ESP8266 MQTT switch with local on/off and feedback
Everything about esp8266 and more.
SweetPants
Domoticz version: V4.10007
Post by SweetPants » Monday 11 June 2018 19:53
Project Scope:
When entering my house I want to be able to switch the light in the halway automatically between sunset and sunrise. So when the door opens, switch On the light for say 1-2 minutes and switch Off again using dzVentz. But I also want to be able to switch on/off the light using the existing wall switch(es).
This could be done using an extra (ESP8266 driven) relay in parallel with the original wall switch, but then you are not able to switch off the lights anymore with the wall switch and this is not suitable when having a hotel circuit (2 or more switches in series)
This could be solved by buying (expensive) wall switches which most of the time do not fit into the wall box or are totally different from the original.
Solution:
I've created an ESP8266 enabled switch that can be switched using MQTT, but also takes the switch wire from the wall switch as an input and do local switching if needed. When the wall switch is toggled, the switch also sends an MQTT update to domoticz to update the current switch state. The module is located in or near the lamp, so in case of a hotel circuit, it also works.
First test looks promising
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
kimot
Target OS: Raspberry Pi
Domoticz version: v3.8153
Re: ESP8266 MQTT switch with local on/off and feedback
Post by kimot » Tuesday 12 June 2018 23:05
ESPeasy works the same way without need scripts in Domoticz and works if Domoticz is down too.
Domoticz only sends "events" sunset, sunrise, switch slamp ( for remote control ) etc. Other ESPeasy sends door contact state to first (lamp) ESPeasy
This ESPeasy monitors mechanical switch state too, reports lamp state back to Domoticz and control lamp relay ( with timers if needed )
SweetPants
Post by SweetPants » Wednesday 13 June 2018 14:50
My solution does that too, no need for scripts, and no need to modify wall switches, just sense the presence of a switch signal, but you need some additional hardware to do that. And how about hotel circuits with two or more wall switches?
Edit: Have a second one running now on a 3 switch hotel circuit. Still looking good
ronschaeffer
Post by ronschaeffer » Friday 17 August 2018 13:41
Sounds really interesting. Please post some details about your hardware set up to detect the wall switch toggle. Thanks!
SweetPants
Post by SweetPants » Friday 17 August 2018 14:30
Schematic: (The circled part converts the wall switch signal to something the ESP can handle
The attachment Feedback_Switch.png is no longer available
Hardware:
ronschaeffer
Post by ronschaeffer » Monday 20 August 2018 16:43
Thanks. Have you been happy with the performance?
SweetPants
Post by SweetPants » Monday 20 August 2018 18:43
What performance? It's just a switch and it takes only a few msec to switch either locally or via MQTT
Derik
Post by Derik » Monday 20 August 2018 23:21
Project Scope:
Solution:
Perhaps look at Tasmota..
SweetPants
Post by SweetPants » Tuesday 21 August 2018 8:12
Project Scope:
Solution:
As said, it's already working fine, so no need for Tasmota
ronschaeffer
Post by ronschaeffer » Wednesday 22 August 2018 14:13
Just meant whether it was working reliably
SweetPants
Post by SweetPants » Wednesday 22 August 2018 15:47
yup, running since jun 11 and never missed a local or MQTT switch up till now. Have 2 running, working on a third, waiting for some components.
Dlanor
Post by Dlanor » Wednesday 22 August 2018 21:24
SweetPants wrote: yup, running since jun 11 and never missed a local or MQTT switch up till now. Have 2 running, working on a third, waiting for some components.
Can it also be installed behind a light switch? Dutch version ‘inbouwdoos’?
Domoticz | Dashticz V2 | Raspberry Pi | RFXCOM RFXtrx433E USB | RFlink 433Mhz | SONOFF
SweetPants
Post by SweetPants » Thursday 23 August 2018 9:08
Depends on the depth of the 'inbouwdoos', but I don't think so, never tried. Also be aware that the ESP antenna is a PCB antenna and known not to be very good, so placing it behind the original wall switch could give problems.
Last edited by SweetPants on Saturday 25 August 2018 12:37, edited 1 time in total.
Antori91
Domoticz version: 4.97&3.5
Post by Antori91 » Thursday 23 August 2018 10:49
Hello SweetPants,
Could you publish the ESP8266 code you are using for this?
Domoticz High Availability Cluster: Synology Dz V3.5877 (Main) - Raspberry Dz V4.97 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
SweetPants
Post by SweetPants » Thursday 23 August 2018 22:03
Hello SweetPants,
Send me a PM. Be aware, this is C code using the ESP SDK (2.2.0) directly, so no Arduino IDE or any other platform involved.
