Pass2PHP
Egregius
Re: Pass2PHP
Post by Egregius » Wednesday 23 May 2018 9:10
Lol, seems I have superfast disks :lol:
sincze
Target OS: Raspberry Pi
Domoticz version: 3.8875
Re: Pass2PHP
Post by sincze » Wednesday 23 May 2018 20:55
A well, because we now can :D read the usage of a Unifi AP-AC-LR :D
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
gimic
Domoticz version: 3.66
Re: Pass2PHP
Post by gimic » Tuesday 19 June 2018 22:21
Is it normal that when no events ocure that the _cron60.php is not executed every 60 seconds? or am i missing something?
Tnx
Egregius
Re: Pass2PHP
Post by Egregius » Tuesday 19 June 2018 23:36
If you don't trigger the script by cron yes. If you have lot's of devices it gets triggered automatically.
I shall post my cron script tomorrow, or it could be on github.
gimic
Re: Pass2PHP
Post by gimic » Wednesday 20 June 2018 13:27
ok, tnx there is a cron.sh file on git but i don't think that that is the file i need.
Egregius
Re: Pass2PHP
Post by Egregius » Wednesday 20 June 2018 14:56
That's the one ;)
https://github.com/Egregius/LUA-Pass2PH ... re/cron.sh
You can adjust the sleeps in it and remove lines as needed.
Add it to cron with sudo crontab -e
* * * * * /path/to/script/cron.sh
The script will also check if domoticz is still online and reboot if needed.
gimic
Re: Pass2PHP
Post by gimic » Wednesday 20 June 2018 19:58
Works, needed also jq package installed ;-)
Egregius
Re: Pass2PHP
Post by Egregius » Wednesday 20 June 2018 20:20
Great!
Enjoy pass2php ;)
gimic
Re: Pass2PHP
Post by gimic » Thursday 21 June 2018 22:37
Do you have an example or an idea how i can create a button with following function
First time pressed: change status of blinds to ON
Second time pressed: change status of blinds to Stop
Third time pressed: change status of blinds to Off
Fourth time pressed: change status of blinds to Stop
Fifth time pressed: change status of blinds to On
etc...
how can i remember in php the blinds two steps in history so i know if it is stopped i need to do On or Off the next time it is activated?
