TH12 - Imagintronix Moisture sensor
mvdwetering
Target OS: Raspberry Pi
Post by mvdwetering » Saturday 28 May 2016 12:19
Does anyone recognize this problem: I've bought a XT300 moisture sensor. In RFXcom manager the sensor shows up, but in Domoticz (v3.4834) it is not seen. Even when I put the sensor next to my RPI.... strange. Any solution?
Marten.
Packettype = TEMP_HUM
subtype = TH12 - Imagintronix
channel 2
Sequence nbr = 94
ID = 2
Temperature = 24 °C
Humidity = 99
Status = Wet
Signal level = 5 -80dBm
Battery = OK
robpow
Domoticz version: Beta :)
Re: TH12 - Imagintronix Moisture sensor
Post by robpow » Saturday 28 May 2016 13:07
I just added three of them to my setup and they showed up just fine after enabling the protocol in Domoticz. I'm in the latest beta version of Domoticz and Type 1 ver 1001 of RFXtrx.
The only drawback is they are very chatty and with three of them transmitting it looks like they are blocking some of my Oregon temperature sensors from time to time.
If they could be slowed down to only transmit say every five minutes it would probably help.
Matt
mvdwetering
Post by mvdwetering » Saturday 28 May 2016 22:27
I did some more research.
It is a transmissionproblem of the sensor. Within 50cm of the antenna it works, a little bit more distance and the signal is lost. The 17 cm replacement antenna I bought for my trx433 does not receive anything from this sensor, while all the other devices are working fine. The original antenna does receive the signal, but only form close by.
So.... i've sent an email to www.plantcaretools.com
mvdwetering
Post by mvdwetering » Sunday 05 June 2016 11:32
Great service from Guido at Plantcare Tools. I received a new sensor free of charge to repliceren the defective one! Probleem solved.
robpow
Post by robpow » Sunday 05 June 2016 14:17
That's good news!
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 » Monday 26 September 2016 18:56
I use the tx300 now in our vegetable garden (in the netherlands) for one week now. On the internet and on this forum i searched for below which humidity level i should irrigate. I could not find this question/answer.
What is your experience?
Rp3, youlesss, rfxcom, philips hue, dsb1820
ESFnl
Domoticz version: 3.4834
Post by ESFnl » Friday 14 October 2016 21:28
Not quiet sure if I may reply to this topic with a new question or should start a new topic... but I have the same device and thought this would be the best place?
I bought two Imagitronix moisture sensors. One of them is found by Domoticz immediately, the other isn't found at all. Reinstalling the batteries didn't work. Any suggestions?
The second issue is with the sensor that is found. The humidity level is switching between 100% and 0% constantly. Is this a matter of tuning the software side or maybe a hardware issue?
Rf433 soil moisture sensor.png (147.66 KiB) Viewed 1461 times
Amsterdam020
Post by Amsterdam020 » Tuesday 18 October 2016 20:02
perhaps it helps when you change the channel on the device
astrapowerrr
Post by astrapowerrr » Tuesday 10 July 2018 21:22
hi all,
i just bought this sensor. but i just cant figure out how to connect.
can someone help me with this?
Fixed it. Had to set learn just when the sensor starts flashing then domoticz connected.
Amsterdam020
Post by Amsterdam020 » Tuesday 10 July 2018 22:23
If you filter under setup devices for 'Imagintronix' you should get a result like
10 rfx 0001 1 Makkelijke Moestuin Temp + Humidity Imagintronix 18.0 C, 5 % 5 100 Set UnusedRename Device Log 2018-07-10 22:18:25
