Dashticz - Module - Calendar
Moderators: robgeerts, htilburgs
HansieNL
Target OS: Raspberry Pi
Domoticz version: Stable
Re: Dashticz - Module - Calendar
Post by HansieNL » Wednesday 10 May 2017 20:06
alveman wrote:Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
Have you tried without https://crossorigin.me/
Blah blah blah
robgeerts
Domoticz version: 3.7067
Post by robgeerts » Wednesday 10 May 2017 20:12
Martin
This is handled automatically nowadays with the calendars ;)
Try:
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
and then in your columns:
columns[1]['blocks'] = [calendars.private]
But, I'm still working on the calendar-module.
Creator of Dashticz
Do you appreciate my work and want to buy me a beer?
Send:
- XVG to D8fwNbyV6YxJk1aSiXftWTtdaPipsKn2Fa
- ANY ERC20-TOKEN to 0x9b8ee84329d77765a28bca188218c6c793875a8a
or donate via PayPal: https://www.paypal.me/robgeerts
alveman
Post by alveman » Wednesday 10 May 2017 21:27
robgeerts wrote:
Martin
Try:
var calendars = {}
Now I have tested this but no luck
//var _ICALENDAR_URL			= 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX';
//var _ICALENDAR_DATEFORMAT	= 'YYYY.MM.DD HH:mm';
//var _ICALENDAR_LOCALE		= 'en'; //en,hu, etc.
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'webcal://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
And changed the output block from 'icalendar' to calendars.private
Also tested both webcal:// and https:// but no difference same result. It's says "Loding..." for like 3 sec then emty. I can wait for the calendar-module ;) , keep up the good work!!
Martin
robgeerts
Post by robgeerts » Wednesday 10 May 2017 22:26
Could you share your calendar link (only for me, via pm) so I can test it?
(I dont care about your appointments so dont bother about that ;)
Creator of Dashticz
Send:
alveman
Post by alveman » Wednesday 10 May 2017 22:44
robgeerts wrote:Could you share your calendar link (only for me, via pm) so I can test it?
It seems to be a Internet Explorer "bug", just walked by my wallmounted iPad and there was the calendar :D and it seems to work in Chrome as well. (worked in IE before the update)
But the output looks lite random calendar objects from 2014 until now.
Martin
poudenes
Domoticz version: 3.8993
Post by poudenes » Thursday 11 May 2017 6:05
After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
I can share mine as well if you want to test it?
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
robgeerts
Post by robgeerts » Thursday 11 May 2017 8:53
Recurring will be fixed, meanwhile I fixed something in latest beta when multiple events are at the same day/time
Creator of Dashticz
Send:
robgeerts
Post by robgeerts » Thursday 11 May 2017 11:06
New version of the calendar module is available in BETA.
Please test, its not completely finished... 1 step at a time ;)
BACKUP YOUR CUSTOM.JS
Creator of Dashticz
Send:
EdwinK
Post by EdwinK » Thursday 11 May 2017 11:18
Going to check it out :)
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
robgeerts
Post by robgeerts » Thursday 11 May 2017 12:38
poudenes wrote:After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
Could you test recurring events in latest beta??
If not working, please pm me your calendar-url and date where recurring events should be..
Creator of Dashticz
Send:
mvveelen
Post by mvveelen » Thursday 11 May 2017 14:10
I tried the
maxitems: 5, ......
but that doesn't work (yet ?).
Also, I see some strange behaviour (see attachment): recurring events are shown multiple times, the date is displayed wrong, the times are...wrong.
Work in progress, right :) ?
Schermafbeelding 2017-05-11 om 14.09.55.png (282.37 KiB) Viewed 987 times
Synology DS414 DSM6.1 + RFXCOM rfxtrx433E + Xiaomi Gateway + Philips HUE Lights + Nefit Easy + Dashticz v2 + Domoticz latest Beta
poudenes
Post by poudenes » Thursday 11 May 2017 14:24
robgeerts wrote:New version of the calendar module is available in BETA.
After latest update, It shows all repeated items somewhere in 2018. And the time is 1 hour later then actual in ical calendar.
And it shows 1 time item for next day (this one is for 12th may 2017)
gielie
Domoticz version: latest β
Post by gielie » Thursday 11 May 2017 23:00
I have the calendar working fine only the days and months are in English, is it possible to show this in Dutch?
- Vision ZU1401 USB Stick
- Aeotec MultiSensor 6
- FIBARO FGS222
- FIBARO FGWPE Wall Plug
- Everspring AN157
- Neo CoolCam Power plug
- Neo CoolCam PIR Sensor
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts » Thursday 11 May 2017 23:12
"Da kenne we wel regelen"
I'm not at a pc right now but i thought there was a variable called '_CALENDAR_LOCALE' you can set to nl_NL in config.js
Creator of Dashticz
Send:
mvveelen
Post by mvveelen » Thursday 11 May 2017 23:35
Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
robgeerts
Post by robgeerts » Thursday 11 May 2017 23:37
Wich line?
Creator of Dashticz
Send:
mvveelen
Post by mvveelen » Thursday 11 May 2017 23:39
I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
EdwinK
Post by EdwinK » Friday 12 May 2017 9:59
mvveelen wrote:Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
Can we have combined calendar's again?
robgeerts
Post by robgeerts » Friday 12 May 2017 10:34
mvveelen wrote:I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
Your calendar shows right at my dashboard, I have this var set in config.js:
var _ICALENDAR_DATEFORMAT	= 'DD.MM HH:mm';
What do you have set in this variable?
Combined calendars should work again.
Creator of Dashticz
Send:
EdwinK
Post by EdwinK » Friday 12 May 2017 11:01
Okay. Going to try them :)
When I use calendars.combined I get this error message:
Error combined calendars
Screen Shot 2017-05-12 at 11.03.48.png (34.22 KiB) Viewed 856 times
Looks like this happens with the private calendar. So, when I got back from work, I will see if I can find out WHY.
Users browsing this forum: No registered users and 7 guests
