Python plugin: Battery Level for Z-Wave Devices
heggink
Target OS: Raspberry Pi
Domoticz version: V4.9999
Re: Python plugin: Battery Level for Z-Wave Devices
Post by heggink » Monday 13 August 2018 20:58
Plugin works great but sometimes, after changing batteries, the old battery level persists and does not get updated (not even after reboot). Thoughts?
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
Logread
Post by Logread » Saturday 18 August 2018 10:02
The plugin reads the battery level from openzwave. Indeed openzwave sometimes takes time to update it. This is unrelated to the plugin.
multinet
Post by multinet » Monday 27 August 2018 8:53
Hello i have the same trouble (no battery update after changing them)
I change the battery 2 weeks ago, I think there is a pb in openzwave because indeed the openzwave xml file does not have the correct battery level
PI 2 - Domoticz 3.9208
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
Martinq
Domoticz version: 3.8153
Post by Martinq » Thursday 20 September 2018 13:55
Great plugin!!
Somehow Notifications are not working. In the Utility page I have a sensor with a battery level from 90%. So I made a notification like this:
Type: Usage
When: Less
Value: 81
Ignore Interval: Enabled
But no notifications.
Also tried to make a dzVents script, but no luck with it. It seems the Battery level from the plugin is in the sValue field. But I can't find how to extract this in dzVents. Tried it with this:
      timer = {'Every minute'}
   execute = function(domoticz)
      if (domoticz.devices('Battery - Deursensor Berging').sValue < 80) then
        domoticz.log(domoticz.devices('Battery - Deursensor Berging').sValue)
But this gives an error:
Status: dzVents: Error (2.4.6): An error occured when calling event handler Testbat
Status: dzVents: Error (2.4.6): ...o/domoticz/scripts/dzVents/generated_scripts/Testbat.lua:6: attempt to compare nil with number
Status: dzVents: Info: ------ Finished Testbat
Somebody knows how to get notifications working with this plugin?
Logread
Post by Logread » Thursday 20 September 2018 18:41
@Martinq,
I remember reading somewhere (on the forum or on GitHub) that devices created by python plugins do not work well with notifications (or dzvents ?). Or possibly because these are « custom » type of devices that show the battery levels.
Anyway, there is a global setting in domoticz for low battery that works with notifications (I am using this). Alternatively you could write a script that polls the battery level devices for levels, at regular intervals ?
Martinq
Post by Martinq » Thursday 20 September 2018 20:10
I just got a notification from the sensors in Domoticz. Changed the When from Less to Less or Equal. Don't know why it was not working with only Less, but will wait a little bit longer.
The Low Battery function in the Domoticz settings doesn't work well. Many times the device battery is already empty without giving a warning. This script is the first one that gives the correct level. For instance I have a smoke detector. In Domoticz device page the battery level is still 100%. But in the zwcfxxxx.xml the level is 80%. So Domoticz still thinks the battery is full. Also when I check on the Nodes page the Control Page I see the level is 80%.
I am still trying to get the level in dzvents.
Martinq
Post by Martinq » Thursday 20 September 2018 21:19
Oke, got it working in both Notifications from the Custom Sensor as in the dzVents.
In dzVents you can use the .state attribute to get the Battery Level, like this:
       local LEVEL = tonumber(domoticz.devices('Battery - Deursensor Berging').state)
      if (LEVEL < 95) then
        domoticz.log('Battery level Low!! Level = ' .. LEVEL)
        domoticz.log('Battery Level = ' .. LEVEL)
It's important to use the "tonumber". State returns a string, otherwise you get an error: attempt to compare string with number
madvisionz
Domoticz version: 4.10007
Post by madvisionz » Sunday 21 October 2018 22:39
I can't get this plugin to work unfortunately.
I'm running Domoticz on Synology and the install commandlines doesn't work in Putty (in Windows) so I downloaded and copied the files with WinSCP to the BatteryLevel folder on my Syno manually, but I guess that isn't enough.
What am I missing here?
Domoticz 4.10007
DSM 6.2.1
Next day...Battery Monitoring still not visible in Hardware.
Logread
Post by Logread » Tuesday 23 October 2018 8:19
@madvisionz, I have no clue about where domoticz python plugins should reside in a synology install so difficult for me to assess if you chose the right location... do you successfully use other python plugins ?
Also, did you make the plugin.py file executable (sudo chmod +x plugin.py) ?
Last, did you restart domoticz ?
madvisionz
Post by madvisionz » Tuesday 23 October 2018 21:16
@Logread, this is my first python plugin.. the location is /volume1/@appstore/domoticz/var/plugins. I created the "BatteryLevel" folder with mkdir and copied the files to this folder manually (apt-get and git clone isn't working). After that I did run the commandline to make plugin.py executable and restart Domoticz and Synology.
Also running Python 3.5.1.
Any ideas?
##Edit##
I installed another Domoticz incl. Python and now I can add the Battery Monitoring. Thx!! :D
No zwave devices found, but ok... we're getting somewhere.
dextm80
Domoticz version: 4.10159
Post by dextm80 » Wednesday 14 November 2018 23:46
i've this error sometimes:
 2018-11-14 12:13:24.602 Error: (Battery Level Zwave Devices) Ignoring controller ./Config/zwcfg_0xef422f8f.xml since presumed dead (not updated for more than 2 hours)
can you help me ?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
Logread
Post by Logread » Thursday 15 November 2018 9:12
can you help me ?
If it is only from time to time then it is no big deal... It just means your zwave controller has not been updating its data for a while. Not sure why but I assume your zwave network does not poll devices that often.
dextm80
Post by dextm80 » Monday 10 December 2018 19:17
Hi @Logread, my plugin stopped his work! :(
 2018-12-10 18:09:11.798 Error: (Battery Level ZWave) Error reading openzwave file ./Config/zwcfg_0xcc2f1a61.xml
 2018-12-10 18:10:21.726 Error: (Battery Level ZWave) Enable to find a zwave controller configuration file !
what appened?
tnx
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
Post by Logread » Monday 10 December 2018 19:33
Can you see the file in the Config directory ? Can you read it with a text editor ?
First time this error is reported (it could be a malformed xml format but this would be strange)...
dextm80
Post by dextm80 » Monday 10 December 2018 19:37
yes it's into config directory and i'm reading it normally
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
Post by Logread » Monday 10 December 2018 22:23
Then it could be that since you are running a very recent beta the open wave config file format has changed ?
Did you successfully run the plugin with prior versions ? Did the plugin stop when you last upgraded ?
dextm80
Post by dextm80 » Monday 10 December 2018 22:28
yes, after 25 november 18 the plugin stops
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
Post by Logread » Monday 10 December 2018 23:38
You have to bear with me... just too busy to check what when wrong with recent Domoticz betas
Logread
Post by Logread » Tuesday 11 December 2018 12:31
dextm80, can you send your openzwave config file to me by pm (you might have to change its extension to .txt) ? I might then try to see if breaking changes have been Introduced recently.
alanlsmith
Domoticz version: Latest β
Post by alanlsmith » Tuesday 11 December 2018 14:02
If it helps: I'm on beta 4.10267 and the battery plugin is working fine
Domoticz Latest β, Ubuntu 18.04 on Intel NUC i3, 8Gb ram, 70Gb drive, RFXtrx433, z-wave and a bit of Broadlink/Android
Users browsing this forum: allinvisible and 5 guests
