Support of Let's Encrypt
tho071088
Target OS: Raspberry Pi
Domoticz version: Stable
Post by tho071088 » Thursday 26 October 2017 10:02
I use Let's Encrypt for SSL support, i have to run scripts manually to update the certificates and replace them in Domoticz configuration.
Also, I have to replace them each time Domoticz is updated.
Could it be automatic ?
Domoticz Beta on Rasbperry Pi 3
RFLink / YeeLight / Xiaomi Devices / 433MHz / SonOff via MQTT
niki_lauda
Re: Support of Let's Encrypt
Post by niki_lauda » Friday 15 December 2017 22:20
@ https://www.domoticz.com/wiki/Native_HT ... SL_support
you can define your own letsencrypt certificate.
-sslcert file_path ( for example D :\server_cert.pem or /opt/domoticz/server_cert.pem)
tho071088
Post by tho071088 » Tuesday 19 December 2017 22:06
Yes but it's not so easy :oops: :
  • Manually generate new certificate every 6 month
  • Tree files to concatenate (privkey.pem/fullchain.pem/server_cert.pem).
Something automatic could be nice.
kijdhfcjdks
Post by kijdhfcjdks » Monday 01 January 2018 23:28
Hi, here's another variant for installing a letsencrypt certificate with Domoticz on a Raspberry Pi (Raspbian). This also includes a cronjob that auto renews. (not tested live yet though...)
I'm using a custom ssl port for Domoticz so I forward port 443 to certbot-auto(listening on port 8889 in this example) for the certificate setup and renewal only. Certbot-auto is a tool from EFF that simplifies the process.
#0 Setup router forwarding
External port 443 => 8889 on local raspberry pi
#1 Login to rpi and update
sudo apt-get update
sudo apt-get upgrade
sudo /home/pi/domoticz/updaterelease
#2 Install certbot-auto
cd ~
mkdir certbot
cd certbot
wget https://dl.eff.org/certbot-auto
chmod a+x certbot-auto
#3 generate and install certificate
sudo ./certbot-auto certonly  --standalone --preferred-challenges tls-sni-01  --tls-sni-01-port 8889 -d YOURDOMAIN.COM
sudo rm /home/pi/domoticz/server_cert.pem
sudo cat /etc/letsencrypt/live/YOURDOMAIN.COM/privkey.pem >> ~/domoticz/server_cert.pem
sudo cat /etc/letsencrypt/live/YOURDOMAIN.COM/fullchain.pem >> ~/domoticz/server_cert.pem
sudo cp /home/pi/domoticz/server_cert.pem /home/pi/domoticz/domo_server_cert.pem
cd domoticz/
sudo /etc/init.d/domoticz.sh restart
Done! "domo_server_cert.pem" is your backup if Domoticz overwrites the live one during updates.
Renewalscript(not tested live yet):
nano /home/pi/cert-domoticz-update.sh
Paste the following script and save it:
#!/bin/bash
/home/pi/certbot/certbot-auto renew
rm /home/pi/domoticz/domo_server_cert.pem
cat /etc/letsencrypt/live/YOURDOMAIN.COM/privkey.pem >> /home/pi/domoticz/domo_server_cert.pem
cat /etc/letsencrypt/live/YOURDOMAIN.COM/fullchain.pem >> /home/pi/domoticz/domo_server_cert.pem
cp /home/pi/domoticz/domo_server_cert.pem /home/pi/domoticz/server_cert.pem
sudo chmod a+x /home/pi/cert-domoticz-update.sh
Setup Cron:
crontab -e
Add this:
3 0 * * 7  /home/pi/cert-domoticz-update.sh
The script will run every Sunday at 3 AM
Edit: added a line to the to the script(row 4). Now renewal should work
Last edited by kijdhfcjdks on Wednesday 25 April 2018 20:29, edited 1 time in total.
Deluka
Post by Deluka » Saturday 24 February 2018 19:08
I'm trying this but getting the following error
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA
jsiegmund
Post by jsiegmund » Tuesday 06 March 2018 19:13
That's because of this: https://community.letsencrypt.org/t/imp ... sues/50811
The TLS path is no longer valid. You need to remove the two arguments concerning tls and use the default HTTP verification method instead.
Deluka
Post by Deluka » Wednesday 07 March 2018 23:51
Oke thx that solved my problem
kijdhfcjdks
Post by kijdhfcjdks » Wednesday 25 April 2018 20:33
I re-downloaded certbot and followed the steps and the deprecated command works for me anyway. Can't use the standard ports so that's why I use these flags.
clubeddie
Post by clubeddie » Monday 24 September 2018 19:45
I tried your steps, but i am getting stuck at
After this command i get
etc/letsencrypt/live/YOURDOMAIN.COM/privkey.pem: No such file or directory, where YOURDOMAIN.COM is offcourse my own domain. Any clue?
Directory live isn't exists
