[Plugin now available in Beta] Help with Yeelight Bulb
Derik
Target OS: Raspberry Pi
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by Derik » Saturday 06 January 2018 13:31
Thanks...
The trick "Lan beheer" does the job..
Also in android..
xxx
ErikJ
Post by ErikJ » Sunday 07 January 2018 14:28
Boredcat wrote:
Saturday 06 January 2018 10:40
Derik wrote:
Thursday 04 January 2018 12:53
Dear All.
Is there perhaps someone that have the "new" app working from the yeelight bulb?
In the old app new how to set the bulb in developermode..
Only i cannot fin this in the new app...
Hope there is some one smarter then myself:-)
thanks
How to go developermode in the Yeelight app.
Select the light
In the right down corner (Ios App) there is a triangle with a line below, select that.
The you see LAN Beheer (With be named differently in the English app)
Select that and you can enable/dsiable develop mode
Thanks!!
chrispazz
Post by chrispazz » Wednesday 24 January 2018 16:20
Any news about the switch status update when wall switch is powered off?
thank you
madrian
Post by madrian » Friday 26 January 2018 22:36
+1
Derik
Post by Derik » Sunday 18 February 2018 16:05
dear all...
My Android app from yeelight is updated..
Now i can see candle and romance and etc scenes
I like to have this script into Domoticz...
Is ther perhaps someone that have this scripts working??
Script or plugin or??
Thanks!!!
My wife will make love when i set the bulb in to romance...:-)
So hope for a fast ....
xxxx
madrian
Post by madrian » Friday 02 March 2018 22:50
Derik
Post by Derik » Tuesday 03 April 2018 7:21
dear all..
Are there more people that have strange working yeelight after te last update:V3.9168 Build Hash: 5f4b6858 Build Date: 2018-04-02 15:54:41
2018-04-03 07:16:44.669 Yeelight::udp_server::HandleIncoming found set_ct_abx
2018-04-03 07:16:44.669 Yeelight::udp_server::HandleIncoming found set_rgb
2018-04-03 07:16:44.669 Yeelight::udp_server::HandleIncoming found set_rgb and set_ct_abx
2018-04-03 07:16:44.669 Yeelight::udp_server::HandleIncoming mode: 1, Support: get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust adjust_bright adjust_ct adjust_color set_music set
2018-04-03 07:16:44.670 Yeelight::InsertUpdateSwitch colorMode: 1, Bri: 55, Hue: 290, Sat: 100, RGB: 14156031, CT: 4000
2018-04-03 07:16:44.670 YeeLight: New Light Found (192.168.5.33/YeeLight LED (Color))
2018-04-03 07:16:44.671 Yeelight::udp_server::HandleIncoming found set_ct_abx
2018-04-03 07:16:44.671 Yeelight::udp_server::HandleIncoming found set_rgb
2018-04-03 07:16:44.671 Yeelight::udp_server::HandleIncoming found set_rgb and set_ct_abx
2018-04-03 07:16:44.671 Yeelight::udp_server::HandleIncoming mode: 1, Support: get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust set_music set_name
2018-04-03 07:16:44.671 Yeelight::InsertUpdateSwitch colorMode: 1, Bri: 100, Hue: 204, Sat: 100, RGB: 16711680, CT: 2700
2018-04-03 07:16:44.671 YeeLight: New Light Found (192.168.5.32/YeeLight LED (Color))
2018-04-03 07:16:44.672 Yeelight::udp_server::HandleIncoming mode: 1, Support: get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust adjust_bright adjust_ct adjust_color set_music set
2018-04-03 07:16:44.672 Yeelight::InsertUpdateSwitch colorMode: 1, Bri: 100, Hue: 229, Sat: 100, RGB: 16762624, CT: 4000
2018-04-03 07:16:44.672 YeeLight: New Light Found (192.168.5.35/YeeLight LED (Color))
2018-04-03 07:16:44.672 Yeelight::udp_server::HandleIncoming found set_ct_abx
2018-04-03 07:16:44.672 Yeelight::udp_server::HandleIncoming found set_rgb
2018-04-03 07:16:44.672 Yeelight::udp_server::HandleIncoming found set_rgb and set_ct_abx
2018-04-03 07:16:44.672 Yeelight::udp_server::HandleIncoming mode: 1, Support: get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust set_music set_name
2018-04-03 07:16:44.672 Yeelight::InsertUpdateSwitch colorMode: 1, Bri: 85, Hue: 228, Sat: 100, RGB: 13311, CT: 4000
2018-04-03 07:16:44.672 YeeLight: New Light Found (192.168.5.30/YeeLight LED (Stripe))
2018-04-03 07:16:44.673 Yeelight::udp_server::HandleIncoming found set_ct_abx
2018-04-03 07:16:44.673 Yeelight::udp_server::HandleIncoming found set_rgb
2018-04-03 07:16:44.673 Yeelight::udp_server::HandleIncoming found set_rgb and set_ct_abx
2018-04-03 07:16:44.673 Yeelight::udp_server::HandleIncoming mode: 2, Support: get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust set_music set_name
2018-04-03 07:16:44.673 Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 359, Sat: 100, RGB: 16711680, CT: 4000
2018-04-03 07:16:44.673 YeeLight: New Light Found (192.168.5.34/YeeLight LED (Color))
I see some bulbs, that have the old ip adres..
I cannot change te name of the bulbs, some with the same name?
Is there someone with a solution?
airmarshall
Post by airmarshall » Monday 04 June 2018 16:33
I recently moved my domo install to an Rpi3+ and used the beta available at the same time: v3.9317
Prior to this I was using Xiaomi wireless switches to toggle yeelights using the following dzvents script, it worked perfectly:
    active = true,
        devices = {
            '$Wireless Switch 1', '$Wireless Switch 2'
    execute = function(domoticz, switch)
        if (switch.state == 'Click' and domoticz.devices('Master').state ~= 'On') then
            domoticz.log('Master Night On')
            domoticz.setScene('Master Red 1%', 'On')
            switch.switchOff()
        elseif (switch.state == 'Click' and domoticz.devices('Master').state ~= 'Off') then
            domoticz.log('Master Off')
            domoticz.devices('Master').dimTo(0)
            switch.switchOff()
        elseif (switch.state == 'Double Click' and domoticz.devices(43).state ~= 'On') then
            domoticz.log('Nursery Night On')
            domoticz.setScene('Nursery Red 1%', 'On')
            switch.switchOff()
        elseif (switch.state == 'Double Click' and domoticz.devices(43).state ~= 'Off') then
            domoticz.log('Nursery Night Off')
            domoticz.devices(43).dimTo(0)
            switch.switchOff()
        elseif (switch.state == 'Long Click' and domoticz.devices('$status_NightMode').state == 'Off') then
            domoticz.log('Night Mode On')
            domoticz.devices('$status_NightMode').switchOn()
            switch.switchOff()
Since the change, if the yeelight is switched on via the script, then the script won't switch it off. If you switch the yeelight on via other means, like the web gui or mobile app, then the wireless switch script will switch it off.
If the light is off, the wireless switch will switch it on as appropriate.
I have tried both .switchOff() and .dimTo(0) commands.
Really annoying and the WAF has gone through floor. Any help much appreciated....
****UPDATED 11 June 2018****
Fixed it in the end by using direct commands to the buld via a modified script pasted below for info:
    active = true,
        devices = {
        if (switch.state == 'Click' and domoticz.devices(57).state ~= 'On') then
            runcommandon = " sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\": [\"color\", 16711680, 1]}\\r\\n' | nc -w1 192.168.50.72 55443 ";;
            os.execute(runcommandon);
            domoticz.devices(57).dimTo(1)
            switch.switchOff()
        elseif (switch.state == 'Click' and domoticz.devices(57).state ~= 'Off') then
            domoticz.devices('Master').switchOff()
            switch.switchOff()
            runcommandon = " sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\": [\"color\", 16711680, 1]}\\r\\n' | nc -w1 192.168.50.73 55443 ";;
            domoticz.devices(43).dimTo(1)
            switch.switchOff()
            switch.switchOff()
The additional
ensures domoticz knows instantly the light is on as feedback from the yeelight to domo isn't instant. Script could probably be tidier but solves this problem for now!
