framb0ise v2 - awesome new dashboard!
jkimmel
Target OS: Raspberry Pi
Re: framb0ise v2 - awesome new dashboard!
Post by jkimmel » Sunday 30 July 2017 15:48
safi78 wrote:In settings, you only have to specify your domoticz server url, not the /framb0ise in the url.
Problem is settings don't open.
Having installed jessie and domoticz from scratch only cloned framb0ise into /domoticz/www
Domoticz is running fine.
Rfxcom
ehallq
Post by ehallq » Monday 31 July 2017 6:49
Had trouble when installing this first, I had to visit ****/frambi0se/ . ****/frambi0se did not work
jkimmel
Post by jkimmel » Monday 31 July 2017 20:03
I needed
xxx.xxx.xxx.xxx:8080/framb0ise/index.html
Rfxcom
markjgabb
Domoticz version: 3.8153
Post by markjgabb » Tuesday 01 August 2017 2:04
awesome add on, very nice and simple to use, easy layout and great working setup
was wondering for traffic what sort of information you would need to setup for australia/victoria....
for instance our local road authority has this system
http://api.vicroads.vic.gov.au/
is that the kind of thing you need?
V 3.8153 RPI 3
RFlink 334 mhz
mysensors
broadlink
wemo
markjgabb
Post by markjgabb » Friday 04 August 2017 4:03
is there any reason the calendar part cant be achieved using the private url for ggogle?
V 3.8153 RPI 3
RFlink 334 mhz
mysensors
broadlink
wemo
tlpeter
Post by tlpeter » Saturday 05 August 2017 13:05
Now this is great and indeed only Domoticz config and that is what i need.
I do not want to setup a second tool only to see what i already have.
This is a great easy tool.
Maikie
Post by Maikie » Friday 25 August 2017 11:47
Would it be possible to show a negative value for power?
sander815
Post by sander815 » Friday 25 August 2017 12:07
why doný i see the settings page when i open http://192.168.1.227:8080/framb0ise/
jvdz
Domoticz version: Stable
Post by jvdz » Saturday 26 August 2017 10:32
Could you make an issue in github please so we dont forget to follow up?
Jos
jvdz
Post by jvdz » Saturday 26 August 2017 10:33
Did you actually copy the files there?
Have you tried adding index.html to that line?
Jos
thruhge
Post by thruhge » Sunday 27 August 2017 9:44
Thanks for the great work.
I have a question about Blinds (433mhz), is this function available? Because I just see a powerbutton only.
safi78
Domoticz version: LastBeta
Post by safi78 » Monday 28 August 2017 14:15
You're welcome.
Is it possible to send us the json for this device?
Then we can have a look how this should be presented in the webinterface.
I don't know if you noticed or not, but I'm an extremely arrogant man who tends to think all of his plans will work ...
https://safiweb.nl
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
Post by safi78 » Monday 28 August 2017 14:17
That could work. Can you send me an example URL for your situation? Then we'll have a look at this :)
https://safiweb.nl
safi78
Post by safi78 » Monday 28 August 2017 14:19
Jos
Very interesting, I don't remember we 'don't do' negatives? Must be a javascript thingie.
https://safiweb.nl
tlpeter
Post by tlpeter » Monday 28 August 2017 18:37
Hi Safi78, i have a sunscreen which is controller by a fibaro roller shutter but all i see is a on/off switch.
This is the json for this deice:
   "ActTime" : 1503938059,
   "ServerTime" : "2017-08-28 18:34:19",
   "Sunrise" : "06:49",
   "Sunset" : "20:36",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Closed",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 16,
         "HardwareName" : "Zwave USB",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00000201",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-08-28 11:26:24",
         "Level" : 255,
         "LevelInt" : 255,
         "MaxDimLevel" : 100,
         "Name" : "Zonnescherm",
         "Notifications" : "false",
         "PlanID" : "12",
         "PlanIDs" : [ 12 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Closed",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Blinds",
         "SwitchTypeVal" : 3,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "blinds",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "2209"
   "status" : "OK",
   "title" : "Devices"
Can you fix this?
jvdz
Post by jvdz » Monday 28 August 2017 19:33
I have a sunscreen which is controller by a fibaro roller shutter but all i see is a on/off switch.
That is how it is implemented at this moment. It shows a Blue button for when it is (partially) closed and a green button for when it is Open.
It sends a Toggle Switch when pressed.
Jos
safi78
Post by safi78 » Tuesday 12 September 2017 11:53
Fixed by jvdz, try latest update.
https://safiweb.nl
Robbonnechere
Post by Robbonnechere » Thursday 07 December 2017 11:51
Hi, I am a complete newbie so please be gentle ! If this post is in the wrong area please accept my apologies.
I have just setup my first Domoticz install. I set it up following a step by step giude, creating a new user called domoticz. Everything appears to run OK. I have working devices switches and a room and floor plan. When I tried to install your dashborad I got a permisions error, so I installed using sudo.
I now get a blank framb0ise page and can click on the settings icon and fill in the page, but nothing happens and it never updates the settings info. If I refresh or reboot there is still a blank page with no settings saved. I think possibly this is a permisions problem but have no idea where to look.
Any help or advice would be welcomed.
Rob
jvdz
Post by jvdz » Friday 08 December 2017 10:27
Hi Rob, do you have any ROOMPLANs defined in Domoticz with devices in it as those are used by franb0ise?
Jos
OttoBismark
Post by OttoBismark » Sunday 10 December 2017 17:46
thanks to Safi78 for the good work. Since i'm a real newbie i was able to use framb0ise even if i'm not able to correctly show the weather forecast. Is it possible to integrate a widget like this one https://forecast.io/embed/#lat=41.91697 ... &name=Rome?
The darksky widget doesn't work for me. it shows an empty widget.
Last question: it would be possible to change the background image?
Thank you
Cheers
Users browsing this forum: Google [Bot] and 4 guests
