How to check presence of Beacon ?
Busmeikel
Target OS: Raspberry Pi
Domoticz version: 4.9700
RSSI instead of HOME
Post by Busmeikel » Wednesday 05 December 2018 9:29
it was my fault, if you can read that is sometimes a benefit ;-)
In REPEAT-Mode the script writes the RSSI into the user-variable if the tag is present,
in SWITCH-Mode the script writes HOME into the user-variable if the tag is present.
Only for the protocol.
Meikel
EddyG
Domoticz version: 4.10252
Re: How to check presence of Beacon ?
Post by EddyG » Friday 07 December 2018 12:17
I have the following problem.
The script(s) worked fine on my previous hardware Raspberry Pi 3B.
Now I switched to a Raspberry Pi 3B+ on Berryboot Linux domoticzslave 4.14.83v7-aufs #1 SMP Wed Nov 28 22:52:43 CET 2018 armv7l GNU/Linux
The only way I can have the test_beacon.py have normal output is to open a second putty window and issue an sudo bluetoothctl
with the commands "power on' and 'scan on'
After the 'scan on' the output on the first window is normal, but as soon as I stop the bluetoothctl by 'quit' the output on the first window stops.
Anyone any ideas???
Regards,
Eddy
QuadRotas
Re: RSSI instead of HOME
Post by QuadRotas » Thursday 13 December 2018 17:57
Meikel
Did you get your setup to work eventually? And could you share your setup perhaps?
I have everything configured like the wiki manual says but the tags I use are only registered by the script when they're in discovery mode. As soon as they go into normal mode the script doesn't see them anymore.
My Pi3B has been configured according to basic needs so no altered bluetooth settings whatsoever.
Artursd
Post by Artursd » Sunday 16 December 2018 19:15
Hello
root@raspberrypi:/home/pi/scripts# hciconfig
hci1: Type: BR/EDR Bus: USB
BD Address: 00:15:83:F2:26:66 ACL MTU: 310:10 SCO MTU: 64:8
UP RUNNING
RX bytes:9808985 acl:0 sco:0 events:232671 errors:0
TX bytes:19397 acl:0 sco:0 commands:997 errors:0
hci0: Type: BR/EDR Bus: UART
BD Address: B8:27:EB:7C:EC:0A ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN
RX bytes:17615918 acl:75 sco:0 events:405712 errors:0
TX bytes:20594 acl:67 sco:0 commands:969 errors:0
I need to redo the script on Hci1 ????
Artursd
Post by Artursd » Sunday 16 December 2018 19:17
root@raspberrypi:/home/pi/scripts# sudo python /usr/local/bin/check_beacon_presence.py
2018-12-16 19:16:07,274 - root - DEBUG - Ok hci0 interface Up n running !
2018-12-16 19:16:07,274 - root - DEBUG - Connect to bluetooth device 0
2018-12-16 19:16:07,741 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-80,) - DATA unknown (-106,)
2018-12-16 19:16:07,743 - root - WARNING - Tag Nut_Egita seen after an absence of 30 sec : update presence
2018-12-16 19:16:07,770 - requests.packages.urllib3.connectionpool - DEBUG - Starting new HTTP connection (1): 192.168.1.128
2018-12-16 19:16:07,772 - requests.packages.urllib3.connectionpool - DEBUG - http://192.168.1.128:8080 "GET /json.htm?type=command&param=updateuservariable&idx=7&vname=Nut_Egita&vtype=2&vvalue=HOME HTTP/1.1" 401 91
2018-12-16 19:16:07,777 - root - DEBUG - <Thread(Thread-2, started 1968174192)> -> <Response [401]>
2018-12-16 19:16:08,065 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-80,) - DATA unknown (-106,)
2018-12-16 19:16:08,160 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-85,) - DATA unknown (0,)
2018-12-16 19:16:08,169 - root - WARNING - Tag Nut_Arturs seen after an absence of 30 sec : update presence
2018-12-16 19:16:08,173 - requests.packages.urllib3.connectionpool - DEBUG - Starting new HTTP connection (1): 192.168.1.128
2018-12-16 19:16:08,177 - requests.packages.urllib3.connectionpool - DEBUG - http://192.168.1.128:8080 "GET /json.htm?type=command&param=updateuservariable&idx=8&vname=Nut_Arturs&vtype=2&vvalue=HOME HTTP/1.1" 401 91
2018-12-16 19:16:08,184 - root - DEBUG - <Thread(Thread-3, started 1968174192)> -> <Response [401]>
2018-12-16 19:16:08,315 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-88,) - DATA unknown (0,)
2018-12-16 19:16:09,087 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-89,) - DATA unknown (0,)
2018-12-16 19:16:09,357 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-80,) - DATA unknown (-106,)
2018-12-16 19:16:09,398 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-86,) - DATA unknown (0,)
c2018-12-16 19:16:09,676 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-77,) - DATA unknown (-106,)
what is the problem ??
QuadRotas
Post by QuadRotas » Sunday 16 December 2018 19:21
Nothing. You have 2 Bluetooth-controllers, one onboard and one USB. The script takes the one on HCI0, the onboard one.
The output says it detects the 2 tags you defined in the script just fine. If you have set everything correctly in Domoticz you should see the status of the two tags being updated.
Also, what kind of tags do you use? Mine won't stay on so I'm looking for tags that work with the script.
Artursd
Post by Artursd » Sunday 16 December 2018 20:30
Thanks for the quick response. Already found more errors. Corrected on HCI 1. There is already a result
Artursd
Post by Artursd » Sunday 16 December 2018 20:32
2018-12-16 20:31:29,732 - root - DEBUG - Ok hci1 interface Up n running !
2018-12-16 20:31:29,733 - root - DEBUG - Connect to bluetooth device 0
2018-12-16 20:31:29,773 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-85,) - DATA unknown (0,)
2018-12-16 20:31:29,800 - root - WARNING - Tag Nut_Arturs seen after an absence of 30 sec : update presence
2018-12-16 20:31:29,801 - requests.packages.urllib3.connectionpool - DEBUG - Starting new HTTP connection (1): 192.168.1.128
2018-12-16 20:31:29,806 - requests.packages.urllib3.connectionpool - DEBUG - http://192.168.1.128:8080 "GET /json.htm?type=command&param=updateuservariable&idx=8&vname=Nut_Arturs&vtype=2&vvalue=HOME HTTP/1.1" 200 58
2018-12-16 20:31:29,813 - root - DEBUG - <Thread(Thread-2, started 1968174192)> -> <Response [200]>
2018-12-16 20:31:29,833 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-80,) - DATA unknown (-106,)
2018-12-16 20:31:29,834 - root - WARNING - Tag Nut_Egita seen after an absence of 30 sec : update presence
2018-12-16 20:31:29,840 - requests.packages.urllib3.connectionpool - DEBUG - Starting new HTTP connection (1): 192.168.1.128
2018-12-16 20:31:29,843 - requests.packages.urllib3.connectionpool - DEBUG - http://192.168.1.128:8080 "GET /json.htm?type=command&param=updateuservariable&idx=7&vname=Nut_Egita&vtype=2&vvalue=HOME HTTP/1.1" 200 58
2018-12-16 20:31:29,847 - root - DEBUG - <Thread(Thread-3, started 1968174192)> -> <Response [200]>
2018-12-16 20:31:30,232 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-84,) - DATA unknown (0,)
2018-12-16 20:31:30,390 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-85,) - DATA unknown (0,)
2018-12-16 20:31:30,481 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-84,) - DATA unknown (-106,)
2018-12-16 20:31:30,540 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-86,) - DATA unknown (0,)
2018-12-16 20:31:30,691 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-84,) - DATA unknown (0,)
2018-12-16 20:31:30,808 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-83,) - DATA unknown (-106,)
2018-12-16 20:31:31,000 - root - DEBUG - Tag Nut_Arturs Detected 78:bd:bc:da:50:77 - RSSI (-85,) - DATA unknown (0,)
2018-12-16 20:31:31,128 - root - DEBUG - Tag Nut_Egita Detected ed:c5:51:27:23:96 - RSSI (-84,) - DATA unknown (-106,)
Artursd
And when does he stop ????
QuadRotas
Post by QuadRotas » Sunday 16 December 2018 20:36
It doesn't The script continuously scans for the tag and updates Domoticz accordingly. You get this output because you run the script manually. If you end the script, nothing gets scanned. You can configure the script to be ran as a service so it runs all the time, in the background. You won't see anything on your screen. Check out the logging section of the script to reconfigure it so it only writes warnings/errors to the logfile. If you write debug logging to your logfile grows significantly.
Can you let me know what kind of bluetooth tags you use? I'm dealing with my own problems getting this to work.
Artursd
Post by Artursd » Sunday 16 December 2018 20:54
I understand all this, if I constantly scan it, will it not download RP3B ???
Artursd
Post by Artursd » Sunday 16 December 2018 20:57
I still have NUT 2 pcs
Artursd
Post by Artursd » Sunday 16 December 2018 21:01
Variables are already changing, the script is working. There is a concern if he will score RP3b if he constantly scans
Artursd
Post by Artursd » Sunday 16 December 2018 21:02
Пишу с переводчиком, может не все будет понятно
QuadRotas
Post by QuadRotas » Sunday 16 December 2018 21:46
I am not sure what you mean with 'download'?
Thank you.
Do you mean if the Raspberry will overheat, or overload? No, the script is not powerful enough to do that.
Нет проблем :)
It's okay to post multiple replies in 1 post, instead of separate posts
Artursd
Post by Artursd » Monday 17 December 2018 18:40
Hey. This is all a translation. I mean, if BLE scanning is going to happen all the time, Can a large processor loop be? I'm working on RP Domoticz
Artursd
Post by Artursd » Monday 17 December 2018 18:45
Привет. Это все перевод. Если постоянно будет происходить сканирование BLE, как будет загружаться процессор?
emme
Domoticz version: latest
Post by emme » Monday 17 December 2018 19:13
"We always done this way"
