Notifymyandroid results in error, although key is OK Topic is solved
marin849
Target OS: Raspberry Pi
Domoticz version: 2.4xxx
Post by marin849 » Monday 04 July 2016 23:09
I have had the problem for a few months that NMA notification doesn't work so decided to check today.
I have created a new API-key, and tested it with the verify-url, then I sent a test message as an URL-string through the web-browser to check that it works. It does!
Then I tried this on the pi running Domoticz.
pi@pi2 ~ $ wget "https://www.notifymyandroid.com/publicapi/notify?apikey=yesmykeywashere&application=%22Domoticz%22&message=%22test%22&event=%22testevent%22&description=%22inget%22"
That works as well!
Problem is in Domoticz I only get "Problem sending, check API-key" when I test the notification, and in the log it only says:
 2016-07-04 23:02:51.080 Error: NMA:
2016-07-04 23:02:51.080 Error: Notification sent (nma) => Failed
Verbose logging is enabled.
It is difficult too see what is wrong, as the error message is blank. I have Domoticz 3.5274. Any Ideas?
marin849
Re: Notifymyandroid results in error, although key is OK
Post by marin849 » Friday 15 July 2016 0:39
Can anyone confirm that their NMA-notification is working?
DomoOr1981
Domoticz version: 3.8373
Post by DomoOr1981 » Friday 08 September 2017 12:37
I too, have the same problem and I'am curious how other boardmembers realized their Notifications (through NMA?).
This verify-test went fine (of course <my-api-key> was replaced by my own 48-char-api-key).
https://www.notifymyandroid.com/publica ... my-api-key>
My Browser returned:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<nma>
<success code="200" remaining="995" resettimer="30"/>
</nma>
Also, this notify-test went fine.
https://www.notifymyandroid.com/publica ... n=DomoDesc
<nma>
<success code="200" remaining="996" resettimer="32"/>
</nma>
And a little later this "popupped" on my phone:
But I cannot get it to work in Domoticz. The testbutton in Domoticz result in (the log):
2017-09-08 11:46:29.122 Error: NMA:
2017-09-08 11:46:29.123 Error: Notification sent (nma) => Failed
2017-09-08 11:46:29.161 Active notification Subsystems: nma (1/12)
"Who o who" has got the solution?
Thank you for your help.
DomoOr1981
Post by DomoOr1981 » Tuesday 12 September 2017 13:57
At last everything works fine now on my "RPi 1 B+" after a fresh installation with this older image: "2017-07-05-raspbian-jessie-lite.img" (my starting-trials were with different versions of Raspbian Stretch Lite).
SweetPants
Domoticz version: V4.9701
Post by SweetPants » Tuesday 12 September 2017 14:21
If you read the forum, you would have seen there are some problems with the latest Beta's concerning HTTP(s) mainly related using Stretch
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
DomoOr1981
Post by DomoOr1981 » Sunday 17 September 2017 14:11
I can't read the whole forum the whole time ;)
So, to which topic(s) are you referring?
marin849
Post by marin849 » Monday 13 November 2017 18:17
I just did a new install with Raspbian stretch lite and I have the same exact problem in both the new installation and the old installation, running Raspbian Wheezy. I am also curious which thread that is mentioned.
Denny64
Domoticz version: 3.8153
Post by Denny64 » Wednesday 11 April 2018 19:28
