How to update a virtual 'Instant+counter' sensor with Lua
nood
Target OS: Raspberry Pi
Re: How to update a virtual 'Instant+counter' sensor with Lua
Post by nood » Tuesday 03 April 2018 11:30
I just figured out how to scrape the local url too! I shared my python script here
Hieron wrote:
Sunday 01 April 2018 13:20
Only thing I'm still trying to figure out is how to properly show the value for todays output. The correct value from the inverter is 0.440 kWh. So what is the value "Today: 0.060 kWh"?
I think you only have to find the total value, Domoticz will automaticaly calculate the difference with yesterday's total.
Hieron
Post by Hieron » Friday 06 April 2018 20:30
yea it works well, after 1 day the totals and all show up fine.
annegerben
Post by annegerben » Friday 03 August 2018 22:26
gsmink wrote:
Sunday 30 July 2017 11:04
Hi Annegerben,
Can you share the code with the ping option
annegerben wrote: Thanks for your code!
I've been using it quite a while, but recently I've added a ping check so the script doesn't have to run completely when the inverter is offline.
reply is a bit late, sorry.
But I'm using the builtin ping and change the code a bit :
if statement on the switch in the beginning and closing it at the end.
lineNo = 0
now    = 0
temp   = 0
today  = 0
total  = 0
v1     = 0
v2     = 0
i1     = 0
i2     = 0
ip     = 'ip'
i = 1
-- Only run during day or saj can be pinged
-- if ( uservariables["dark"] == "False" ) then
if (otherdevices['saj'] == "On") then
--if (uservariables["saj_online"] == "on") then
    function UpdateDevice(device, data)
        idx = otherdevices_idx[device]
        if (idx == nil) then
            print('** Unknown device '..device)
            commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
            i = i+1
	--Get the XML data from the inverter
    local url = 'curl http://'..ip..'/real_time_data.xml'
    local data = assert(io.popen(url))
    for line in data:lines() do
        if (lineNo == 0 and string.find(line,'Normal') ~= nil) then
            lineNo = 1
        elseif (lineNo > 0) then
            if     (lineNo == 4) then now   = string.match(line, "%d+")
            elseif (lineNo == 5) then temp  = string.match(line, "%d+%.%d+")
            elseif (lineNo == 6) then today = string.match(line, "%d+%.%d+")
            elseif (lineNo == 8) then total = string.match(line, "%d+%.%d+")
            lineNo = lineNo + 1
    data:close()
    if (lineNo >= 14) then
        -- Update the Domoticz GUI
        ep = v1*i1
        wp = v2*i2
        UpdateDevice('Solar', now..";".. total*1000)
        UpdateDevice('Invtemp', temp)
		-- Upload the data to PVoutput every 10 mins
		-- date = os.date("*t")
		-- if (date.min % 10 == 0) then
		--     baseURL="http://pvoutput.org/service/r2/addstatus.jsp?"
		--     API="yourAPIkey"
		--     PVO_URL= baseURL .. "sid=36263&key=" .. API .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M")
		--     PVO_URL = PVO_URL .. "&v1=" .. (today*1000) .. "&v2=" .. now
		--     commandArray['OpenURL'] = PVO_URL
		-- end
