Longer log
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
cincuranet
Target OS: Raspberry Pi
Longer log
Post by cincuranet » Monday 11 June 2018 7:01
Is there some setting somewhere to have the Domoticz Log Image store more/older lines (in All tab)?
Egregius
Re: Longer log
Post by Egregius » Monday 11 June 2018 7:41
use tail -f in a shell and you'll see all the lines.
Or open the logfile in a text editor.
SweetPants
Domoticz version: V4.10196
Re: Longer log
Post by SweetPants » Monday 11 June 2018 7:54
And use log rotation with compression and you can save days or more logging.
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
cincuranet
Re: Longer log
Post by cincuranet » Monday 11 June 2018 8:07
So nothing to show more lines directly in Domoticz's UI, right?
Egregius
Re: Longer log
Post by Egregius » Monday 11 June 2018 17:34
Probably yes, but then you need to dig into the Domoticz code.
After that make the change after each update or place a pull request at github.
SweetPants
Re: Longer log
Post by SweetPants » Monday 11 June 2018 22:26
Or request a programmable log length variable in the settings?
Egregius
Re: Longer log
Post by Egregius » Monday 11 June 2018 22:48
It's open source, you can contribute.
Personally I don't see a point for that. If you want to see the full history of the log you can easily open it in a text editor.
Or use a php script like I do :P
SweetPants
Re: Longer log
Post by SweetPants » Tuesday 12 June 2018 13:34
I agree, I have logrotate enabled and save the last 7 days of domoticz log. 99.99% of the time this is more then enough, and easy to read in an editor.
Re: Longer log
Post by waaren » Tuesday 12 June 2018 16:50
I also agree that this is probably valid for 80%-90% of the people visiting this forum but I doubt if that is also true for the majority of users who will only look at the log when asked to do so by their smart nephew or niece.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
