Make snapshot from Ubiquiti UVC camera
bramfm
Target OS: Raspberry Pi
Post by bramfm » Wednesday 26 October 2016 4:10
I like the Ubiquiti cameras, however the API documentation just s*cks. So I started to experiment a little and I found out that every individual camera makes a snapshot every second. Getting the snapshot (snap.jpeg) of the camera is a little bit harder.
The thirst thing I tired was fetching the file via http, so something like http://xxx.xxx.xxx.xxx/snap.jpeg, this works only If you are already logged-in.
Next I tried:
wget --user=ubnt --password=yyyyyy https://xxx.xxx.xxx.xxx:/snap.jpeg this generates the "Unknown authentication scheme" error. It seems that you have to change someting in the camera to make this work. I am a bit lazy to adapt all my camera's.
So I decided to fetch snap.jpeg via scp, problem is however that you need to enter a password and that's not very convenient. There is a trick described on the ubiquiti fora where you have to upload the key into the camera, and again I didnt want to do that.
Next I used sshpass, I know this is not the most secure method, but what the heck it's behind my firewall
sshpass -p yyyyyyyy scp -r ubnt@xxx.xxx.xxx.xxx:/tmp/snap.jpeg /tmp/snap.jpeg
where yyyyyyy is the camera's password, and xxx.xxx.xxx.xxx is the camera's ip address.
If you want to call this script from within Domotics, be sure the camera key is in the known_hosts file for root:
sudo ssh-keyscan -H xxx.xxx.xxx.xxx >> ~/.ssh/known_hosts
Now you have a snapshot in the /tmp directory. Via Pushsafer I want generate a notification with the snapshot. Be aware pushsafer is not free, but it offers much more funtionality with a better user interface than prowl, so a couple of euros is well spent.
The snapshot is rather big so you have to reduce it in size:
convert -resize 40% /tmp/snap.jpeg /tmp/snap2.jpeg
Then you need to encode it via base64:
base64 --wrap=0 /tmp/snap2.jpeg
The complete script:
#!/bin/bash
sshpass -p yyyyyyyyyy scp -r ubnt@xxx.xxx.xxx.xxx:/tmp/snap.jpeg /tmp/snap.jpeg
URL="https://www.pushsafer.com/api"
PRIVATEKEY="" #Your Private or Alias Key
TITLE="Bel!"
MESSAGE="Er wordt gebeld";
# DEVICE="131";                #Device or Device Group ID
ICON="55";
SOUND="3";
VIBRATION="0";
JPEG="$( base64 --wrap=0 /tmp/snap2.jpeg )"
PICTURE="data:image/png;base64,$JPEG";
if [ ${#PRIVATEKEY} == 0 ]
then
        echo "Error: You need to supply an app token"
        exit 1;
fi
if [ ${#MESSAGE} == 0 ]
then
        echo "Error: message may not be empty"
        exit 1;
fi
RESPONSE=`curl -s --data k=$PRIVATEKEY --data-urlencode t="$TITLE" --data-urlencode m="$MESSAGE" --data d="$DEVICE" --data i="$ICON" --data s="$SOUND" --data v="$VIBRATION" --data-urlencode p="$PI$
echo "Send Push"
echo "| TITLE: $TITLE"
echo "| MESSAGE: $MESSAGE"
echo "| RESPONSE: $RESPONSE"
echo "|____________________"
maomanna
Re: Make snapshot from Ubiquiti UVC camera
Post by maomanna » Thursday 10 November 2016 11:18
thanks!
But, do you know that you can easily add a unifi camera to Domoticz.
Set unifi camera as unmanaged
log in with standard credentials
change credentials
Add camera in Domoticz
fill in IP of the camera
new credentials
port 80
url: snap.jpeg
works like charm!
After adding, you can let the Unifi Video NVR manage the camera.
Camera keeps working in Domoticz
cybermaus
Post by cybermaus » Friday 25 November 2016 18:27
bramfm wrote:Next I tried:
Not that I know it to work, but as a thought did you try:
wget https://ubnt:yyyyyy@xxx.xxx.xxx.xxx/snap.jpeg
or maybe drop the https
wget --user=ubnt --password=yyyyyy http://xxx.xxx.xxx.xxx/snap.jpeg
wget http://ubnt:yyyyyy@xxx.xxx.xxx.xxx/snap.jpeg
And I am assuming the : in your URL was a copy/paste error while posting, and you did not really try that anyway:
pushsafer
Domoticz version: 3.5877
Post by pushsafer » Wednesday 11 January 2017 22:45
If the camera needs a https connection > try to add
--no-check-certificate
after wget.
Some cameras needs stream a cached image so i recommend to add a timestamp to the snapshot url:
wget --no-check-certificate https://user:password@xxx.xxx.xxx.xxx/s ... mp=XXXXXXX
If you need help with https://www.pushsafer.com, iam the developer, you can ask me.
