Plugin - Homewizard
smaus
Re: Plugin - Homewizard
Post by smaus » Wednesday 28 February 2018 21:18
:D top its working :lol:
MrPenthouse
Target OS: Raspberry Pi
Post by MrPenthouse » Tuesday 06 March 2018 22:51
Wow, this did not even cost me more than a minute and it worked straight away! Excellent job and now my HomeWizard has an extended live, much thanks!
webmagic
Post by webmagic » Sunday 11 March 2018 15:09
I like this plug-in very much! Will there be support for the Smartware XQ-lite Led lamps which are using 868 mhz. I would like to set the lamp dim setting via Domoticz.
WWortel
Post by WWortel » Sunday 06 May 2018 15:42
This plugin looks very promising!!! I hope you can help me getting the plugin up-and-running.
Version: Linux raspberrypi 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Beta Domoticz Version: 3.9389-
dzVents Version: 2.4.5
Python Version: 3.5.3
Platform: Raspberry 3B+
I’ve installed the plugin and did a setup of the hardware Homewizard. I get this message: ‘Homewizard created, devices can be found …’ :D
When I go to devices, I get this message: ‘Problem retrieving devices!’ :?
When I go back to hardware, the homewizard I just created is not shown anymore and Homewizard can’t be selected anymore for a new setup of hardware.
To be able to start it correctly again I did: mv plugin.py plugin.py.old Now I can start and remove the created hardware of homewizard in domotics. Next I do a Restart and I’m back to where I started.
Note when I start it via ./domotics, then I see this message:
2018-05-06 14:52:09.993 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2018-05-06 14:52:09.993 Error: WebServer(SSL) check privileges for opening ports below 1024
(I don’t see this message in logs when starting via sudo service domoticz.sh start)
I also tried running the stable version (3.8153). However then I’m not able to setup the Homewizard hardware.
I hope somebody has a clue what is going wrong.
Regards,
WWortel
TheCub3
Post by TheCub3 » Saturday 09 June 2018 18:30
hi,
i did the steps:
cd domoticz/plugins
git clone https://github.com/rvdvoorde/domoticz-homewizard.git
sudo systemctl restart domoticz
and i see in my raspbian,
but i dont see in in Hardware antthing of homewizard ?,i already try a reset in domoticz
i use the beta version that is needed but i see in the log
2018-06-11 19:33:36.208 Status: Domoticz V3.9625 (c)2012-2018 GizMoCuz
2018-06-11 19:33:36.209 Status: Build Hash: 529bd73d, Date: 2018-06-11 06:30:28
2018-06-11 19:33:36.209 Status: Startup Path: /home/pi/domoticz/
2018-06-11 19:33:36.390 Status: EventSystem: reset all events...
2018-06-11 19:33:36.391 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
i think that is the problem but how can i make sure that the library is running correct ?
what am I doing wrong ?
update,
solved the problem, if you also got the same error like above go to Putty and install manual Python with the commando sudo apt-get install python3-pip
tnx,
A,
Sjonnie2017
Domoticz version: 4.9700
Post by Sjonnie2017 » Sunday 26 August 2018 18:29
I don't want to double post but I am having problems with the HomeWizard plugin since I rebooted my device this morning. Please refer to this post (viewtopic.php?f=6&t=24623) for more information.
Can anyone shed some light on this issue?
TIA
Greetz,
Sjonnie
EDIT
Got the latest version from git and replaced it with old plugin.py. Problem solved :mrgreen:
Domoticz (latest) on RPi3 - HomeWizard as relay - HeatLink - Some 26 switches (KaKu/CoCo) for lights and shutters - HomeWizard Weatherstation with 4 additional thermo-/hygrometers - 4 water sensors - Byron B002e doorbell -
BroadLink Black Bean
Sjonnie2017
Post by Sjonnie2017 » Monday 27 August 2018 12:05
Got another question for the more experienced (then me :roll: ) HomeWizard-Domoticz users: I have added a switch (code disks) to my HomeWizard. It works and can be controlled by it. Unfortunately the switch does not show up in Domoticz. Even though I changed the full update interval to once every 15 minutes.
Any ideas?
Greetz,
Sjonnie
Sjonnie2017
Post by Sjonnie2017 » Friday 14 September 2018 14:58
Friendly bump :)
Anyone any idea?
EDIT: I have been investigating all possibilities to get the device list updated. Unfortunately I could not get that to work. Finally decided to remove the HomeWizard from Domoticz and added it again; knowing I would have to recreate the devices and configurations :cry: The missing device is now added. So for now I will think twice before adding extra devices to the HomeWizard ;)
