Event Triggered every Second
dozen
Post by dozen » Sunday 08 July 2018 21:00
I have run a Blockly Event with a Fibaro Plug that switches a 433mhz Plug on when there is kwh > 2
So if my Coffeemachine is going on the light above turns on.
The Function is Correct, but every Second the Log gets: EventSystem: Event triggered: Light Coffee
(RFX433) Lighting 1 (Diner LED Coffee)
Is that normal?
jvdz
Target OS: Raspberry Pi
Domoticz version: Stable
Re: Event Triggered every Second
Post by jvdz » Sunday 08 July 2018 21:16
No, so you likely have a logic error testing for status and switching the same switch.
It would help when you show your blockly logic.
Jos
dozen
Post by dozen » Thursday 12 July 2018 16:31
i dont know how to put the Blockly Event here so i take a Photo ;)
jvdz
Post by jvdz » Thursday 12 July 2018 17:27
yea... stamp size ;)
Anyways, Just add an AND to both to test the status of "Diner LED Coffee" so it looks like:
If "Fibaro gen5 kwh".actual >= 5 and "Diner LED Coffee" = "Off" then
Set "Diner LED Coffee" = "On"
ElseIf "Fibaro gen5 kwh".actual <= 5 and "Diner LED Coffee" = "On" then
Set "Diner LED Coffee" = "Off"
Jos
dozen
Post by dozen » Thursday 12 July 2018 20:33
I Think its a Problem with the Fibaro, he sends a lot of Status Messages
2018-07-12 20:27:14.478 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:15.142 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:15.442 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:17.210 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:17.524 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:19.159 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:19.464 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:20.425 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:20.729 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:42.160 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:42.466 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:43.161 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:43.456 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:44.231 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:44.510 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:45.173 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:45.470 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:51.181 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:51.794 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:12.140 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:12.440 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:14.510 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:14.812 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:15.213 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:15.519 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:16.160 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:16.459 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:18.158 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:18.443 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
So now i have changed the Problem from event triggering to this :(
gerardsoraya
Domoticz version: v3.8763
Post by gerardsoraya » Sunday 15 July 2018 19:21
dozen wrote:I Think its a Problem with the Fibaro, he sends a lot of Status Messages
The way jos says it have to work because jou dont have a check right now. Every second the system sees the usage is above so i do an action.
Verstuurd vanaf mijn SM-G965F met Tapatalk
ubuntu
rflink 433 mhz
rflink 868 mhz
p1 smart meter cable
toon thermostaat
otgw
pretty noob but whit google i've done a lot
dozen
Post by dozen » Sunday 15 July 2018 20:54
Jos
I must remove the „if its on then turn it off“ command because sometimes i need the Light Permanently ;)
Gesendet von iPhone mit Tapatalk
terrorsource
Post by terrorsource » Monday 16 July 2018 13:38
You need to have some kind of check in your script. this way it always triggers each second because nothing changed. this is as designed.
The IF ELSE from @jdvz is what you need to use.
mrf68
Domoticz version: 3.4834
Post by mrf68 » Tuesday 17 July 2018 8:16
But remove one of the = , because using “if >= 5” and “else if <= 5” would be nasty when usage = 5. ;)
Users browsing this forum: No registered users and 6 guests
