Dashticz - Alternative Dashboard
robgeerts
Domoticz version: 3.7067
Re: WIP - Dashticz - Alternative Dashboard
Post by robgeerts » Wednesday 15 July 2015 16:54
I'm also running it from a Windows-pc (Win 8.1) and works, but, do you get any errors?
Could you open the console (in your browser, CTRL+SHIFT+J in Google Chrome) and see if it shows any errors?
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
jjnj
Post by jjnj » Wednesday 15 July 2015 16:56
robgeerts
Post by robgeerts » Wednesday 15 July 2015 17:03
The console shows you it cant find the files requested...
You are trying to open Dashticz in a subfolder /dash but it is looking for some files in the root.
Try adding this line in index.html (open with notepad) right after <head>:
<base href="http://192.168.2.19:8080/dash/" />
Hope this will fix your problem for now..
Creator of Dashticz
Send:
jjnj
Post by jjnj » Wednesday 15 July 2015 17:23
robgeerts wrote:The console shows you it cant find the files requested...
That did the trick!! Thanks :)
wilmardo
Post by wilmardo » Sunday 13 September 2015 16:14
First, thanks for the cool dashboard!
I installed it yesterday and I like it very much but I would like to use it on my tablet but the dash would not load? I see nothing but a white page, I see no errors in my Nginx log and the dash loads fine on desktop.
Do you have a clue what could cause that? I tried the remote debugging through Chrome but my phone is not seen in chrome://inspect. If you would like the output of the console I could borrow someones phone and try it again.
I do not know if this is the right place to suggest a functionality but I would like to see the 'Actuele vertrektijden' from the NS api (http://www.ns.nl/api/home) on my dash. So if my train is delayed I could see it directly on my tablet on the wall :)
drogert
Target OS: Raspberry Pi
Post by drogert » Sunday 13 September 2015 21:48
Nice! I installed it and it looked really cool. I did notice my normal dashboard was slower when the other was running. Also.. How did you get the buienradar widget? I have Forecast IO installed but I think I would like buienradar too!
Thanks and keep up the good work
gdelaat
Domoticz version: 2.2982
Post by gdelaat » Tuesday 15 September 2015 11:58
I've made some changes to dashtics.js in order to re-activate the display of buienradar. I've added the following code on line 134 (I'm not familiar with GitLab, so I'm posting my info here :) ):
						$.ajax({
							url: _HOST_DOMOTICZ+'/json.htm?type=command&param=getconfig&jsoncallback=?',
							type: 'GET',async: false,contentType: "application/json",dataType: 'jsonp',
							success: function(data) {
								_LATITUDE = data.Latitude;
								_LONGITUDE = data.Longitude;
Patrick
Domoticz version: 3.5877
Post by Patrick » Thursday 01 October 2015 22:08
Nice dashboard, but if I try to display it on my iPad1 the sliders are not displaying correctly. Also the pop-up showing the camera is to big for the screen. Is there a way to fix this?
Tommertom
Post by Tommertom » Tuesday 10 November 2015 23:54
I am not sure if there is still development on this tool, but after looking at the alternatives in this forum (appoticz, dashicz, themes on defaul UI) I would like to use it to some development myself as the setup is actually quite nice and the code comprehensible.
I would like to extend it to do the following in order to improve my WAF for this beautiful hobby:
1- blocks in different sizes, pending content, pretty responsive for tablet and mobile devices
2- no graphs in the overall dashboard (see 4)
3- buttons and sliders etc on the panels, not as panel footer as currently implemented
4- the panel background clickable which leads to a deep-dive panel showing more detail (for instance, elaborate info on weather, graphs, etc.). I already created a panel using the xml feed for detailed weather info and news.
5- adding blocks through virtual devices ("text device") for weather, sonos, and all other required blocks not related to domoticz devices (such as nzb, wunderground, etc.)
6- changing the edit mode - block configuration through preamble in name of device - if the name starts with underscore, it will be allowed in the dashboard (I regard the domoticz UI as a administrator panel, not a user panel). Sorting should remain.
7- multi user support for 6.
A long list and I want to start with the first 4 of which 1,2,3 are easy and already done. For 4 I need to find out how to make the background of a panel clickable without losing the click function on the buttons on the panel itself. Anyone knows how?
Once it seems to work out well, I will be happy to share.
Tom
Ingmar
Post by Ingmar » Wednesday 09 December 2015 23:03
Is this still in development?
I only get a white screen... console says the following:
I've installed Dashticz on my Synology NAS. What is wrong?
Gr. Ingmar
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
klontje
Post by klontje » Saturday 12 December 2015 19:08
Same here, just a white screen and base url is set correct.
robgeerts
Post by robgeerts » Sunday 13 December 2015 22:56
Currently I'm not actively developing on Dashticz. Although, I'm checking regularly for any replies on this topic and when needed, I'll reply or will find a solution.
Has Dashticz worked in the past for the both of you?
Creator of Dashticz
Send:
Ingmar
Post by Ingmar » Monday 14 December 2015 15:27
Nope, it's a first time try for me. It looks and sounds good so want to give it a go :)
Do you still have plans to develop it further Rob?
robgeerts
Post by robgeerts » Monday 14 December 2015 15:32
Could you give me a printscreen of the network-tab in console?
One of the requests will be red..
I try to develop some more on Dashticz but unfortunately I do not have any spare time at the moment...
Creator of Dashticz
Send:
Ingmar
Post by Ingmar » Tuesday 15 December 2015 21:05
See below the screenshot of the network tab. I can't see anything red to be honest...
Time is always a precious thing, we're happy with whatever you manage to put into Dashticz :D
jfhautenauven
Post by jfhautenauven » Sunday 13 March 2016 17:16
I'm new to this forum. Been interested in a while in alternative dashboards for Domoticz;
I've been recently working on the code of Dashticz and did the following so far :
- Added translation to French
- Modified texts that were in Dutch to move them to the translation files
Is anyone still interested in this stuff or am I the only one?
I would be glad to contribute to the project
gizmocuz
Post by gizmocuz » Sunday 13 March 2016 17:39
jfhautenauven wrote:Hello,
besides the custom theme, translation work is always appreciated.
The theme'ing stuff in domoticz is still not where it should be, so unless this is fixed, it makes not a real difference how domoticz looks like
As i always say, try to theme your cisco router... .... thats a no
jfhautenauven
Post by jfhautenauven » Sunday 13 March 2016 17:45
Well, theming a Cisco sounds odd lol
I guess I could be of some use at some point, but I'm C# .Net Senior dev who knows very little about js ...
Anyways, I think that it's Rob Geerts who does the stuff for dashticz? (not domoticz, the Dashticz frontpage) , so maybe we could arrange something so that I could post code on his repo?
Or is there another place where I could do it?
ps : I don't want to steal anything from anyone, just trying to help here ... got some time for the moment, so ...
inbedrijf
Post by inbedrijf » Sunday 01 May 2016 11:29
Awesome skin, and got it working on mij server. but i also have this problem : 2- no graphs in the overall dashboard. Is there a solution for this problem?
inbedrijf
Post by inbedrijf » Sunday 15 May 2016 11:12
Anybody?
