Step by step guide: Sonos integration
josimd
Re: Step by step guide: Sonos integration
Post by josimd » Sunday 16 September 2018 14:02
its exactly the same
Schermafbeelding 2018-09-16 om 13.59.21.png (312.64 KiB) Viewed 282 times
Holland
Target OS: Raspberry Pi
Domoticz version: Beta Ch
Post by Holland » Sunday 16 September 2018 14:15
Almost out of idea's. Apparently the link between the button and the device is gone.
I would delete the selector switch and the dummy.
Then recreate a dummy for each Sonos group/or device. Recreate the selector switch for each Sonos group/or device
josimd
Post by josimd » Sunday 16 September 2018 19:29
yes that did the trick! its working now in Domoticz. Do you also how to run the api continuously, now, when I close the terminal de pipe is broken. Is there an option within synology which I can use?
Holland
Post by Holland » Sunday 16 September 2018 21:00
The solution is PM2, but I have it running on a RPi. See also the first post in this threat.
Don't know if PM2 can run on a synology.
josimd
Post by josimd » Friday 21 September 2018 18:42
I have it running on my synology NAS, instead of PM2 you can run node server.js via another way, see link below.
https://www.youtube.com/watch?v=tkbu3TT5LT8
