.14.0(0002)
1-0:1.7.0(00.369*kW)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
!EEEB
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135847S)
1-0:1.8.2(005932.332*kWh)
0-0:96.14.0(0002)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.274*kW)
1-0:61.7.0(00.076*kW)
!74E3
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135857S)
1-0:1.8.2(005932.334*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.370*kW)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
!DF84
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135906S)
1-0:1.8.2(005932.335*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.365*kW)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.269*kW)
!EC55
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135916S)
1-0:1.8.2(005932.336*kWh)
0-0:96.14.0(0002)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.273*kW)
!A2C8
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135926S)
1-0:1.8.2(005932.337*kWh)
0-0:96.14.0(0002)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.275*kW)
!7FE2
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(160901135936S)
1-0:1.8.2(005932.338*kWh)
0-0:96.14.0(0002)
0-0:96.7.21(00009)
0-0:96.7.9(00003)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(001*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
!FF03
mvveelen
Postby mvveelen » Thursday 01 September 2016 14:05
Since this last update I'm losing readings from the P1 meter. Last update is from 12:16, and now it's 14:04. Don't know if this has anything to do with this, but I think it's good to mention in this thread.
Edit: restarted the Synology and now the readings are back again....
Return to “Bugs and Problems”
