user access or property administration
thaui
Target OS: Raspberry Pi
Post by thaui » Tuesday 19 April 2016 11:52
Is there any property administartion planned for domoticz? I mean can an administrator handle the settings while a user (most of the people in a living place) can only use the rest of the system? This will also give the advantage to use the system in smaller offices.
Bikey
Domoticz version: 3.xxx
Re: user access or property administration
Post by Bikey » Wednesday 20 April 2016 9:25
You already can create several users with different authorizations and access to pages. Isn't that sufficient?
thaui
Post by thaui » Tuesday 26 April 2016 11:44
Thanks for your reply. Will try it in the next few days and report if it fullfil my needs.
Skippiemanz
Domoticz version: 3.5859
Post by Skippiemanz » Wednesday 27 April 2016 16:13
You can also grant users access to specific devices. So I think this could be used to achieve you're goal.
Verstuurd vanaf mijn SM-G925F met Tapatalk
Bikey
Post by Bikey » Monday 02 May 2016 12:21
Skippiemanz wrote:You can also grant users access to specific devices. So I think this could be used to achieve you're goal.
How do you configure access to specific devices? I only see how to give access to specific pages.
Skippiemanz
Post by Skippiemanz » Monday 02 May 2016 21:02
Go to users, and in the same rol as active, name and rights you will find devices.
Verstuurd vanaf mijn HTC One_M8 met Tapatalk
Bikey
Post by Bikey » Tuesday 03 May 2016 16:35
Skippiemanz wrote:Go to users, and in the same rol as active, name and rights you will find devices.
Yeah but that is to select if that user has rights to see the whole page of all devices. You can not select individual devices. I guess if you could allow this per room that would be a flexible solution.
lucalg
Post by lucalg » Friday 14 April 2017 0:10
Good evening,
i'm interested too.
My need is to allow a list of users to come inside the parking. So I've created an event for a single user and works great.
Problem is that i have 250 tags to allow. So how to create a "you can park inside"list to work with event?
Tnx,
Luca
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Thursday 11 May 2017 23:25
Is this working?
I have created a new user and set devices/tabs to see but every time I try to log in it says incorrect username/password when logging from outside.
Maybe is my device that I have tampered quite a lot with lately....
11101101 - www.machinon.com
sincze
Post by sincze » Sunday 23 July 2017 14:19
EdddieN wrote:Hello,
Is this working?
Did you find a solution?
I tried to add an extra user as viewer today and have the same issue.
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
EdddieN
Post by EdddieN » Monday 24 July 2017 10:39
No I didn't but when I tried on a fresh install on a 2nd Domoticz to connect to it remotely from another Domoticz it did work. So I assumed it was my 1st one that I had messed a fair bit with it.
sincze
Post by sincze » Thursday 26 April 2018 22:41
Is this working?
Mmm I'm still having the same issue.
Wanted to add a user to allow controlicz a way in. However I'm unable to login with a newly created user..
2018-04-26 22:38:42.177 Error: Failed login attempt from xx.XXX.XXX.XX for user 'test' !
2018-04-26 22:39:08.931 Error: Failed login attempt from xx.XXX.XXX.XX for user 'test' !
1 have 1 user account (old old ancient) that is able to login... However all newly created accounts are not.
USB: RFXCom, ZWave
EdddieN
Post by EdddieN » Thursday 26 April 2018 23:50
I just tried to create a new one and log in externally with a Tor browser... same problem than before. Incorrect user/password. But I must mention that it is the same machine than before was giving me problems.
Have you tried on a different installation?
sincze
Post by sincze » Friday 27 April 2018 11:38
This is a new installation on new HW, however, same old DB :D
Really strange
So 1 user that is already in the DB is working.
I created an additional one with username 'test' and pwd: 'test987' not working.... incorrect user/password.
If I open the DB with sql browser (ok username + pwd is hashed , excellent) the rest of the settings 'Active' , 'Rights', 'TabsEnabled" look the same. Beats me.
USB: RFXCom, ZWave
EdddieN
Post by EdddieN » Friday 27 April 2018 17:59
Ok, I just tried from outside my network and this way it works. I can create a new user from scratch or copy one and works fine.
Yesterday was trying from within my network, I wonder if it has to do with some conflict with the Settings page of asking for login for any IP not whitelisted?
tudimon
Post by tudimon » Saturday 28 July 2018 18:55
Hello friends, can you help me?
I want to give limited access to my child in the domoticz - only two switches he can to switch.
I create user "artur" and gave him access to the tabs "switches" and "temperature" only. After that I give him access only several devices:
When user Artur logged in domotics use Mobile Chrome it work correctly:
He can view and can control only two switches.
But if he use app Domotics Lite, he can see and manage more - Events, User variables and Scenes.
How to limit access to user Artur in app Domotics Lite?
[offtop]Sorry for my bad english[/offtop]
tudimon
Post by tudimon » Saturday 28 July 2018 19:42
other screenshots:
