Fetch data from external servers without locking the event system!
BakSeeDaa
Target OS: Raspberry Pi
Post by BakSeeDaa » Friday 08 September 2017 17:46
I have seen so many scripts here lately that fetches data from external servers on the Internet.
Most if not all of those scripts use code similar to this:
local file=assert(io.popen('curl http://someserver.json'))
local raw = file:read('*all')
file:close()
(Unfortunately even the Wiki is suggesting this method) It's a very bad practice to do like this. The Domoticz event system will wait for the response. That is, with a little bit of bad luck nothing will happen in your Domoticz system for up to 10 seconds.
So, all of a sudden when you least expect it your Domoticz system freezes and you have no clue why. The whole Domoticz system seems unstable and unpredictable. So my advise is to get rid of all those scripts immediately. We all know that there are delays on the Internet ...You can use such scripts in your LAN if you are 100% sure that your LAN servers are up and running 24/7 and always replies very fast.
What can you do about it then?
For a linux system it's not difficult at all to write a script that first calls the url without waiting for the server to respond and then returns one minute later to check the result. Below is a fully working dzVents skeleton script that does exactly that. It calls an URL every 5 minutes. The server is expected to respond with a json and the result is redirected to a temporary file. Then the next minute it checks for the result file and encodes it. Please feel free to use my script.
-- This example dzVents Lua script shows how to retrieve data from the Internet
-- without risking to lock the Domoticz event system.
local jsonResultFile = '/tmp/tmpJson.json' -- Temporary file to store the servers response
local fetchIntervalMins = 5 -- (Integer) (Minutes, Range 5-60) How often the data shall be retrieved
local scriptVersion = '1.0.2'
	active = true,
	logging = {
		level = domoticz.LOG_INFO, -- Uncomment to override the dzVents global logging setting
		marker = 'callNoWait '..scriptVersion
		timer = {'every minute'} -- Don't change! Verander niet! Ne changez pas!
		-- Every 5 minutes, call the URL and exit.
		-- The following minute, return to read the result file
		local callUrl = false
		if (os.date('*t').min % fetchIntervalMins) == 0 then
			callUrl = true
		elseif ((os.date('*t').min -1) % fetchIntervalMins) ~= 0 then
			return
		if callUrl then
			local url = 'https://jsonplaceholder.typicode.com/posts/1'
			domoticz.log('Requesting data from the jsonplaceholder server...', domoticz.LOG_INFO)
			domoticz.log('URL used: '..url, domoticz.LOG_DEBUG)
			os.execute('curl -s "'..url..'" > '..jsonResultFile..'&')
			return -- Nothing more to do for now, we'll be back in a minute to read the data!
		---loads a json file with the provided name and returns it as a table (if it exists)
		local function readLuaFromJsonFile(fileName)
			local file = io.open(fileName, 'r')
			if file then
				package.path = './scripts/lua/?.lua;'..package.path
				local jsonParser = require('JSON')
				local _json = file:read('*a')
				local json = jsonParser:decode(_json)
				io.close(file)
				return json
			return nil
		local demoData = readLuaFromJsonFile(jsonResultFile)
		if not demoData then
			domoticz.log('Could not read demoData from file: '.. jsonResultFile, domoticz.LOG_ERROR)
			return
		domoticz.log('json data file has been read. "title" = "'..demoData.title..'"', domoticz.LOG_INFO)
For the future I'm looking for a way to make the script call a bash script that makes a "call-back" when the external server has responded so that we wouldn't have to wait that extra minute for the result. @dannybloe might have some ideas to to re-trigger the script using a callback, we'll see about that later maybe. But for now I really recommend you to rewrite all your scripts that's using assert(io.popen('curl
Cheers!
Last edited by BakSeeDaa on Sunday 10 September 2017 10:42, edited 2 times in total.
DutchHans
Re: Fetch data from external servers without locking the event system!
Post by DutchHans » Friday 08 September 2017 17:58
Perfect... But how about a lua version? There are many lua-users around here.
Regards, Hans
BakSeeDaa
Post by BakSeeDaa » Friday 08 September 2017 18:09
Regards, Hans
It's not difficult at all to do exactly the same thing in "vanilla" Lua Hans and I'm sure someone likes to translate it.
I used to do all coding in vanilla Lua before but I have realized how much better it gets when using a good framework like dzVents. Actually dzVents makes a lot of work for you on a higher level.
If you are new to dzVents you can just try the script out by copying it and paste it into your internal Domoticz code editor (SETUP-->EVENTS) select dzVents in the drop down, name the script "callNoWait", check "Event active" and save. Now you have your first dzVents script up and running! :lol:
BakSeeDaa
Post by BakSeeDaa » Friday 08 September 2017 18:54
Regards, Hans
OK, I might be banned for this (posting in wrong forum) but... here you go:
	callUrl = true
	return
if callUrl then
	print('Requesting data from the jsonplaceholder server...')
	print('URL used: '..url)
	if file then
		io.close(file)
		return json
	return nil
	print('Could not read demoData from file: '.. jsonResultFile)
	return
print('json data file has been read. "title" = "'..demoData.title..'"')
Last edited by BakSeeDaa on Sunday 10 September 2017 10:42, edited 3 times in total.
elmortero
Domoticz version: 3.9639
Post by elmortero » Saturday 09 September 2017 12:41
Great work bakseedaa, Will try that today
DutchHans
Post by DutchHans » Saturday 09 September 2017 13:38
@ Bakseedaa
Thank you... Give that man a cigar....
Cheers, Hans
BakSeeDaa
Post by BakSeeDaa » Saturday 09 September 2017 19:32
Thanks for your kind words.
I just updated the script to version 1.0.1
The readLuaFromJsonFile function is now using require for loading the JSON library. The variable holding the path to the JSON library has been removed. It should be more efficient and hopefully also platform independent.
BakSeeDaa
Post by BakSeeDaa » Sunday 10 September 2017 10:46
I just updated the script to version 1.0.2
It's a minor change.
Changed the line
package.path = package.path ..";./scripts/lua/?.lua;"
To become
rrozema
Post by rrozema » Thursday 14 December 2017 15:48
I haven't the foggiest if this is actually possible, but can you make the output of the curl command go into a text control instead of into a temp file? If you can do that somehow, you can have the 2nd part of the script, i.e. reading the output, execute when domoticz signals the text control as changed.
dannybloe
Post by dannybloe » Thursday 14 December 2017 17:02
Just wait for dzVents 2.4 :)
EddyG
Domoticz version: 4.9999
Post by EddyG » Saturday 16 December 2017 16:52
Nice script template, I use it several times.
It would be nice to have the same kind of script for outputting to PVoutput without locking the event system.
Is there a common way to do that?
Regards,
Eddy
