Change Database location Raspberry Pi
Preko
Target OS: Raspberry Pi
Post by Preko » Thursday 16 November 2017 20:43
Hello everyone.
I have recently created a Domoticz webserver on a raspberry pi.
I want to change the database location to be not on the SDCard but on a USB KEY (which will be forced to have the same driver number upon rebbot).
1 - is there a way to modify the path ?
2 - is it "acceptable" to do this ?
Thank you all ;)
NB : I have not found a topic / answer related to this question ...
Orionos
Re: Change Database location Raspberry Pi
Post by Orionos » Tuesday 02 January 2018 20:43
I'm surprised nobody answered this. Apparently this community isn't as active as we'd hope. Given the still quite complex nature of Domoticz, I would have expected a lot more whiz-kids. Anyway...
You can easily alter the startup line for domoticz to point to a different file.
In the case of systemd, you'll find a line in the domoticz.service file similar to this:
ExecStart=/home/domoticz/domoticz/domoticz -www 8080 -sslwww 443 -dbase /home/domoticz/domoticz/domoticz.db
As you can see, the location of your database is just a little startup-option away. Given that it's part of the program, I imagine it's perfectly acceptable.
Important: Make certain the user that runs domoticz has read-write permission on the directory that holds the file. Otherwise, domoticz will boot, but you'll have lots of SQL errors.
EddyG
Domoticz version: 4.9999
Post by EddyG » Tuesday 02 January 2018 21:02
I am suprised why 'nobody' uses the 'default' linux methode of calling: ./domoticz --help or /home/pi/domoticz/domoticz --help
You see all the parameters you could use on domoticz.
Regards,
Eddy
ben53252642
Post by ben53252642 » Tuesday 02 January 2018 21:04
Or you could just use a symbolic link (I use many for making certain files operate from tmpfs reducing writes to the SD card).
Example:
mkdir -p /tmp/domoticz
ln -sf /tmp/domoticz/domoticz.db-shm /root/domoticz/domoticz.db-shm
ln -sf /tmp/domoticz/domoticz.db-wal /root/domoticz/domoticz.db-wal
ln -sf /tmp/domoticz/ozwcp.poll.XXXXXX.xml /root/domoticz/ozwcp.poll.XXXXXX.xml
ln -sf /tmp/domoticz/ozwcp.scenes.XXXXXX /root/domoticz/ozwcp.scenes.XXXXXX
ln -sf /tmp/domoticz/ozwcp.stat.XXXXXX /root/domoticz/ozwcp.stat.XXXXXX
ln -sf /tmp/domoticz/ozwcp.topo.XXXXXX /root/domoticz/ozwcp.topo.XXXXXX
ln -sf /tmp/domoticz/domocookie.txt /root/domoticz/domocookie.txt
ln -sf /tmp/domoticz/domoticz_beta.tgz /root/domoticz/domoticz_beta.tgz
mkdir -p /tmp/domoticz/Config
ln -sf /tmp/domoticz/Config/OZW_Log.txt /root/domoticz/Config/OZW_Log.txt
service domoticz start
EddyG
Post by EddyG » Tuesday 02 January 2018 21:13
It's not a good idea to put the database on a tmpfs, because if you have a power failure or reboot you lose the database.
Why not use the startup parameter to relocate the database, that's what the parameter is intended for.
Regards,
Eddy
albercola
Post by albercola » Sunday 29 April 2018 22:21
Orionos gave the best solution for my problem. Unfortunately i cannot locate the domoticz.service file.
EddyG gave another good suggestion but i am not able to solve my problem in that way.
Can you please help me?
Post by waaren » Sunday 29 April 2018 22:32
@albercola,
I use Berryboot . Now I only boot from the sd card and all other IO is done from/to USB or SCSI attached storage. I use my Synology NAS for it with the the additional benefit of being able to have hourly snapshots of my domoticz production system. It saved my data already on a couple of occasions.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
