Step by step guide: Sonos integration
leecollings
Target OS: Raspberry Pi
Re: Step by step guide: Sonos integration
Post by leecollings » Wednesday 31 May 2017 17:09
Yes, you can select just one speaker. Check out the documentation for the full list of commands you can use: https://github.com/jishi/node-sonos-http-api
E.g.
/{Room name}/clip/{filename}[/{announce volume}]
/clipall/{filename}[/{announce volume}]
Examples:
/clipall/sample_clip.mp3
/clipall/sample_clip.mp3/80
/Office/clip/sample_clip.mp3
/Office/clip/sample_clip.mp3/30
Heursqem
Post by Heursqem » Tuesday 06 June 2017 19:31
leecollings wrote:
Heursqem wrote:This is what I would love to achieve
#1 - Someone pushes my doorbell
#2 - I capture the current state of my sonos player (medium, song, volume etc) and save this for later
#3 - I play my own sound through the sonos player (ding-dong)
#4 - I go back to to captured/saved state and listen to original music again
Would all of this be possible with this solution?
Hey, you can already do this with the clipall command (if you want to play the announcement through all Sonos devices on your network).
You can handle all of the above by using:
http://localhost:5005/clipall/name-of-your-mp3.mp3
(store your mp3 file in /static/clips/)
Works awesome, thanks!!!!
junr
Post by junr » Sunday 18 June 2017 12:18
ironrider wrote:Hi,
i have to start server.js after a Domoticz reset.
Is ist possible to make the server.js running as a service.
Thanx
Sven
Sven,
Go to the api directory
cd node-sonos-http-api
Start de pm2 server
 sudo pm2 start server.js
Save the process
 sudo pm2 save
The pm2 will save the running process.
Sudo reboot
It works fine now
Greetz JUNR
RFXcom | Toon | Zware | Sonos |
RezzZ
Post by RezzZ » Friday 15 September 2017 17:40
Hi guys, I'm trying to get this working for my sonos system and got the api working.
problem now is to create that dummy device and switch:
9. Create a selector switch (create a dummy device and pick selector switch in the list of virtual devices ) according to the below images;
How do I create a dummy device? The device page doesn't allow me to create devices..
I can create new hardware (1-Wire (System)) but it will not create any devices I can use for the selector.
What am I missing?
junr
Post by junr » Sunday 17 September 2017 17:43
RezzZ
Create a Dummy switch in the hardware tab
Make a virtual sensor with Selector Switch.
in the device tab you select the dummy with
Hope it helps.
Greetz Junr
RezzZ
Post by RezzZ » Monday 18 September 2017 10:30
thanks Junr! I totally missed the dummy switch as a hardware device but it is really in the list...
thanks again!
RezzZ
Post by RezzZ » Monday 18 September 2017 11:19
any chance someone has already created a transparant icon set for sonos?
the file from dhanjel (posted 8-6-2016) has white corners, not transparant.
royson
Post by royson » Friday 10 November 2017 22:46
Hi guys.
Im new here and have tried this great solution, but I have wierd problem.
Im running my domoticz installation with https and the switch sends commands in http. Not sure if this is the problem but it doesnt work. If I send the command directly in the browser with http it works, so the api is active. But if I use the exact same link on a selector in domoticz, nothing happends.
Which log can I start searching in for clues?
Thanks in advance for any help.
royson
Post by royson » Saturday 11 November 2017 10:23
royson wrote:Hi guys.
Edit:
I figured it out. Nothing to do with the encryption fortunately. Domoticz just wasnt able to convert the space in "dining room". All sorted now =)
Next step is adding TTS.
Sent from my LG-H815 using Tapatalk
BakSeeDaa
Post by BakSeeDaa » Monday 27 November 2017 13:26
Hi there!
I just had a look at the node-sonos-http-api. I haven't tried it yet, (still waiting for 2 pcs Sonos One to be delivered) but it looks really nice.
I also had a quick look at the LUA script in the initial post. It seems to be a device triggered script so it will run whenever a device changes in Domoticz. That can happen quite often and will put some burden on the Domoticz server for sure.
Looking a bit closer at node-sonos-http-api I see that there is support for a web hook. That sounds promising because using that, Domoticz wouldn't have to do polling the API for changes. Instead Domoticz can be "push noticed" whenever there is a status change. It should be much faster and more efficient than polling. One small problem is that Domoticz currently doesn't have a way to trigger a specific script using the API. Therefore to use the web hook functionality we'd need some software to interpret whats coming in and inform Domoticz about it. That wouldn't be so hard to do.
I've started a nodejs project to intercept events from node-sonos-http-api using web hooks and use them to inform Domoticz. I'll let you know when I have been able to test it in case someone is interested.
MiWa4711
Post by MiWa4711 » Tuesday 02 January 2018 12:18
I am a beginner started with domoticz 8 weeks ago. Now after all my lights are integrated I am looking for sonos.
Did installation following step by step guide but failed.
Can anyone please help me?
Thanks.
MiWa4711
Post by MiWa4711 » Saturday 06 January 2018 18:22
Dear all,
now it runs. Juhu....
RedFish
Post by RedFish » Thursday 08 February 2018 20:34
Dear all,
How you do it...i've got same problem !!!
EDIT: It's good for me.........It's alive !!! :D :D :D
AllesVanZelf
Post by AllesVanZelf » Friday 14 September 2018 10:49
Heursqem wrote:
Wednesday 31 May 2017 13:22
But how could I store the actual state, so I can resume after the clipall command?
leecollings wrote:
Wednesday 31 May 2017 14:06
It stores the current state within the command. Try it out and you'll see.
I've tested it, with a Play 1 playing a song, it pauses, plays the mp3 file, and then resumes the previously playing song.
I noticed that this is not always working well. I have two sonos-speakers.
If I send a clipall command to the sonoses, the sounds plays well on both speakers, but afterwards the music does not continue where it was. I think the music starts on the playlist from one of the speakers, not always the right one.
But if I send the command to both speakers separately (two links), it works well.
Just for the record 8-)
It might be a coding error?
josimd
Post by josimd » Saturday 15 September 2018 21:31
Gents, installed in on my Synology NAS, and can start / stop my Sonos speakers via the URL in my browser. But is doesn't start with the selector switch in Domoticz when im using the same url... Fout bij verzenden van schakelaar opdracht, controleer apparaat/hardware!
Anyone?
Holland
Domoticz version: Beta Ch
Post by Holland » Saturday 15 September 2018 23:35
@josimd
Should work. Can you share the url that you use to let it start playing
josimd
Post by josimd » Sunday 16 September 2018 10:13
Thanks for reply;
in my browser: http://192.168.86.136:5005/woonkamer/play
(small think is when I use http://192.168.86.136:5005/woonkamer/pauze it doesn't stop)
and I use the same in Domoticz;
But then I get the error
Holland
Post by Holland » Sunday 16 September 2018 12:30
The following url should be changed ;
to
http://192.168.86.136:5005/woonkamer/pause
What is the version of Domoticz you are running. Because, some time ago there were some issues with the selector switch. But that has been resolved.
josimd
Post by josimd » Sunday 16 September 2018 13:14
I'm running on V4.9700 (synology)
Holland
Post by Holland » Sunday 16 September 2018 13:30
Is new enough.
Can you check again, if your setup similar to the below;
