Ping???
welby
Target OS: Raspberry Pi
Ping???
Post by welby » Tuesday 30 January 2018 13:48
Not sure if it's possible but i'd like to ping my phone to see if i'm home or away. Is it possible with dzvents?
emme
Domoticz version: latest
Re: Ping???
Post by emme » Tuesday 30 January 2018 16:17
not really sure, but if you have a iOS device, it won't reply on ping
if you have an Android device (huawei act like this), it won't reply on standby
presence with mobiles is quite wired... ;)
"We always done this way"
welby
Re: Ping???
Post by welby » Wednesday 31 January 2018 7:05
I had it working with a lua script but it was using the time method and was every minute which was a bit to often to have it happening.
emme
Re: Ping???
Post by emme » Wednesday 31 January 2018 9:01
what about the System Alive Checker (PING) availble in the hardware list?
welby
Re: Ping???
Post by welby » Wednesday 31 January 2018 11:30
Didn't even think of that :oops: Seems to be working pretty good, thanks emme 8-) 8-)
elythomaslumber
Domoticz version: 3.8153
Re: Ping???
Post by elythomaslumber » Wednesday 31 January 2018 13:44
Had that idea some years ago but as emme says there is a problem with iOS devices. Now since some weeks I have a FritzBox router (also available in Australia :D ( http://firstint.com.au/fritzbox-fon-wlan-7490/)). This box knows the presence of an iOS device even if it is in sleep mode. I tested with iPAD 1, iPAD 3 and iPad Air but also with Android 6.0 phone. Presence is detected 1-2 seconds after WiFi has logged in to the router. Absence needs up to 10minutes after the device is logged out.
I found a script (German): https://www.schlaue-huette.de/apis-co/f ... -fritzbox/ which can be used for login triggered by a cronjob reading out the presence of any network device. So it is used as presence detection.
Just for fun I modified it and integrated some Domoticz switch commands. The script asks for 2 devices and swiches a lamp in case of one of the two devices are present and delivers an echo message when started from CLI which device is present. So it can be used at a basic php script for presence detection. I think I will place it in the Wiki in the next days. If somene is interested I can place it here.
Raspberry Pi & Domoticz 3.8153
RFXCOM FW1022
Wall panel APPLE iPAD 3.generation
Fritz!Box 7590 & Eurotronic COMET DECT Thermostat
https://www.qrz.com/db/DK5LH
DeBaat
Domoticz version: V3.8153
Re: Ping???
Post by DeBaat » Sunday 04 March 2018 17:00
Hai.
As I also have a FritzBox, I'm surely interested in the script you mention.
