Equivalent to Pirack for Piface Digital 2 Topic is solved
Moderator: fantom
Michel13
Target OS: Raspberry Pi
Domoticz version: Stable
Post by Michel13 » Saturday 27 February 2016 18:36
For my project, I would like to use at least 2 Piface Digital 2 on one Rasp PI2.
I thought the Pirack was the good thing for adding cards to the GPIO, so I have ordered one.
Alas, the Piface Pirack cannot accomodate the Piface Digital 2 : the GPIO connector of the card is bigger thus it bump into the jumpers on both sides of each connector of the Pirack. In addition, the 5V connector is also an obstruction on the first connector. Great ! :roll:
Why Piface does not produce a Pirack compatible with their own products ?
So now, I am still looking for a solution to connect more than one Digital 2 on a Rasp.
Do you have any idea, product or solution to achieve that goal ?
Michel
Michel13
Re: Equivalent to Pirack for Piface Digital 2
Post by Michel13 » Tuesday 01 March 2016 13:06
I am very surprised that nobody have had to face the same impossibility to match the Digital 2 with Pirack.
I have finally solved the problem and I give here my solution in case it could help somebody.
I have simply removed the barrel jack and the jumpers pins JP1 to 8, and solder them on the other side of the board. As pins of the barrel jack are reversed, I have done an external wiring to connect the negative pin to the board.
No change is necessary on JP9 to 12.
For addressing the Digital :
On Digital boards : JP1 and 2 must be set to the proper address board, with JP1 and 2 to 0 on board 0, JP1 to 1, JP2 to 0 on board 1, etc (see Digital doc)
On the Pirack : set JP1 to 8 where Digital are installed from default SPI CE to Swapped SPI CE lines (see Pirack doc). Don't ask why, but the default setting does not work.
In Domoticz : add the necessary lines in piface.conf file to include the additional digital boards. For instance, for output 0 and input 0 of board 1 :
piface.1.output.0.enabled=true
piface.1.output.0.pin_type=level
piface.1.output.0.count_enabled=true
piface.1.output.0.count_update_interval_sec=10
piface.1.input.0.enabled=true
piface.1.input.0.pin_type=level
piface.1.input.0.count_enabled=false
piface.1.input.0.count_update_interval_sec=10
etc....
Enjoy the multi digital 2
mscory
Post by mscory » Monday 19 September 2016 22:55
No you are not alone !
Thank you for your comments. I modified my PiRack and it worked ... without swapping SPI CE. Strange.
Kind regards
Michel
Michel13
Post by Michel13 » Monday 26 September 2016 12:52
Thanks for your feedback. I am glad that it helped you, as it could help many others hopefully.
I have not made much progress on my project since. I did a lot of purchasing and preparation works to implement the future installation of my home automation system. So I cannot currently comment on the usefulness or not of the SPI CE setting. I will test again as soon as possible.
Michel
