Script (NodeJS): Chromecast status to virtual device
dhanjel
Domoticz version: 3.5146
Post by dhanjel » Tuesday 07 June 2016 18:18
This is a simple script to get information pushed into Domoticz when chromecasts changes state to/from playing and idle.
(Just a basic script, it is possible to control chromecasts as well through https://www.npmjs.com/package/nodecastor).
My plan is to adjust the light on RGB-lists behind the tv:s depending on the source.
Create a virtual device (switch) for each Chromecast you want status on.
Install nodejs (preferably with pm2 in order to have the service running at startup).
Install the required libraries (npm install.. ): underscore, nodecastor, request.
Save this script and start it in node.js (after configuration):
var _ = require("underscore");
var nodecastor = require('nodecastor');
var request = require('request');
//Settings
var domoticzIp = "192.168.1.200";
var domoticzPort = 8080;
var playerLookup = [
	{ Name: 'Sovrum', Id: 178},
	{ Name: 'Vardagsrum', Id: 179},
	{ Name: 'Allrum', Id: 180},
	{ Name: 'Matsal', Id: 181}
function deviceIsPlaying(deviceStatus) {
	if (deviceStatus.applications === undefined)
		return false;
	var match = _.find(deviceStatus.applications, function(item, index) {
		if (item.displayName != 'Backdrop')
			return true;
	return !(match === undefined);
function lookupDeviceId(deviceName) {
	var match = _.find(playerLookup, function(item, index) {
		if (item.Name === deviceName)
			return true;
	return (match === undefined) ? -1 : match.Id;
function updateDomoticz(playerId, isPlaying) {
	if (playerId < 0)
		return;
	var url = "http://" + domoticzIp + ":"  + domoticzPort +
				"/json.htm?type=command&param=switchlight&idx=" + playerId +
				"&switchcmd=" + (isPlaying ? "On" : "Off");
	request(url, function (error, response, body) {
		if (!error && response.statusCode == 200) {
			console.log(body)
function localServer() {
	//Chromecast scanner
	nodecastor.scan()
	  .on('online', function(d) {
		var playerName = d.friendlyName;
		var playerId = lookupDeviceId(playerName);
		d.on('connect', function() {
		  d.status(function(err, s) {
			if (!err) {
				var devicePlaying = deviceIsPlaying(s);
				d.on('status', function(status) {
				updateDomoticz(playerId, devicePlaying);
	  .on('offline', function(d) {
	  .start();
console.log("Starting server");
localServer();
The values under //Settings needs to be adapted.
IP and port to Domoticz and an array with mapping from chromecast name to virtual device id in Domoticz (can be found on http://domoticz_ip:domoticz_port/json.htm?type=devices.
Heisenberg
Target OS: Raspberry Pi
Re: Script (NodeJS): Chromecast status to virtual device
Post by Heisenberg » Friday 17 June 2016 10:47
Thanks for the script. Is there a way to automatically start a (youtube) stream with the virtual switch?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
rednas
Post by rednas » Monday 04 July 2016 16:29
Would it be possible to add this to a future version of Domoticz, like Logitech Media Server & Kodi are included?
dhanjel
Post by dhanjel » Monday 04 July 2016 19:08
This is my old play script for chromecast audio, I have not yet adapted it and modernize it. But could be something to start with.
var http = require('http');
var chromecastjs = require('chromecast-js')
var port = 8001;
var server = http.createServer(function (request, response) {
  response.writeHead(200, {"Content-Type": "text/plain"});
  var url = require('url');
  var url_parts = url.parse(request.url, true);
  var query = url_parts.query;
  if (query.action === undefined) {
	  response.end();
  else {
	console.log("Incoming request.");
	console.log("Device: " + query.device);
	console.log("Action: " + query.action);
	var browser = new chromecastjs.Browser();
	browser.on('deviceOn', function(device){
		if (device.config.name == query.device) {
			console.log("Connected to target device, " + query.device + ".");
			device.connect();
			device.on('connected', function(){
				if (query.action === "play") {
					if (query.volume !== undefined) {
						var targetVolume = (query.volume === undefined ? 0.2 : query.volume);
						device.setVolume(targetVolume, function() {
							console.log ("Volume set to " + (targetVolume*100) + "%.");
							device.play(query.stream, 0, function(){
								console.log('Playing stream: ' + query.stream);
								response.end();
					} else  {
								response.end();
				} else if (query.action === "stop") {
					device.stop(function(){
						console.log('Stopped!')
						response.end();
server.listen(port);
console.log("Server started on port " + port)
DarkFoxDK
Post by DarkFoxDK » Saturday 26 November 2016 16:17
I'm not sure how your code was working before. For me it would only update devices when starting the script.
I've modified the localServer function to make it work correctly:
  nodecastor.scan()
          if (!err) {
      d.on('status', function() {
          if (!err) {
    .start();
meanmrgreen
Post by meanmrgreen » Saturday 03 December 2016 23:43
Sorry for this but im not used to linux and such.
HOW do i install this thing step by step on a raspberry 3?
turnhob
Post by turnhob » Sunday 11 December 2016 19:41
Any help would be nice.
I changed the settings and when I start it on my raspberry it says "Starting Server".
But nothing seems to happen after that.
None of my chromecast switches change status when i play content from youtube.
Im a little bit of a newbie so any help (or directions) would be nice.
turnhob
Post by turnhob » Friday 16 December 2016 19:59
turnhob wrote:Any help would be nice.
I fixed it myself. Thank you for the script.
Is it possible to see if its playing or is it only possible to see if an app is loaded on the Chromecast device?
meanmrgreen
Post by meanmrgreen » Tuesday 03 January 2017 11:17
how did you fix it?
chrisfraser05
Post by chrisfraser05 » Sunday 05 February 2017 2:04
This is interesting. I'll have to try this tomorrow
DewGew
Domoticz version: V4.9741
Post by DewGew » Thursday 28 June 2018 14:33
I updated my rpi to stretch and now my script is not working. I reinstalled node.js and underscore, require and nodecastor. Still not working.
Anyone with idea who can help me??
Raspberry Pi 2B - domoticz - Aeon Labs Z-Stick GEN5 - RFlink gateway
NanoPi NEO-air - domoticz - REGO6XX interface
Dashticz V2 - Homebridge
freijn
Post by freijn » Friday 29 June 2018 9:24
Perhaps show us the error you are hitting?
DewGew
Post by DewGew » Monday 02 July 2018 14:56
I got no erros ..
